01-13-2010, 05:21 AM
#201
Common Sense
IMO it has nothing to do with the "U" bolts. They are only there to keep the jack brackets from falling off until you tighten the set screws. They carry no weight, and counter no torque.
This problem exists on Airstreams, I think, because the jack brackets are made to universally fit all trailers, and so there is extra space between the tongue and the bracket that the set screw has to take up. The fact that the Airstream tongue is made from tubing, and can give under the set screw, compounds the issue.
I am confident the extra plates will solve the problem.
01-13-2010, 08:55 AM
#202
ProPride Industries, Inc.
Holly
, MI
Thought I should chime in here...
I'm not really sure why this has happened with about 5 customers. That is 5 times out of close to 1800 hitches on the road. That IS 5 too many for me.
The plates DO solve it nicely because they take up the space that allows the jack to tilt.
ProPride Hitch
"The Most Advanced Generation in Trailer Sway Elimination"
Holly, MI
Tu ne cede malis
01-13-2010, 09:48 AM
#203
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
not one of the 5
Striving for perfection is admirable. Thanks! Hard to find in this day and age. I have my Propride since April 09. I have twisted it into some very tight angles and have found no loosening of the mounting brackets since installation with a torque wrench. I have measured the thickness of my box A frame with paint and I get 2.35 in. There is room for a 3/8 in. plate/shim between the mounting bracket and frame. I could fill this space if I find a problem. But so far I no reason to anticipate the necessitiy. Again, Thanks for a quality product that does exactly as advertised.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
01-15-2010, 07:07 AM
#204
Wise Elder
2010 30' Classic
South of the river
I note that many of the ppppp users who have posted here have fairly heavy spring bars, generally 1000 pound. In contrast, every time the subject comes up with any other hitch, Andy reminds us that heavy spring bars combined with the rapid rear axle spring rate common on most TVs can lead to greater stress on the 'stream. With other hitches, at least, he seems to recommend that when in doubt use spring bars with a smaller rating.
I realize that a certain amount of trial and error at the scales is the only way to get this perfect and that there is some adjustment that can be made with the jacks. However, the spring rate does differ and I would like to take Andy's advice, which would mean running 750 pound bars for my setup (I expect the tongue weight for my rig will end up midway between 750-1000 pounds). Does this make sense or are the heavier bars really necessary?
01-15-2010, 07:20 AM
#205
Common Sense
Jammer, If you go back and check Andy's recommendations to go to smaller weight range bars, he is specifically talking about Reese square trunion bars, which are well known for a rough ride. The PP hitch uses round bars, which on the on the other hand, are known for a smooth ride.
Another issue is the actual weight of the PP hitch....I am pulling a 25' with the hitch, and the trailer has a tongue weight of about 780 pounds. But, when you add the 230 pounds of the PP hitch to that, the actual tongue weight is closer to 1000 pounds, which is the weight rating of my bars.
I am happy with the ride with this hitch and weight range bars.
01-15-2010, 08:47 AM
#206
Port Orchard
When I ordered my hitch, I had a discussion with Sean, about what bars I should use. I Had previously seen many of Andy's posts about bar rating. Sean stated that I should use 1400# bars. It seemed to me that the manufacturer of the hitch would likely be the best source for this information. I have not regretted that decision once. The ride is very good, much better than I had with my previous TT and an equalizer hitch.
No disrespect intended, but I don't know if Andy has ever used or even seen a ProPride hitch. My advice: Stick with what Sean tells you.
Regards,
Ken
P.S. I notice your setup is similar to mine. In my case it takes a lot of flex of even the 1400# bars to get the weight distributed properly.
01-15-2010, 10:00 AM
#207
_
... Does this make sense or are the heavier bars really necessary?
no it does NOT make sense (but sounds appealing like many myths) and yes PROPERLY rated bars are necessary.
select bars based on anticipated tongue mass, which is MORE than the a/s factory estimates.
the 30 footer needs 1000 OR 1400, IF you plan to carry FULL lp tanks or ADD batteries...
the advice to go 'light' isn't based on any REAL data that ANYONE else has duplicated.
lots of thread space is taken up by this issue.
dual cam hitches rely on bar FLEX to engage the cams properly and light bars SOMETIMES are needed for that purpose.
for example a small trailer with YOUR older 3500 truck.
but the pp doesn't rely on BAR FLEX to engage sway control.
so one may adjust the bars to almost ZERO if that's your need, even 1400 lb bars.
i've had contact with dozens of owners (haha/pp) who TRIED lighter bars and could NOT achieve ideal w/d on their tv...
and they ALL eventually traded up or PURCHASED higher rated bars for larger streams...
the issue/worry becomes 'does bar stiffness affect the forces ON the trailer' structurally and if so HOW...
that too is the debate of a lot of theads, mostly with NO data to support the opinions offered.
here is an example of real data on this issue...
http://www.airforums.com/forums/f238...tch-53341.html
back in the orange daze, i was able to get a good set up INITIALLY with 1000 lb bars, FULLY tensioned.
http://www.airforums.com/forums/f238...-in-17984.html
and was advised to go to LIGHTER bars, which didn't exist at the time (for that hitch) and would have UNDONE the ideal distribution.
after towing awhile the 1000lb bars (and truck springs) could no longer balance the axle loads.
and i had to go UP TO 1400 lb bars to achieve proper load balance, AND add a leaf to the truck.
totally the opposite of the 'light bar' approach, but with great data and towing records to support the move.
dont' waste a year and a lot of gyrations on this issue, follow the manufacturers advice...
and those (the other guys posting) who actually have done the exercise.
if you need more user proof check the haha thread too or ANY of the others that really dig into the details.
cheers
2air'
01-24-2010, 08:10 PM
#208
Common Sense
A Little More Experience
Went to a rally this weekend, and on the way back we were driving with a cross wind of 20-25MPH, with gusts up to about 35, but the gust speeds are my estimation.
Anyway, on the way home I was following a club member/friend who tows an '85 25' AS with a Ford F150. He uses a Reese roundbar WD hitch with a friction sway control, I helped him hitch up, and knowing the conditions we would be driving in, I thightened the sway control as tight as I could get it by hand.
We had no serious problems, but I couldn't help but notice his trailer being whipped around by the wind. At times, it appeared the trailer would sway at least 6" or more to the Left in the wind. I also noticed at the same time, while watching down the side of our trailer in the same wind conditions, no swaying at all.
I was definately feeling the wind, but there was no swaying. I really like the way this ProPride hitch performs.
Regards,
Steve
01-27-2010, 10:45 AM
#209
Holly
, MI
Beware
I'm not sure if this is the place for this post but thought it would be good here since many future customers read about the PP here in this thread.
Just found out about a new tactic being used.
It seems there is a company advertising on Google for the term "propride hitch." THAT isn't the problem. That is how Google advertising works for keywords.
The problem is this...
An Airstream dealer clicked on the ad to order a 3P-1400 for a customer. (The customer SPECIFICALLY named the hitch and the model)
The company at the other end of the ad quoted a hitch price and shipping to this dealer.
Luckily, someone else at the dealership called me and I had to return the call. By returning the call I found out that they had ALREADY been quoted a price and delivery on the hitch. Well, THAT is impossible since I am the person that does that and it had NOT happened.
Anyway, the purpose here is to let future PP customers know that they should provide the PHONE NUMBER of ProPride, Inc. to the dealer if they wish to purchase their hitch along with their Airstream.
(P.S.- The customer IS getting what he wants so it was all cleared up with the dealer.)
ProPride Hitch
Holly, MI
Tu ne cede malis
03-03-2010, 10:07 AM
#210
Wise Elder
2010 30' Classic
South of the river
In all the discussions of proper fastener torque, is there a reason there is no mention of use of Loctite or a similar thread locking compound? I use the stuff all the time and have much more faith in it than I do in split-ring lockwashers.
Another idea to consider would be upgrading the split rings to toothed lockwashers which have far greater holding ability. Or, for things like the WD jacks, nuts with the nylon friction lock feature.
With all this discussion of retorquing fasteners it seems to me there must be a better way. Aside from worst-case scenarios like aluminum wheels (where lockwashers can't be used and the stretchable length of the fastener is small) periodic retorquing shouldn't be necessary.
03-03-2010, 10:27 AM
#211
_
i dont' see a LOT of discussion HERE (this thread) on RE-torqueing fasteners yet...
its an issue on some other hitch brands and in other applications (lugs) but not so much here.
i too considered thread 'goo' and still might use it on the pp some day...
but so far the nuts/bolts/threads have ALL stayed PUT, where i PUT them...
my approach has been to MARK the threads/nuts once fastened with a dab of paint or silver/metallic sharpie...
this allows for a quick visual check without a wrench in hand.
and so far no slipping in 7,000 miles of use.
the value of red/blue/green loc compounds where ONE TIME fastening is the objective is clear...
but the effectiveness of anaerobic fastener compounds is directly related to how CLEAN the threads are maintained...
or how frequently they are RE adjusted (OR removed) which is an issue with hitches...
i'm a big advocate of using thread compounds on bike spokes but the issues are somewhat different in that application too...
i also notice that the major player in thread loc-ing sealants now offers a product with PTFE in the mix?
____________
anyway i don't see a lot of need HERE yet once the set up is dialed properly.
and EVEN with thread compounds the warning to 'check yer pp nuts' would still apply.
cheers
2air'
03-03-2010, 10:43 AM
#212
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
2air', now for the proof of the pudding. How is the Propride performing?
Now that you have 8,000+ miles under your belt, tell how you like the Propride vs. the Haha.
- Does the PP perform equally as well in sway elimination?
- Is the hook up procedure any easier than the Haha?
- Is the weight distribution function equivalent?
- Are you seeing any signs of fastener wear on the height-adjustable hitch bar?
- Has there been any finish deterioration of any of the finishes, as is so common on the Haha?
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-03-2010, 10:53 AM
#213
_
Originally Posted by moosetags
...Now that you have 8,000+ miles under your belt, tell how you like the Propride vs. the Haha.
Brian
hi brian...
i'll be digging into EACH of these issues soon and continuing the photo comparison between parts (hitch head, jacks, yoke/struts)...
but direct answers are...
YES on similar relaxed steering for the driver, trailer control and LACK of sway.
YES, YES, YES on hook up (the new hitch head BOX is better)
YES on w/d function...
NO signs of fastener wear on the stinger...
a couple of TINY nicks in the finish (my clumsiness) but overall the powder coating is...
SO MUCH better looking, durable and easier to maintain at nearly 6 months of exposure and use.
so yes i'm VERY happy with the PP switch over and the costs to do so.
cheers
2air'
03-03-2010, 08:10 PM
#214
Vintage Kin
Fort Worth
And I'll make a request per an old post where 2Air indicated an analysis of multiple scale readings on the HAHA would be forthcoming . . perhaps those could be integrated here as the current TV is a known quantity (only an extra leaf into the rear's, correct?) and I have the impression that a 700 LB/FT new truck is on the horizon . . . .
Thanks for consideration
03-18-2010, 07:44 PM
#215
2010 27' FB International
Birmingham
, Michigan
Yes!!! Thank you all for such great information.
04-21-2010, 12:47 PM
#216
Wise Elder
2010 30' Classic
South of the river
I took delivery of my trailer yesterday. Since my local Airstream dealer is not a dealer for ProPride, and their service technicians have never seen or heard of ProPride, I did not want them to install my hitch. Better that I install the hitch myself than pay someone else by the hour to read the manual and figure it out while I wait in the showroom.
I had assembled the stinger and installed the stinger, head, WD bars, and the front two yoke arms on the truck earlier in the week, pulling the WD bars out to the side and using a ratchet strap to hold them up. The process of installing the hitch in the dealer's parking lot took about an hour and a half.
There are several important things I learned.
* As others have found it is necessary to bend the propane line slightly to provide clearance for the yoke bracket.
* It is also necessary to make some accommodation for the interference between the propane tank cover and the WD jack brackets. I think I'll end up trimming part of the rod stock on the WD brackets so that the propane tank cover will fit as intended.
* On my trailer the curb-side WD jack had to be mounted a little further forward to clear an obstruction (a propane line bracket if memory serves) causing it to rub slightly against the propane tank cover. I put a rag in between to prevent damage on the trip home and will probably shim the front of the jack bracket a little for a more permanent repair.
* My hitch had excessive paint on the nuts welded onto the WD jack brackets. I had to chase the threads with a tap to make them usable. I caught it when trial fitting everything before going to the dealer, so it wasn't a big deal.
* The grooves on one of the WD bars for my hitch were cut too deep causing the metal retainer disc to fail to engage with the bushing. This could lead to loss of a WD bar when driving over a high point. Sean said this is a recent problem and sent me a larger retainer disc at no charge.
* Some sort of provision for extending the electric cable and safety chains is required even on new Airstreams where the factory chains are purportedly longer than they were in older production.
Also some shortcuts and facts to consider for an easier installation:
* I did not try to measure for placement of the WD jacks and yoke brackets. It is easier and quicker to line everything up by eye.
* In deference to my deep distrust of split-ring lockwashers I used loctite. I believe that especially on the U bolts this makes for a far more secure installation because the nut does not then rely on fastener tension to remain secure.
The performance of this hitch on the road far exceeded my expectations. The trailer pulled straight and true, and was not affected at all by the bow wave of passing semis even at 70 mph (I did have a problem with porpoising but that's because of worn-out rear shocks in the truck and has nothing to do with the hitch). Turning and backing performance was smooth and predictable.
Rigging wise I followed these steps:
1. Start with WD bars slack and tongue jack holding trailer up at the neutral point where there is no force up or down on the hitch.
2. Lower tongue jack an inch or two.
3. Tension WD bars until the tongue jack no longer carries any weight.
As imprecise as this sounds it gave me no measurable change in the front fender height. I checked axle weights at the closest CAT scales and added a little WD tension since the front axle was lighter than I wanted.
05-05-2010, 01:10 PM
#217
2010 27' FB Flying Cloud
Oakland
Our ProPride Hitch Installation
We took delivery of our new 2010 Flying Cloud 27FB on 4/29. Like Jammer, the dealer did not offer ProPride as an option; they were willing to install it for $500-600. My husband, John, read the instructions, checked all the parts and decided to install it himself at the dealer's. We packed up the ProPride Hitch and the Enkay Rock Tamers and headed to the dealer's. Here are John's comments on installation which we have emailed to Sean. We both feel that Sean was incredibly responsive...at every step of the way. A note on ordering. This is not an off the shelf item. I placed the order on 4/12, took receipt on 4/28. Here are John's comments: -MaryD
Sean,
You will be pleased to know, I presume, that I did successfully complete the installation of the ProPride hitch on our new Airstream trailer. I very much appreciate your availability by phone, and your reassurance at moments of stress was invaluable to my success. As I indicated in one of our conversations, however, I believe that your instructions could use some improvements which, if incorporated, might free up your time to improve your handicap, or whatever it is that you might rather be doing. Some of these observations are going to find their way onto the Air Forums for the benefit of those who might acquire a ProPride before the instructions are revised. So, starting at the beginning, here goes:
Page 4, Pre-Installation. You should give a complete list of tools required at this point. I went through the instructions prior to heading off to pick up the trailer and install the hitch, and purchased those items that I identified as not being in my collection. But this is something of a hit-or-miss process, and a list up front would be very desirable. Also please note that not all sockets are the same; a number of procedures require a deep socket, and this distinction should be specified. Also, you supply the 15/16" socket called for in assembling the Hitch Bar, and this would be an opportunity to take some credit.
A list of things to be ready for would be desirable. Notably, in my case and I assume many others, being alerted to the need to shift the gas line running under the A-frame to accommodate the retaining U-bolts for the Weight Distribution Jacks would have eased my anxiety over this matter. In my case the gas line is held with pop riveted clamps and the rivets need to be drilled out to free the line, so add a competent drill to the tool list. The drill will also be required for the gas bottle tray.
Page 5, Adjustable Hitch Bar. This went reasonably well. I found step 4 confusing, read it a number of times, and still ended up having to flip the Hitch End. I’m not sure how to make this any clearer. Maybe a chart of the various conditions would help; I’m often better at graphic or charted information than textual information, while others are the opposite. Both approaches might help. Another possibility would be two line drawings illustrating the above and below conditions with the dimension "X" shown and an => "X" do this and < "X" do that sort of approach. The problem (to me) is that the words in the text become so repetitive, and "Hitch Bar Hitch End" & Hitch Bar Receiver End" so similar that one’s eyes glaze over. Simply stated, it needs cleaning up. The clarifying notes regarding the tilt adjustment pin and using the hole v. the slot in the side plate are useful.
Page 9, Weight Distribution Jacks. First problem we discussed on the phone: is the angled rod necessary? There was no way the jacks were going to clear the gas tank cover with the forward end intact. The Pre-Installation instructions suggest removing the tanks before starting, but I would not have caught this conflict had I done that. An instruction to check the clearance of the tanks &/or their cover would be beneficial at this point; then note that the piece can be cut off. And add a hacksaw to the tool list. Or simply eliminate the part. Depending on the depth of the A-frame members, the U-bolts may be too long for a standard socket; a deep socket should be specified. My solution was to cut ¾ inch off each threaded section to 1) accommodate my socket and 2) keep from goring myself on the protruding ends later. Another job for the hacksaw. Now consider this: your instructions presume that the installer is removing an existing hitch and installing the ProPride. That being the case, the installer is probably doing this job close to his/her complete tool assortment &/or shop facilities. We started with a new trailer and installed the ProPride as the original hitch. I brought the tools I thought I’d need and a general assortment as well, but I’m doing the installation in the dealer’s lot. I do not have a heavy equipment service truck. So try hacksawing off the end of a u-bolt without a vise. I improvised, and it worked OK: I turned the hitch bar assembly 90° in the receiver and stuck the leg of the u-bolt through the lynch-pin hole to steady it, holding the other let down against the hitch bar. I could have attached the jack using an open-end wrench, but there is insufficient clearance to hacksaw off the bolt end in place.
Page 10, Weight Distribution Jacks, continued. "Step 5: Insert the ½ X 3-1/2" Adjustment Bolt in the threaded hole on the inside of the bracket." Yeah, right! On my trailer there is a battery box inset between the arms of the A-frame; no way a 3-1/2" bolt is going to insert in anything. I fail to see how a 3-1/2" bolt could be required in any case, even if the A-frame were open C-channel, but a bolt that long is certainly not going to fit if there is a battery box in that space. So off to buy replacement bolts; 2-1/2" is plenty, and they have to be pre-threaded into the Jack almost to the limit before locating the Jack on the A-frame in order to allow the Jack to come forward enough to be within spec. Also, there are ½" nuts included with no other apparent purpose, so I used them as jam nuts, but there is no mention of that application in the instructions. A further word of caution: a 2" bolt would have been sufficiently long for my application, even allowing space for the jam nut, if I had been able to get one threaded all the way to the head. I settled for a Grade 8 bolt threaded to within about ½" of the head, and managed to get the clearance I needed. Of course, one could cut off the 3-1/2" bolt to the necessary length-another job for the hacksaw-but then there is the "how do I hang on to this while I cut it?" problem. If I’d been at home, it would have been simple, but I was 125 miles away, in the dealer’s lot without a service truck; am I beginning to sound repetitive?
A quick quality control issue here: I was test driving the adjustment bolts and one was rather stiff. I assumed it was the paint, and tried to crank it on in to no avail. I realized I was stripping the bolt threads. The problem was a blob of weld dribbled into the nut. Fortunately the dealer’s shop was kind, and cleaned the thread with a ½" tap, but I could have been in real trouble.
Another Jack issue is likely unique to a select few trailers, but mine is one of them (2010 Airstream Flying Cloud 27’ FB, double bed). This model has a centered front storage compartment with a downward opening door. When open, this door lies flat on the battery box and extends almost to the leveling jack. With the Weight Distribution Jacks installed, the door does not open fully, limiting the size of what can be put into the compartment. Furthermore, when open, the door rests against the Weight Distribution Jacks. If the door is open when one is lowering the jacks, the door may become caught under the lower edge of the outer (upper) tube of the jack, and be pulled down with it. This puts a mush mark in the edge of the door, as I found out the hard way. (AAAgh! My brand new trailer!) Not your fault, but a conflict that may be common enough to warrant your calling attention to it, both in the Jack installation instructions and the unhitching instructions.
Page 11, Frame Bracket. We discussed this on the phone: while the photo on page 12 makes it clear, the instructions on page 11 do not make it clear that the holes in the gas tank tray need to be perpendicular to the axis of the trailer and not perpendicular to the axis of the A-frame member. Suddenly the holes are in the wrong place, and new ones need to be drilled. Since the error is not terribly great, the new holes need to intercept the original holes, which is bad drilling practice. So the new hole has to be put a little further away than necessary, then the intervening bit of metal filed out. Another tool required; I used three different files. Also, the drill bit of the appropriate size should be specified. A can of Black Rust-oleum enamel is a good addition as well for, although this is an error that will be hidden by the gas tanks, it is good to get a protective coating on all the holes, necessary and unnecessary. My gas tank tray is not welded down. But removing the tray and replacing it on top of the u-bolts would have been problematical. The tray appears to be held by self-tapping screws which are not likely long enough to span the gap that the u-bolts would create between the tray and the A-frame. And I do not think the tray would be stable on top of the U-bolts. On the other hand, now that the u-bolts go through the tray, the round bottoms of the gas tanks are a bit rocky because they hit the u-bolts. You warn about locating the u-bolts so that they do not interfere with the ring on the bottom of the tank, but not the tank bottom itself. Although the tank clamp holds the tanks down firmly, I’m thinking that some sort of shim to lift the tanks above the u-bolts would be beneficial.
Page 15, Weight distribution/Spring Bars. We discussed on the phone the fact that the links have six holes, not three (so there is no "middle" hole), but otherwise, this step went reasonably well.
Page 18, Yoke. This took some doing to get in; I had to shift the Frame Bracket (more holes). Annoying (and my own fault) but not difficult; only fussy. The issue with this step is that the ¾" bolts cannot be torqued to 250 ft-lbs because the nuts are too soft. I set the torque wrench to 150 to start, and reached that level. However, as I upped the setting, the nuts rotated past the nut block; I rounded off one corner on each nut and stopped. Unless my brand new torque wrench is defective, these bolts are not torqued to 250. Setting the nut block clearance tighter might allow more torque. Using a set of feeler gauges (yet another tool) to fill the gap between the nut and the nut block might make it possible to get higher torque; I had a set with me but did not think of it at the time. A harder bolt-grade 5 or 8-might solve the problem. The question is whether 250 ft-lbs is a tested value or an assumed value; perhaps the solution is to reduce the spec. In any case, mine are as tight as they will go, and I am a bit concerned that the nuts have locked up against the lock washers enough that I will be unable to remove the bolts if the time comes.
Page 21, Final Installation Adjustments. Regarding instruction Number 3, torque issue as above. Regarding the note, you do not give a solution if the trailer is not reasonably level. I assume (and the dealer confirms) that one would adjust the setting on the Hitch Bar assembly, but that is not stated.
Page 23, Unhitching. Step 2 specifies that one should lower the tongue jack (raise the trailer) to take the weight off the back of the tow vehicle, but I was unable to discern where that point was. The geometry of the device is still a little unclear to me, but there seem to be three points at which one might be able to see a shift indicating that the tow vehicle is now being lifted rather than weighted down. These are at the hitch ball, where the hitch bar enters the main hitch unit, and where the hitch bar enters the receiver. All of these fit tightly enough that no shift is visible, although the hitch bar/receiver junction is somewhat obscured by the hitch mounted mud flap hanger. Pulling out the tow vehicle resulted in a significant drop of the tow vehicle; I was actually lifting my truck with the tongue jack. Taking a rough measure against my shin, I now have a better idea of what the level ought to be, but no precise measure. On my former trailer, using just a ball hitch, there was enough slack in both the ball joint and the receiver joint that one could have identified that change over point had it been necessary, but not with the ProPride so far as I can tell.
My installation was conducted over a period of 12 hours, but that includes time out to demonstrate my former trailer that I was delivering to a buyer, and a number of excursions for parts and tools. I estimate that, had everything been in place at the outset, I would have completed the task in about six hours. I may be a novice at hitch installation but I am tolerably mechanical; I think that a two-hour estimate for installation is overly optimistic.
These comments are not meant to be a criticism of the ProPride hitch, but rather to minimize the angst of installation. As I may have mentioned on the phone, a friend of mine used to manufacture model railroad kits. The hardest part was writing the instructions. Because he is an excellent molder already, has all the necessary tools on hand, and had designed the kit, assembly to him was very straight forward, but he always got complaints from buyers who found the instructions unclear. Writing instructions for the integration of a kit such as the ProPride with an assortment of variable existing products (the various different trailer designs) is clearly even more complex. I read the instructions start to finish before I even left home, and it was insufficient. There need to be more warning flags for installers, most of whom will be installing their first and last hitch.
05-05-2010, 01:53 PM
#218
_
ok, 2 nice verbal reports...
good job jammers and maryD.
but WHERE are the pickchas!
no doubt the OFFICIALly supplied written instructions are...
not very polished...
there are some serious stylistic issues in the official word/picture document...
and some very cumbersome wording in that document 2.
which leads us TO this UNofficial guide.
the instructions provided here, in posts #7-21 and the #50s posts and the #150s posts
are ALL very useful...
so are the many photos added to this thread.
there are good examples of the bolt/nut block issue, the lp tank mods, gas line routing and so on...
essential TOOLS are also nicely covered here.
____________
MOST of the w/d hitches used require modification (movement) of the lp gas lines on streams ...
so if anything that's really an A/S issue, since they ROUTE the lines where brackets mount for several of the hitch makers.
____________
DIY installation is a good thing, since WE become quickly familiar with the parts.
but DEALER COST for HITCH INSTALL should be negotiated WITH the purchase price.
my old orange was installed BY the a/s dealer because i ASKED before purchase was finalized.
many other dealers DO install hitches too. certainly the ones they sell but again that's part of the negotiations...
___________
the pp is somewhat akin to an erector set with only ONE model built from the bits (hopefully )...
___________
it appears that some of the BITS included have changed or been revised over the 2+ years this thing has been on the market...
documenting those changes and variations HERE is a good thing.
i would EXPECT that another OFFICIAL pp install manual will need to be written eventually...
until then (and even after...) keep the reports coming, include ANY issues or personalized mods...
and throw up some pictures too!
in the UNofficial pp users guide....
cheers
2air'
05-05-2010, 04:58 PM
#219
Port Orchard
Tank cover and WD jacks.
This is what I did regarding the interference between WD jack's angle brackets and Tank cover.
On our trailer, the front of the tank was already resting on a couple wire bundles. I killed two birds with one stone by raising the tank cover with 8 stainless steel fender washers. This allowed the rear of the tank cover to rest on the WD jack bars and allowed more clearance for the wire bundles in front.
Regards,
Ken
05-05-2010, 07:09 PM
#220
_
nice ken!
solved 2 issues with one fix.
for those of u UNaware of the tank cover/pinched wire issue...
it's covered in some detail in posts #14, 18, 33, 38 and 40 here...
http://www.airforums.com/forums/f353...tml#post515931
while the wiring on my rig has been RErouted to avoid the 'pinch'
the STACK o'washers will help with the pp jack brackets.
cheers
2air'
