Closed Thread
Old 03-15-2009, 08:44 PM   #785
krlajwvater's Avatar
2003 30' Classic
mount joy , Pennsylvania
correction I meant thread # 772
krlajwvater is offline
Old 03-16-2009, 11:57 AM   #786
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by krlajwvater View Post
robert cross thread # 722 solution to your shin saver. this is a nice way to store stinger when not in use. you can also put a lock for theft purpose.
Looks Good
Ours, stinger carries the flaps...
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
ROBERT CROSS is offline
Old 04-08-2009, 12:58 PM   #787
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Non-Leaking Grease Gun
Even though I always back off the pressure on the grease gun it still leaks grease when stored. I use it, release the pressure, wrap it in plastic bag, and when I go to use it again the thing is almost covered in grease.
I am tired of having to wipe grease off of the gun before I can use it.
Two questions:
What am I doing wrong?
How can I stop the gun from oozing grease?
Does anyone know of a manual grease gun that does not leak grease when not being used?
OK, that was three questions.
SRW
TEXAS66
SRW is offline
Old 04-08-2009, 01:24 PM   #788
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Leaking Grease Gun
This is just maybe an answer to my own question.
I spoke with a rep at Lincoln a maker of most anything having to do with pumping grease.
The rep said that the stuff leaking out of my grease gun was actually water that had separated from the grease, and it was impossible to stop the stuff from leaking.
Most any grease will separate over time - grease in a 50 gallon drum, tub, or a cartridge like those used in a manual grease gun.
He said manual grease guns leak - get over it.
TEXAS66
SRW is offline
Old 04-09-2009, 10:37 AM   #789
Thumbs up
My K-D don't
Amanamus
"Tahawus"
Old 04-18-2009, 07:45 AM   #790
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
I am going to look at or buy a Hensly hitch today. They claim it was used one time and then stored for the last 8 years. What should I be looking for? Is there a list to check to know if it is all there? What would I look for to tell how much whear there may be?
Phil Gobie is offline
Old 04-18-2009, 08:04 AM   #791
Thumbs up
Phil,
If you haven't seen the owner's manual there is a lot of good info here.
http://www.hensleymfg.com/pdf/Hensleymanualmedres.pdf
Ware...Look at the weight bars where they insert into the head, A ware ridge would indicate lack of lubrication. Send Hensley the serial # and they can give the mfg. date.
Good luck, keep us posted.
Amanamus
"Tahawus"
Old 04-18-2009, 08:24 AM   #792
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Thanks Robert, I printed the manual and I will take it with me. I am leaving now to go see it. I wil let you know how it goes.
Phil
Old 04-18-2009, 01:48 PM   #793
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
I got it! Looks like it was barely used. Unfortunately it must have been stored outside for period and it is sun faded and some surface rust. I think I am going to clean up the head, repaint it and see if I can sell it. I was considering using it but I am towing with a Dodge 3500 and using an airsafe hitch. I am afraid the hensley may damage my trailer with my stiff suspension
Old 04-18-2009, 02:26 PM   #794
Thumbs up
Phil,
If you are satisfied with the sway control, the Air Ride is very important with the 3500. Glad you got the Hensley, good luck.
Amanamus
"Tahawus"
Old 04-18-2009, 03:21 PM   #795
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The HAHA serial number will gauge its age. Mine 8332 and was produced in 2006.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is offline
Old 04-18-2009, 04:00 PM   #796
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
The number I see is 04421 I am not sure if that is the right number or not? Is it stamped or imprinted in the steel?
Old 04-18-2009, 07:07 PM   #797
Thumbs up
It's on a label right under the Honey Brown
2007 I tink
ID:	78737   Click image for larger version
Name:	2007 WINTERIZE 001.jpg
Amanamus
"Tahawus"
Old 05-06-2009, 11:56 AM   #798
North Georgetown , Ohio
It really bugged me to have to reset the weight bars every time I gassed up, so.......
This should keep the little buggers from unloading.
Mike44665 is offline
Closed Thread
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 53 08-14-2018 07:04 PM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 01:01 AM
Price guide for site? ViewRVs General Motorhome Topics 7 01-05-2003 12:06 AM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 06:53 AM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 09:33 AM
