Originally Posted by finalcutjoe
...can't I bump that connection with the spring bar up to the top hole, and crank the spring bar up to get MAXIMUM leverage?
hi fc'
clearly there is a mechanical/clearance issue that has been addressed by sean...
DO NOT USE THE FIRST HOLE or it will rub in turns and backing.
but the bigger issue is
WHY r u trying this....
-you do have the
1400 lb bars right?
whatever rated bars u have, the 'useful' flex is just a
few inches...
and cranking them beyond that range
doesn't offer more leverage.
while they shouldn't break, the
added flex doesn't offer anything useful.
with a 30 slide u need the 1400s unless towing with a 1 ton drw...
what drop shank?
if the shank has too much drop, trying to get 'er up to level with the spring bars isn't wise.
many end up with the
wrong drop and try to work around it, usually without success.
how close to LEVEL is the trailer after hookup/
BEFORE jack tension?
-how close to LEVEL is the trailer after hookup/
AFTER jack tension?
-once the trailer is LEVEL, what is the
burb's attitude (relative to unhooked) at the front/rear?
it is very likely (with that trailer/tv combo) that the
burb rear will be LOWER relative to the front...
and MORE BAR TENSION (beyond useful) will NOT solve that issue.
-have u
replaced the
oem receiver with a CLASS V ???
with your hitch weight a higher capacity reciever is really necessary...
-using 1000lb bars the rear suspension on my 3/4 ton slowly fatigued from towing...
this issue could NOT be solved by more jack tension OR changing holes.
i went UP in bar rating to 1400lbs, added a leaf, and changed stringer drop...
all 3 adjustments were needed to get back to ideal positioning AND measured weight distribution...
-have u weighed the set up? especially axle weights while connected?
-lastly why not
POST SOME PICTURES of your combo and the ISSUE that is prompting u to...
use the wrong jack hole...
cheers
2air'
