Originally Posted by Sean Woodruff
The level of the trailer is more a function of hitch bar offset than of spring bar tension...
as i'm SURE u know...
the above is true when initially selecting a bar, but...
once connected the trailer nose DROPS up to several inches...
depending on the tongue mass, wheel base, payload and tv spring specs and tire pressures.
IF the stinger was adjusted so that the trailer was dead level initially without jack tension,
any w/d force from the spring bars would RAISE the junction ABOVE level...
on these multiaxle trailers tire wear and axle loads vary significantly IF towing an un level trailer...
along with the handling issues of UN-level towing.
for example, now that i've altered the truck rear suspension, a 4 inch bar no longer functions properly....
even though my
trailer IS exactly level based solely on the bar drop....
and with any tension rises at the nose.
the front of my trailer moves 1-3.5 inches UP as i tension the spring bars...
and that correction (which varies by t.v.) is part of the set up too...
an adjustable stinger might make getting the initial set up easier for many owners and the hitch makers...
cheers
2air'
