Old 06-29-2013, 06:10 PM   #645
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Originally Posted by Ridgerunner3 View Post
The hitch box on a 2500 Ram must be much higher than the new GM 2500 4X4 hitch box. My hitch is showing three holes above the stinger. You are showing zero
To be fair, I am running 285/75-17E tires too. That does create a little more height to deal with.
I think I'll email these pics to Sean and see what he says. Thanks to all, but if there are other opinions out there, I am all ears.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 06-30-2013, 04:04 AM   #646
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Email sent to Sean and returned already (that was quick, on a Saturday night too).
He said that nothing looked wrong, but if the trailer was nose-high, I needed the longer drop stinger, and he offered to swap out the OE one for the longer drop. I humbly accepted!
More to follow.
2010 Classic 30
ProPride P3-1400
Old 06-30-2013, 06:46 AM   #647
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
That's pretty darn great!!
SteveSueMac is online now   Reply With Quote
Old 06-30-2013, 06:52 AM   #648
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
If all tech support in America were like Sean's, the Chinese would not have a chance....
Larry
lsbrodsky is offline   Reply With Quote
Old 06-30-2013, 07:47 AM   #649
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
Originally Posted by lsbrodsky View Post
if all tech support in america were like sean's, the chinese would not have a chance....
Larry
You've got that right!
Zigidachs is offline   Reply With Quote
Old 07-23-2013, 04:00 PM   #650
Redmond , Washington
Hello all,
I never posted here before because I'm not an airstream owner but I have always followed this thread since I decided to buy a Propride hitch last year - it's one of the best. Well, it's hard to find PP owners so I hope you guys don't mind if I post.
I have a couple of questions, please bear with me.
What should I be doing to maintain the hitch? Currently I'm using the grease gun every 500 miles. What else?
I noticed rust on the inside of the jacks and in other areas (I live in the Northwest). I'm thinking in using WD40 or similar. I also had to re-center the yoke after I took it to the dealer.
Should I grease the trailer's hitch head? It was hard work (for me) to assemble it and I'm weary of having to redo it correctly just to add grease.
Finally, I just moved the stinger one hole down. Does it affect how I do the weight distribution on the jacks? I had them at 5.75" before.
Thanks!
(PS.: I have a video of my Propride here. Breaks and weight distribution were not yet dialed up when I made it but I still think it's nice)
chracatoa is offline   Reply With Quote
Old 07-23-2013, 08:24 PM   #651
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Thanks for the video. It's really cool to see how these hitches work! I have a Hensley, similar, but different. After 7 years I pulled the hitch to sandblast and repaint the hitch and A-frame and was surprised to see the hitch ball was still lubed well. My maintenance on the Hensley, besides the 500 miles lube, consisted of paint retouching and using a spray lube such as white lithium grease on the other moving parts.
Besides Hensley's atrocious paint job, one trip on a freshly chip sealed road in Idaho about 3 years ago is what really started my rust problems to cause the hitch repaint. Every one of those little dings in the paint started the rust issues. I wasn't very good about dealing with it at the time so it perpetuated into a total repaint. Some rock tamers on my TV would have postponed this chore, but now that it's done, it looks great!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 07-25-2013, 02:24 PM   #652
Yeah, it's not that bad now but I don't want to make it worst. I'll see if I take a picture sometime this weekend for our next trip and post it here.
We're going to do a long trip to Utah, Idaho, Montana in August. That will be our longest trip ever (so far we have been doing 2-5 hours trips).
Old 07-25-2013, 04:08 PM   #653
I have some pics here.
Old 07-25-2013, 09:37 PM   #654
TinShack's Avatar
2005 28' Safari S/O
I'm not sure what the first pic is showing. It looks like the plate that attaches the spring bar adjusters to the frame. If that's the case it may be better to touch it up with some primer and paint after a light sanding. Rust doesn't look bad yet.
The second pic shows the rub spot from adjusting the tension on the spring bar. Mine does this too, and I haven't found a solution to it. Since my recent repaint, it is already scraping down to bare metal. WD-40 of White Lithium grease will keep it from rusting.
Love your sons lego rig. It has a slideout like my Airstream! Here's a pic of my recent hitch/a-frame after the redo...
Name:	2013-07-06 11.39.16.jpg
Steve
Old 07-26-2013, 04:18 AM   #655
W , New England
Looks like Mongo de-oranged a Hensley! :-) Love it!! That looks very cool!!
Old 07-28-2013, 01:36 PM   #656
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Finally got it set up
Got the longer drop stinger installed, rivet with all four washers. Front fenders are back to original height, but rear sits about 3/4 to 1" lower. Trailer sits about 1/2"higher in front, almost perfect. I think I'll be good to go after a trip to the scales for front axle weight distribution confirmation, and maybe a few more cranks (WD jacks are at 6.5" now). Here are some pics. See anything odd or unusual with set-up?
2010 Classic 30
ProPride P3-1400
Old 07-28-2013, 03:33 PM   #657
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Are you sure you didn't drive off with my TV and trailer.
Old 07-28-2013, 07:21 PM   #658
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Wow!
2010 Classic 30
ProPride P3-1400
Looking at new TVs, Input please Mr & Mrs S Tow Vehicles 46 03-16-2012 10:39 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
