10-11-2010, 07:39 PM
#301
2009 23' FB Flying Cloud
The Woodlands
Finished 1st trip with the Propride
Well we just finished the official maiden voyage with our trailer. We towed from Houston TX to Minneapolis and back with no issues. This is only our second tow (1st was bringing her home from La), but the differences were unbelievable.
The trailer and truck acted as a single unit and easily handled at freeway speeds of 70+. A very Zen experience with no sway at all! Rig was so stable that my wife drove for at least 50% of the trip (that alone was worth every penny).
All in all it took about 7 hrs or so to install. This thread was invaluable in helping me to fit the slightly unique aspects of the Airstream.
A few things I did similar to others:
1) cut the tabs one side of each jack to accommodate the propane shroud
2) used washers & nut to "elevate" the propane bottle tray above the U-Bolts
that attach to the yoke bar.
3) Utilized shorter (1.5") SS bolt on the back of the jack bracket. Ones
included were way too long due to battery box location.
Still need to get to the scales to get totally "dialed in".
Here are some pics of the finished product. Thanks for all of the great info here.
10-11-2010, 08:45 PM
#302
_
nice report hansom'
good looking rig (gotta love red trucks)
thanks for taking the time 2 post here and including pix!
cheers
2air'
10-25-2010, 03:54 PM
#303
Brecksville
, Ohio
In an attempt to adjust the tilt of my 3P hitch head, I have recently inserted two additional washers to the tilt bolt (from 1 to 3). A question that I now have is whether this change will require the re-adjustment of the level of tension on the spring bars that I had previously dialed in. Do I need to hit the CAT scales again to make sure that the proper weight distribution is still maintained? My initial observation is that when I raised the spring bar links to the original height that I had previously marked, the front end of the truck now seems to be compressed more. Thanks!
10-25-2010, 04:56 PM
#304
Common Sense
Your observation would be correct. If you drop the rear of the draw bar, which adding washers would do, with the same amount of height on the jacks, the hitch weight would be moved farther foward on the tow vehicle.
Regards,
Steve
10-25-2010, 08:23 PM
#305
_
Originally Posted by Tigershark
In an attempt to adjust the tilt of my 3P hitch head, I have recently inserted two additional washers to the tilt bolt (from 1 to 3)...
exactly why was there any need to adust the 'tilt' of the hitch head?
manipulating the stinger with the bolt/washers is mainly used to deal with RECEIVER issues.
this is a case where PIX of the installed hitch and tv connection are needed.
no pix preclude any meaningful exchange.
________
on a side note IF/when the rig is dialed in,
quickly take measurements (height) at the 4 wheel wells/bumper and receiver.
those height/distances can be used as basic reference/until scale readings are repeated.
cheers
2air'
10-29-2010, 12:56 PM
#306
Brecksville
, Ohio
________
cheers
2air'
The main reason for the adjustment was that the lower end of the adjustable shank of my hitch bar was previously pointing backwards (towards the truck) when tensioned up. I didn't pay too much attention to it at that time. However, when my dealer saw that, he suggested that I insert some additional washers. The shank is now pointing perpendicular to the ground, may be a little forward towards the TT.
As to your second comment, that's what I did as a quick check. Since I noted that the front of the truck appeared to have compressed more than before, I wanted to ask the question here just to confirm that I would need to redial in the WD settings. I plan to take the rig to the scales at the beginning of next
season to get the actual weights.
Thanks for the help!
12-04-2010, 09:30 AM
#307
Castaic
Pro Pride Install Project!
This was more than install, it's a project! It took about 4 hours with help from my buddy Steve. Neither of us had any experience with this product. It seems to go pretty well as long as you just take one step at a time. We had to modify the propane tank area to get the yoke support bar installed. Also, I have to get chain and electrical extensions. Other than that, no glitches. Now, it's just a matter of getting it dialed in.
Here are a few pics:
2011 International 25' Signature Series
2010 Dodge Ram 1500
Pro Pride Hitch
12-04-2010, 09:32 AM
#308
Castaic
One more pic of it hooked up.
2010 Dodge Ram 1500
Pro Pride Hitch
#309
Port Orchard
ProPride sells an extension kit containing both those items.
Ken
12-04-2010, 09:33 AM
#310
Airstreamin and luvin it
Northwest Panhandle
, The Sunshine State/WBCCI 6637
extensions
The chain and Plug extension should be in the box.Well from what I remember...They were in there.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
12-04-2010, 09:40 AM
#311
Castaic
Nope. 100% sure it was not.
2010 Dodge Ram 1500
Pro Pride Hitch
12-04-2010, 12:07 PM
#312
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I found on mine that there was enough extra slack plug wire near the "A" frame and body to ease out the necessary amount allowing me to not need an extension. The chains definitely needed a few extra links.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
12-04-2010, 06:24 PM
#313
Northwest Panhandle
Strange
Mine came with them.You can see my pics in post #41.
Maybe they forgot or changed something in the packaging system.Dont really know until you give Sean a call.
12-04-2010, 06:53 PM
#314
_
thanks for joining us rik'
u r correct the installation is a full day of fun.
the classics went through a phase with shorter chains, then longer, then shorter...
sometimes the 7 pin can be made longer by using the slack.
sorta dependz on how much stinger drop is needed.
most of the safari/cloud/internationals seem to need the extension kit.
often only 2-3 links extra, per side does it.
the kit is not automatically included, it's an order item, as ken suggests.
i think IF ordered (or discussed with sean prior to shipping) it would be in d'box.
email/pm/call him monday, that should get the kit shippin'.
>>>did u order the 1000 lb bars or 800 or what?
>>>how much drop did you bolt into the stinger?
u probably know this...
in order for the w/d bars to reload the front axle,
there needs to be enough initial drop so that as the jacks are tightened,
the rear of the truck will come UP several inches,
the initial drop helps 2 keep from raising the trailer past level.
wheel well, bumper or beltline measurements can help with this till hitting a cat scale.
cheers
2air'
12-04-2010, 07:38 PM
#315
Castaic
Yes, I re-Routed and there is enough. I still am thinking about some extension just to be redundant.
2010 Dodge Ram 1500
Pro Pride Hitch
12-04-2010, 07:42 PM
#316
Castaic
I have changed the Stinger twice now. I am going to mess with it again tomorrow again, probably. I don't think I need any tilt with the washers, however. Seems to cock it too far forward. I removed one washer, raised the Stinger and it's a bit more level, but now has more tension on the WD jacks.
I have the 800 BTW.
Wish there was a set up video somewhere. I would so do one if I knew the correct set up.
cheers
2air'
2010 Dodge Ram 1500
Pro Pride Hitch
12-09-2010, 05:29 PM
#317
Castaic
2Air,
Sorry, I actually have the 1000 lbs bars.
2010 Dodge Ram 1500
Pro Pride Hitch
12-09-2010, 05:37 PM
#318
_
no problemo'
the 1k bars are probably a better choice
with your combo'
cheers
2air'
01-18-2011, 03:10 PM
#319
2007 30' Classic S/O
2010 31' Classic
West Linn
, Oregon
New Propride Installed...
Here are pictures of my install completed on Friday, January 14th and scaled on state scales on January 17th. Install took about six hours with two of us doing the work. Thanks to Sean and 2airishuman for their assistance. Much smoother ride compared to my equalizer. We are using 5.5 inches of WD Jack with a single washer for stinger tilt.
01-18-2011, 03:26 PM
#320
_
yeee haw!
it's about time
nice job bramer.
good looking rig too.
focusing on the lower left pic in CLOSE UP views...
it appears the yOke isn't parallel with the tongue/A frame?
perhaps it is, and pic is fool'n me,
but the 2nd bolt hole in the yoke is elongated,
and the bolt is near the top of the hole ?
so the rear part of the yoke looks elevated?
this probably doesn't impact function of the hitch,
but will make it appear that MORE tensioning of the jacks is needed.
so IF the yoke were leveled, the spring bars would require LESS lifting for the same tension...
does that make sense?
________
i mention this only because IF it's not intentional, it is possible that the yOke slipped up some...
and the yoke nuts/bolts are not adequately torqued?
________
ok, enough of that and thanks for posting.
that indoor location looks extremely level, a great spot for an install.
let us know how the towing/hookup and general maintenance goes.
the install time should drop some for the next new stream too...
cheers
2air'
