Old 09-12-2010, 10:27 PM   #281
Brecksville , Ohio
Originally Posted by REDNAX View Post
leave the stinger.
Yup
A quick question. If one chooses to leave the stinger for the dealer, I assume we leave it inserted in the hitch head and let the dealer hook it up using some towing vehicle that is equipped with a receiver. If this is the case, do we need to apply any tension on the WD bars before leaving the dealer's yard or just let the bars hanging without tension?
Tigershark is offline   Reply With Quote
Old 09-12-2010, 10:41 PM   #282
_
hi tiger' welcome to the forums and this thread...
it is extremely hard to back a receiver/tv into the stinger and connect/thread the pin...
possible, but very tricky.
and how much tension on the jacks will depend on POSITIONing of that tv-receiver.
in fact jack TWEAKING will be necessary to line up the stinger tip TO the receiver hole.
it is be better for the dealer to move the stinger TO a tv and hook up in the usual manner.
for moving around in a parking/service lot, w/d tension isn't really needed
but leave enough tension on the jacks so that the head/box is supported or ~level.
some shops will use a tractor to move the unit
and might have an adapter for the stinger or use a heave chain wrapped 'round it.
never assume they (the service guys) KNOW what to do or how the hitch functions.
run through the steps with whoever is gonna move your trailer
and ask about what they'll use for towing...
while many large shops will claim 'insurance/liability issues'
prohibit YOU backing into a service stall,
others will WELCOME your offer to do this stuff and the hookups.
cheers
2air'
Old 09-13-2010, 09:01 AM   #283
Brecksville , Ohio
Tension or No Tension on WD Bars?
'round it.
cheers
2air'
Thanks, 2air', for the welcome and quick reply.
I was wondering what the best way is regarding to reducing the possibility of damaging the hitch system. I have a PP on my current TT and my dealer has a forklift that is equipped with a receiver. However, as one of the earlier posters had said, that serious demage to the hitch could still occur when the dealer tries to maneuver the TT using such setups.
I am thinking along the same line as you that leaving some tension on the WD bars could help support the heavy hitch head from dropping down to the ground. What is not totally clear to me is whether such tension would increase or decrease the likelihood of damaging the hitch when the dealer tries to hook up with his set up and maneuver it. What do you think?
I am taking my TT in for some service later today, any advice in this regards will be truly appreciated. Thanks!
Old 09-13-2010, 09:37 AM   #284
_
i read ONE 2nd hand report here of another BRAND hitch damaged...
that's not enough info 2 generate any concern imo.
these hitches are DESIGNED to generate and transmit a LOT of stress via the stinger...
with proper w/d these forces are several 1000s of lbs through the assembly.
every forklift/tractor/service mule is different including how/where the receivers are mounted.
so that topic is beyond THIS thread and requiring PIX of the specific lift/receiver as casebycase.
in other words i think MOST of this chatter about damaging the pp is UNfounded without specifics.
it is far more likely the powdercoat can be chipped or the a frame brackets/U bolts tweaked.
every time the carz or truck head to the dealer, damage TO them is possible during handling...
and there are many wayz a careless shop hand can mangle yer stream,
or break 1 thing while fixin' another.
cheers
2air'
Old 09-13-2010, 11:08 AM   #285
cms4140's Avatar
Birmingham , Alabama
I think I am the one who started this chatter - I should be able to report back on the current topic Thursday. I dropped the AS off at the local dealer for the window leak test/repair. As suggested here, I did in fact leave the stinger with them, connected to the main hitch unit per their request (no WD tension). I already have a good bit of powercoat damage to the stinger, so I will be anxious to see how much more I have as a result of this endeavor. My primary concern was them bumping the hitch unit with the forklift in order to hitch up, wondering if it would/could cause damage to the yoke set-up or get it out of line somehow.
Chris
cms4140 is offline   Reply With Quote
Old 09-13-2010, 09:47 PM   #286
Brecksville , Ohio
Originally Posted by cms4140 View Post
I dropped the AS off at the local dealer for the window leak test/repair. As suggested here, I did in fact leave the stinger with them, connected to the main hitch unit per their request (no WD )....
Chris
Chris, I am just curious. With the stinger left in the main unit and no tension on the WD bars, wouldn't the hitch head drop to the ground due to its own weight?
Old 09-13-2010, 10:59 PM   #287
_
Originally Posted by Tigershark View Post
...With the stinger left in the main unit and no tension on the WD bars, wouldn't the hitch head drop to the ground due to its own weight?
no
the stinger would angle downward a bit below the horizontal but that's it...
see MANY of the early pictures in this thread.
IF one removed the w/d bars completely the hitch head would angle downward more
but it's attached at the ball AND yoke, so it's not gonna drop 2 the ground.
________
almost every time i disconnect the w/d bars (or jacks) are maximally LOOSENed...
cheers
2air'
Old 09-22-2010, 09:13 AM   #288
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Hello folks,
I just came back from my yearly 2000 mile trip out to Kansas to attend the Walnut Valley Music Festival. I pulled our '71 Safari with my V8 4Runner and used our ProPride 3p hitch. I could tell a huge difference in the way the AS behaved from the previous long trip to pick up the Safari last September. This was my maiden voyage with Moe (our AS), so I was on pins and needles for the drive out to Kansas. I averaged 60-65 on the highway with very little notice of 18-wheelers zooming by. The hitch kept the truck and Moe stable and well under control.
With Sean's assistance I installed the hitch Labor Day weekend. Thanks Sean!!! After unhitching it at our storage lot I noticed the bracket that holds the yoke wasn't centered. I had noticed that the AS felt like it wasn't tracking correctly behind my truck. Initially, I thought it was because my chains were too short and positioned incorrectly (which was true on both accounts). Once I looked over the hitch I found the bracket had slipped. I hadn't tightened the 2 u-bolts holding on the bracket tight enough. I centered it and tightened up the bolts on the brackets before hitching up again and it tracked true afterward.
After experimenting with the WD jacks I came up with a jack height distance that seemed to balance out the truck. I stopped at 3 different truck scales on the way out to Kansas and all 3 were out of order, so I'll find one local to verify my adjustments. I know the weight distribution can only be truly verified by a scale.
No grumps from me on the hitch, but I do have a couple of observations after using it for my 2000 mile trip to Kansas. Keep it greased. Check the torque on the bolts and the adjustment brackets regularly.
The hitch is very easy to hitch and unhitch. The 3P is one fine piece of equipment. Good job Sean!
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 09-22-2010, 10:01 AM   #289
Wise Elder
Jammer's Avatar
2010 30' Classic
I too had the yoke attachment bracket slip shortly after initial installation. After realigning and retorquing the nuts everything was OK and the problem has not come back. I did have them torqued properly on initial installation and so I believe the loss of friction was due to the various components seating into the finish in the first 100 miles or so.
I see the use of U bolts that are larger than the trailer A frame members as an inherent design defect of this hitch. On a trailer where the U bolts fit perfectly (in other words, something besides an Airstream), they're fine, but in an Airstream application they are prone to slippage. This affects both the WD jack bolts and the yoke attachment bracket bolts.
Alternative designs would include either shipping a selection of U bolts of various sizes (for the WD jack this would mean drilling extra holes in the jack mount to accommodate them), or replacing each U bolt with two carriage bolts and a backing plate. I favor the second approach. Grade 5 carriage bolts are readily available and the production costs for the backing plates would be low. The backing plates could have holes punched for various A frame sizes.
Old 09-29-2010, 11:41 AM   #290
hiker's Avatar
2007 25' International CCD FB
Needham , Massachusetts
Grease Hitch Ball & Other Maintenance
What annual maintenance items do people recommend for the PP?
Also, has anyone installed a zerk fitting on the trailer to permit greasing the hitch ball without disconnecting the PP? The zerk fitting question was asked (and answered) on the HAHA thread but interested to hear what others think.
Mike & Joan
WBCCI #1521 New England Unit
06 Chevy Duramax/Allison
hiker is offline   Reply With Quote
Old 09-29-2010, 12:19 PM   #291
SteveH's Avatar
Common Sense , Texas
Yep, I drilled a hole thru the top of the coupler and installed a zerk fitting there. I grease the ball every time I grease the bar locations, and try to remember it every trip, or every few days on a long trip.
Regards,
Steve
Old 09-29-2010, 12:55 PM   #292
_
hi hiker, thanks for posting.
if one spends a little time looking at the coupler/ball area...
it's pretty clear that very little motion occurs at the ball, especially when compared to other hitches...
that LACK of motion could be used as reasoning for more or less grease'n.
keep in mind any FRESH grease pushed in will result in older grease being pushed out.
and unless that older grease is throughly cleaned up it becomes a dirt magnet and could wick stuff into the recessed space.
my approach over the last 5 years...
has been to inspected and clean the ball/coupler annually; this was just done on the pp.
and then finger apply a coating to the inside of the a/s coupler and a thin coat on the ball.
otoh the w/d bar heads/bushings/retention discs CONSTANTLY move...
so they get injected a lot more frequently, weekly on long trips and every 1000 miles on short/local excursions.
What annual maintenance items do people recommend for the PP?...
timely question, since this thread is just hitting a year marker.
as an annual process i just disassembled and REmounted the pp...
inspected all the bits, cleaned, lubed, checked thread/nuts, wear parts and so on...
i'll have a pictorial on this up here eventually...
lets hope other users will report on their regular maintenance/inspection routines.
cheers
2air'
Old 09-29-2010, 05:26 PM   #293
Wise Elder
Jammer's Avatar
2010 30' Classic
2 1/2" receiver compatibility
Is there a stinger available for 2.5" receivers?
Does the PPPPP work well with the 2 to 2.5" adapter sleeve?
Or is it a better choice to DOWNgrade a tow vehicle so equipped to a smaller receiver?
Old 09-29-2010, 05:33 PM   #294
SteveH's Avatar
Can't really answer your questions, but my truck came with a 2 1/2" reciever, and not wanting the slop when using the adapter, I welded the adapter into the 2 1/2" reciever making it a permanent 2" with no slop.
Regards,
Steve
Looking at new TVs, Input please Mr & Mrs S Tow Vehicles 46 03-16-2012 11:39 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 10:44 AM
