Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 07-23-2008, 06:17 PM   #603
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Originally Posted by 2airishuman View Post
if you need a parts LIST, it is linked early; in the owners manual and downloadable.
unless a strut or jack breaks, most of us don't have the need for spares...
of course i could contact haha, and tell 'em one of mine broke.
IF 4 of us do that u'd have a set!
if it's a salvage take off u may need the frame mounting brakets too...
brakets, struts and screw jacks...
wouldn't surprise me IF that isn't 600$ o'stuff...
cheers
2air'
I did download (and print) the whole manual.All 37 or so pages' worth, but sometimes it's better to have it in your hand where you can touch and feel it. I don't have to lug my computer around when I look for parts, either, I just whip out page 6 and point to what I want.
Lessee, looks like I need:
frame brackets
2/3 of the jack assemblies
spring bars
1 safety key
strut assemblies
spring bar u-brackets
u-bolts and plates
I think that's everything I can't get at the store.
Old 07-24-2008, 08:30 AM   #604
Hensley Ron
Commercial Vendor
Hensley Ron's Avatar
Profile:  Currently Looking...
Oxford , Michigan
Spring bar u-brackets come with the spring bars. I didn't see the hitch bar mentioned. Did you get the right size? Give Jarrod a call at x103 and he can walk through the parts with you. No pressure to buy anything, but we want to make sure you're getting the right parts and safe.
Ron Estrada
Hensley Mfg., Inc.
Hensley Ron is offline   Reply With Quote
Old 07-24-2008, 05:45 PM   #605
overlander63
Rivet Masher
L.A. , California
Thanks, Ron, I'll give a call as soon as I have a chance during business hours. The hitch bar is the correct drop. I installed the Big Orange Part at work, on the level concrete floor, and floor to top of ball is 19", nearly perfect. Serial # is 06864.
There's an SOB about two sites over with a HAHA (it's worth more than the trailer) that's permanently moored, I can go take measurements for holes under cover of darkness, so I have a visual aid.
Old 07-25-2008, 09:32 PM   #606
millvalleyca
millvalleyca's Avatar
Profile:  2008 27' International CCD FB
Mill Valley , California
do I need a 4" drop?
Hi guys
We just got back from our 2,000 mile Grand Canyon trip.
The HAHA performed as advertised!
I think I may have to trade my 6" drop for a 4". I hope you can tell from my pictures.
The picture on the right looks like my front end is tipping (the ground seemed to be pretty level)
The left picture shows the trailer after I used the jack to "level" the trailer...about 2". It lifted the back of the truck up too because I didn't unhitch.
What do you think? Do I need a 4" drop or is it about as level as it's gonna get?
The other question I have has to do with the tension bar...I have it on the "first line from the top" I tried it on the "middle line" and it felt a bit stiffer....never tried the "bottom line" because I feel uncomfortable apply so much tention to the weight distribution bars.
Does this have anything to do with "leveling the trailer?"
Your comments are greatly appreciated!
Dennis
Name:	Grand Canyon 002.jpg
ID:	64486   Click image for larger version
millvalleyca is offline   Reply With Quote
Old 07-25-2008, 09:42 PM   #607
dpandorf
dpandorf's Avatar
Profile:  2000 34' Limited
Somewhere in Western , North Carolina
Originally Posted by millvalleyca View Post
Hi guys
Dennis
Hi Dennis, looks like we have the same truck and have been towing our trailer with the 2" drop and don't think that is enough. Just received the 4" drop and will break it in 2 weeks as we head out on a 13 week trip to the NW. I think the 6" drop is a little too much.
I moved my tension bar to the middle notch from the bottom notch.
Duane
Air# 16888
2000 34' Limited
2008 F250 Powerstroke
Hensley Hitch
dpandorf is offline   Reply With Quote
Old 07-25-2008, 10:03 PM   #608
millvalleyca
Hi Duane
Don't you just love your truck! I think the best thing are the mirrors!
Does it make a difference that your trailer is 34' vs my 27'?
Was the nose of your trailer sticking up at 2"?
Dennis
Old 07-25-2008, 11:02 PM   #609
dpandorf
dpandorf's Avatar
Hi Duane
Dennis
My nose sticks up with the 2" and that's why I finally ordered the 4" drop. Just had my truck serviced today for our 13 week road trip. About to turn over 20k and had the oil, fuel filters and tires rotated.
I was feeling pretty good when the service rep went over the brake check as part of the tire rotation. "Brake pads are like new!" So I guess I've been babying the thing.
Duane
Air# 16888
2000 34' Limited
Hensley Hitch
Old 07-25-2008, 11:12 PM   #610
2airishuman
2airishuman's Avatar
Profile:
...The picture on the right looks like my front end is tipping (the ground seemed to be pretty level)
The other question I have has to do with the tension bar... I feel uncomfortable apply so much tention to the weight distribution bars...Does this have anything to do with "leveling the trailer?"
hi millva'
in R side pic, the trailer nose is LOW and the truck tail is LOW too...
this suggests that the spring bars are UNDER TENSIONED, and should be tensioned MORE....
here is a quick "leveling" primer...
1. part the trailer on VERY LEVEL ground with enough level space for the tv too...
2. adjust the tongue jack until the trailer is VERY LEVEL. use a LEVEL and record the trailer HEIGHT ft/bk...
...at the beltline or some other specific marker on the trailer.
3. back the LOADED tv (with stinger) up to within 1 inch of docking with the trailer, but don't hook up...
4. MEASURE the truck stance (height at wheel wells) at all corners
5. adjust the haha so it is LEVEL like the trailer (us the screw jacks 4 this) so the stinger and haha are parallel to each other.
....they still aren't at the same HEIGHT (stinger and haha), but should be parallel...
6. note the DIFFERENCE between the haha box and stinger height
7. IF the difference is more than 3 inches, u will likely need MORE DROP on the stinger...
8. IF the stinger is level with the box or +1 to -2 inches different it should work.
9. now adjust the tongue jack to allow docking.
10. back in and hook up, and RETRACT the trailer tongue jack completely with NO tension on the spring bars.
.....the connected units should look like or RIGHT picture at this point (low at the hitch)...
11. tighten the spring bars until the trailer is LEVEL AGAIN, use a level AND see the measurements in #2
12. now check the truck stance again (see #4) ideally the entire truck is lower about the same at each corner...
13. the truck MIGHT still be lower at the rear (depends on cargo, payload and truck springs)
14. don't forget ALL the tires tv/trailer should be properly inflated and the truck LOADED when doing this...
____________________________________
15. take the entire rig to a SCALE and get weights....
16. based on measurements like these (see post #1 in thread below) u may need to tighten the jacks MORE...
http://www.airforums.com/forums/f238...ers-17984.html
__________________________________________
IF FULL TENSION on the spring bars doesn't result in good axle loads or RAISES the trailer tongue much above level..
u might need a longer drop stinger.
don't worry about FULLY raising the jacks to creat MAX tension on the bars...
they won't break, even if tightened PAST full tension (they just keep flexing)
IF u are leaving "2 holes showing" at the bottom of the jacks,
ideal tension will very likely be at the "2nd mark" +/- a 1/2 inch
so start on a LEVEL SURFACE, MEASURE heights, GET THE TRAILER LEVEL...
after doing all this the truck may still be a tad low in the rear, depending on tongue mass and payload...
hope the steps help, u might wanna print this out.
there are others ways to get to level but this is a methodical approach to the set up...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 07-26-2008, 12:19 AM   #611
millvalleyca
Hi 2air
I was waiting for your response!
I will take the measurements the next time out.
Unfortunately I have the most uneven driveway.
The info on your Cat scale thread is amazing...I'm gonna have to read the whole thread.
Right now I need your gut instinct!
I can't believe you can tell so much from a single picture.....I noticed the back end being lower than the front end when we stopped for lunch today.
Knowing my tow vehicle and trailer should the 6" drop bar be the right size?
I just went outside to look at my hitch and noticed that there are three holes showing at the bottom of the hitch.
The dealer set my hitch up...should I change it to two holes?
Will (should) changing the holes showing and maximizing the tension on the tension bars get me more level?
Boy....it sure is tough being the ultimate newbie.
Thanks again for the info!
Dennis
Old 07-26-2008, 01:03 AM   #612
2airishuman
Profile:
...Unfortunately I have the most uneven driveway.
Will (should) changing the holes showing and maximizing the tension on the tension bars get me more level?...
yeah driveways are NOT great for this.
that rv slot in your LEFT pic would be a good place or a level parking lot or a diesel filling station...
JUST GUESSING, i suspect 4" is right, but it all depends on tongue mass and how high the truck receiver box is...
these fords vary some based on tire/wheel size, 4x4, off road package and so on...
go back to post 128-140 for a review of the stinger length topic.
"3 holes showing" is the standard setup i think, see pages 15 and 19? in the haha owners manual...
just to be clear we're on the same page about the holes, see the pic lower pics here for 2 holes...
http://www.airforums.com/forums/299428-post63.html
http://www.airforums.com/forums/370909-post214.html
and here for 3 holes...
http://www.airforums.com/forums/362490-post202.html
you'll need to ZOOM those pics to see well.
YES, reducing the number of holes showing INCREASES the spring bar tension at a given mark...
think about it, more holes exposed means the jacks are LONGER,
while few holes SHORTENS the jacks.
the point being that once tightened to the 1st or 2nd mark tension will vary,
based on screw jack LENGTH, and this length is based on the 'number of holes' showing...
does that make sense?
3 is fine IF u can get enough tension to raise the trailer to LEVEL and have good wt distribution on the axles.
2 holes increases the tension at each mark.
the manual emphasizes a MINIMUM of 2 holes must be exposed.
what spring bar rating do you have? i'm assuming 1,000 lb bars.
a 4 inch drop should work, but really it depends on all the variables we've covered.
the goals are...
1. get the trailer level as the primary thing.
2. have the truck 'close' to level, but
3. ideally base the truck posture on axle loads and driver feedback at each setting...
if and when u do get some scale readings be sure to post them in the cat scale thread!
...I noticed the back end being lower than the front end when we stopped for lunch today...
my interpretation of this is, the TRUCK back was low and the TRUCK front was high?
that's how it looks in your RIGHT picture.
cheers
2air'
Old 07-26-2008, 09:05 AM   #613
Hensley Ron
Commercial Vendor
Oxford , Michigan
That looks fairly level, but it's hard to tell with a photo. Measure it like the guys say. If it's more than an inch off, you may consider a new hitch bar. Airstream's typically have "B" couplers, so three holes is good. Taking it to two holes won't make much difference in weight distribution and may actually make it more difficult to release all the tension for unhooking, though I've experimented with both and found nothing gained and nothing lost. Of course, My tongue weight is so heavy it's tough to say.
By the way, thanks again for this great thread. I get quite a few orders based on what someone has read here. Nice lookin' rig there, millvalley. I'd love to get my family out to that part of the country. I've seen it all already (Navy brat), but my kids haven't been farther west than Indiana.
God bless.
Ron Estrada
Hensley Mfg., Inc.
Old 07-26-2008, 10:36 AM   #614
millvalleyca
Thanks for the input guys.
The height of the receiver box is 19 inches at the top. (engine running on level ground)
There are three holes showing.
1000 lb bars.
If I raise the bar so that 2 holes are showing and tighten the tension to the middle line.....it will make a difference? Can it make a big difference in leveling the trailer?
Thanks!
Old 07-26-2008, 03:45 PM   #615
2airishuman
Profile:
...If I raise the bar so that 2 holes are showing and tighten the tension to the middle line.....it will make a difference? Can it make a big difference in leveling the trailer?...
basically going from 3 to 2 holes SHORTENS the screw jacks ~1 inch.
IF you can get to level and have good axle loads on the tow vehicle with 3 holes showing there is no need to change it.
IF u run out of room/shaft length, tightening the jacks (pulled up past the 1st mark) going to 2 holes may help...
for any given mark on the upper jacks 2 holes will have MORE tension than 3 holes for a given w/d bar rating.
the important things are,
1. get the trailer LEVEL and
2. properly redistribute axle loads on the tv...
The height of the receiver box is 19 inches at the top...
at 19.5 for this measurement, on my f-250, the 4 inch drop worked fine.
cheers
2air'
Old 07-26-2008, 04:45 PM   #616
Sean Woodruff
Commercial Vendor
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
The level of the trailer is more a function of hitch bar offset than of spring bar tension.
You could just drop/raise the hitch bar a bolt hole.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Sean Woodruff is offline   Reply With Quote
