Old 06-27-2013, 07:01 AM   #631
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Originally Posted by SteveSueMac View Post
Also forgot to mention, I think the "sweet spot" is when you raise the jack to the point where you can see (and it's VERY subtle) the coupler slide off the ball.
That is what I look for also as the "sweet spot".
Bud
Ridgerunner3 is offline   Reply With Quote
Old 06-27-2013, 11:26 AM   #632
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I will watch for that next time. I believe that is the same spot that I find by wiggling the Rock Tamer bars, but it may be a better indication in these off level spots.
Ken
Old 06-27-2013, 05:36 PM   #633
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I continue to harvest good ideas from fellow PP owners. I find it sometimes difficult when I unhitch to insure that all the weight if off the TV before I unhitch. If I miss I get a nice "clunk" as my stinger exits the hitch. I wonder sometimes if the autolevel system in my SUV contributes to this.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-27-2013, 05:59 PM   #634
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
BAB - that's where the "sweet spot" has helped me most! I've had a few of those "clunk" moments. For me, dialing out all of the weight distribution from the jacks is first, then I drop the tongue jack and raise it until I see the coupler lift off the ball. It's a very slight movement. Sometimes I have to drop and raise the tongue jack 2 or 3 times to be sure I got it - but without fail, getting to that spot enables a clean exit every time for me!
Old 06-29-2013, 11:47 AM   #635
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by dkottum View Post
Here's a good video on hitching the PP.
Pro Pride Hitching Up - YouTube
doug k
After years of eyeballing the hitch height on my HAHA, I learned something new on this video...measure the height of the stinger to the height of the hitch with the wrench...gee what a concept!
Also, I don't know if anybody else noticed but he FORGOT to attach the emergency brake activator cable! That would add about 2.3 seconds of time to the total!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 06-29-2013, 12:50 PM   #636
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
P3 Received and Installed
Installed the P3 this morning. Added three links to the chains. Everything else was long enough.
My "before" front wheel well measurement is about 42 inches. After installation, I cranked the 1400 pound WD bars right at 65 turns on each side and got the front to within 1/4 inch. No time to get to the scales today, but I "guesstimate" I am within 100 lbs or so of unhitched front axle weight. My concern is that I seem to be hitch-high.
Nose of trailer and rear of truck are high, with the rear of the trailer a little low.
The hitch itself is nose-low. Stinger is at max drop.
Question(s): How do I get everything level and still distribute the tongue weight? Am I worrying about nothing?
Pics below. Opinions welcomed. Thanks.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 06-29-2013, 01:12 PM   #637
W , New England
Congrats on the installation!!
Do you have washers behind the rivet? If so, I wonder if that contributes to too much lift at the hitch?
I think you're right - you can't drop it any lower from the receiver. How far off are you from level front and back (trailer belly pan to ground)?
Old 06-29-2013, 01:23 PM   #638
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Thanks!
Forgot to mention...rivet up top, no washers.
I'll have to measure the trailer later (but will do it by this evening), just using my calibrated eye right now.
2010 Classic 30
ProPride P3-1400
Old 06-29-2013, 01:42 PM   #639
2002 25' Safari
Images: 11
Did you check that the stinger was level as described in the installation instructions? I agree the stinger appears to have too much up-angle. You may need to add washers to the rivet to get the stinger level (attached to the truck receiver, not attached to the trailer).
Bud
Old 06-29-2013, 04:31 PM   #640
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
The stinger was level as described in the instructions. But I think you're correct in that I guess I need to "overcorrect" to get level after hitch up.
2010 Classic 30
ProPride P3-1400
Old 06-29-2013, 05:40 PM   #641
2002 25' Safari
Images: 11
The hitch box on a 2500 Ram must be much higher than the new GM 2500 4X4 hitch box. My hitch is showing three holes above the stinger. You are showing zero
Bud
Old 06-29-2013, 05:50 PM   #642
W , New England
My Chevy 2500 had 2 holes over the top of the receiver but I had to bring it down one hole as my trailer nose was 1.5" higher than the trailer rear. Dropping it that one hole got all 4 corners level at 16".
You might be able to put the WD bars in to the TOP hole (not middle as you have it now) but 1) I can't swear that would work and 2) that might require more hight on the WD jacks to distribute the weight.
Call Sean for sure...
Old 06-29-2013, 06:01 PM   #643
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
How much does it cost? How much does a Hensley Arrow cost? I'm interested.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-29-2013, 06:13 PM   #644
Pahaska's Avatar
2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Just feel the sweet spot
To eliminate the unhitching "clunk", I find that regardless of day or night, I just put my fingertips on the hitch body with the hitch cup rim against my fingers and slowly raise the jack. I can easily feel the motion when the ball moves in the hitch cup. I came up with this modus operundi when unhitching one dark night and use it all the time now.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2013 Silverado 2500HD Duramax/Allison LTZ
WBCCI #9632, TAC TX-10
Looking at new TVs, Input please Mr & Mrs S Tow Vehicles 46 03-16-2012 11:39 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 10:44 AM
