Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 04-22-2008, 12:33 PM   #547
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by sander17
I have seen the pins with the spring loaded rings at the local TSC (Tractor
Supply Co.)...
hi dave, you are right.
i picked up several of each size spring-rings and pins at the tsc last year, but didn't look for the other bits.
the small parts i'm gonna look 4 are INSIDES for the grease zerks, and an ocl lug and u bolt 4 the frame bracket.
Originally Posted by crispyboy
... two small collars below the self tapping bolts. What purpose do these serve?
crispy, as ron notes those 'locking collars' keep the jacks attached to the frame brackets....
u can see some pix of them in position, in jim clarks' excellent install (post 203) and in breakaways' pic in post #239...
http://www.airforums.com/forums/377720-post239.html
in initially i worried that they would loosen during travel, but have had no issues with them,
but i do still check tightness with the supplied allen wrench.
they've not been an issue, probably because i'm carrying spares.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-23-2008, 08:11 AM   #548
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
Now I know why I didn't know about the collar. The vintage Hensley hitch brackets I have do not have collars but have nuts/threads instead. Here is a picture of the bracket that I have been sandblasting on in preparation of the upcoming paint job.
crispyboy is offline   Reply With Quote
Old 04-23-2008, 11:00 AM   #549
Sean Woodruff
Commercial Vendor
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
Crispy, that is a modified bracket. Just got off the phone with Jim Hensley and they were never designed or made that way. Someone may have had a bent bracket pin and this was the fix.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Sean Woodruff is offline   Reply With Quote
Old 04-23-2008, 12:15 PM   #550
crispyboy
crispyboy's Avatar
I kind of wondered about that because of the el crappo welds that were on the bolt head side. I was surprised something like that would have come from the factory. I ground out the welds that were made by a 5th grader and put some of my own in place.
Thanks for the info.
Moderators - if the last couple of threads on this issue are not relevant to the spirit of the HA HA thread go ahead and delete them.
Old 04-23-2008, 03:21 PM   #551
2airishuman
Profile:
vintage haha archives!
hi crispy...
these are VERY relevant posts and pictures, thanks for adding the info...
my first thought, on seeing the pic early this am, was the jack attachment area had been modified...
so it's good that sean has confirmed this with the MAN!
are they BOTH like this? perhaps at some point they were OVER LOADED via the jacks...
consider replacing the frame brackets with new, i'm sure haha sells them.
given there is a LOT of stress on this area once the jacks are tightened i'd want a solid piece in that location.
cheers
2air'
Old 04-23-2008, 04:09 PM   #552
Hensley Ron
Commercial Vendor
Hensley Ron's Avatar
Profile:  Currently Looking...
Oxford , Michigan
Apparently someone didn't trust the collar. We've never manufatured them that way. If you must pimp your Hensley, please check with the company.
Ron Estrada
Hensley Mfg., Inc.
Hensley Ron is offline   Reply With Quote
Old 04-24-2008, 07:12 AM   #553
crispyboy
crispyboy's Avatar
Both brackets are modified in this fashion. The brackets are in perfect shape otherwise - no dents, bends or cracked welds. I actually like the idea of the shaft being theaded and using a nyloc nut as opposed to the collar since these are less likely to come loose.
Hensley Ron - could this have been an improvement on the original idea? - toss the idea out too your engineers.........
Old 04-24-2008, 10:17 AM   #554
Hensley Ron
Commercial Vendor
Oxford , Michigan
On my list of improvements is the shaft collar. It's posed few problems, but I'd much rather see something that doesn't involve a lock screw. I don't care for threads, though. That would create a different set of problems and add to the cost.
Ron Estrada
Hensley Mfg., Inc.
Old 04-24-2008, 11:54 AM   #555
2airishuman
Profile:
...I actually like the idea of the shaft being theaded and using a nyloc nut as opposed to the collar since these are less likely to come loose...
my uninformed concern would be reducing the strength of the shaft by making it hollow...
again i was concerned the collars might slip over time, but it is one of the few areas that has been issue free...
earlier posts in this thread suggest NOISE can come from the shaft area if not lubed...
YOURS look odd because the paint isn't worn off...
the jacks constantly rotating under load should rub, so again i really wonder about that modification...
Originally Posted by Hensley Ron
On my list of improvements is...
do you have any update or new info on the INADEQUATE chain extension kits ???
cheers
2air'
Old 04-27-2008, 08:27 PM   #556
Pete Vermont
Profile:  2007 22' International CCD
Tunbridge , Vermont
HENSLEY Hitch & 2007 TAHOE w/in bumper 2x2 Receiver ? ?
I just picked up my new 2007 22 ft Airstream ordered with a Hensley Arrow hitch as a result of comments on this BB. However, I can't get the trailer leveled because I have the 8-inch drop tow bar and it is still too high as my vehicle is a 2007 Chevy Tahoe with the factory-made "in the bumpert" 2x2 receiver.
SOMEBODY else must have come across this problem and found a solution.
Has anybody seen any info about how to adapt? The hitch receiver is about 5 inches higher than one that would be BELOW the rear bumper (or plastic, imitation body trim thingy)?
Pete In Vermont
Pete in Vermont
AIR 26504
WBCCI 2980
2007 22 ft International CCD
2007 Tahoe 4X4
Hensley Arrow
[prior AS: 1986 Excella 32 ft ]
Whoever said "Money can't buy happiness" never owned a custom made bamboo fly rod.
Pete Vermont is offline   Reply With Quote
Old 04-27-2008, 09:25 PM   #557
2airishuman
Profile:
hi pete
have u got any photos or the equipment or connection?
what is the measured height from top/inside the receiver box to the ground on level ground?
i'm aware of the bumper fascia/built-in receiver issues on the new yuks/burbons...
-first it isn't considered very strong or tight relative to the stinger...
and locating aftermarket replacements is apparently an issue...
here is a thread u might post in about a proper replacement receiver for the suv...
see post #11, 19-22, 26-28...
or u might pm uwe about his...
some of the folks towing with hummers also have this issue and apprently just tow with the nose UP...
doing so shouldn't affect the haha performance, but will be a negative on tire wear and perhaps axle fatigue...
i HAVE seen custom made receivers that have the 2 inch box placed LOWER,
but that may require cutting or modifying the bumper fascia...
cheers
2air'
on edit i see u started a thread SPECIFIC to this receiver issue, GREAT IDEA,
http://www.airforums.com/forums/f464...ver-41577.html
hopefully u will get some replies in your new thread...
Old 05-13-2008, 04:34 PM   #558
Whizzo
Whizzo's Avatar
Profile:  2008 22' Safari
Helotes , Texas
Images: 12
Awesome Thread
This is the most helpful thread I've read on any RV group.
Like many folks here, I became a HAHA fan pretty quickly. My SOB (26 ft) was about 3 ft longer than recommended for the medium-sized TV, so the Hensley padded the margin a bit. Now with the new 22 ft, some would argue the HA is overkill - I disagree of course. We've seen the ocassional HAHA-ed Bambi on the road.
The dealer tech was new to the HAHA, and missed a couple of things: the strut rears were not mounted in the right holes to parallel the A-frame, and the struts themsleves were not tightened properly. I didn't discover this until until I got home from an 80 mile shakeout tow, and even then, she pulled beautifully.
Still, can't get her quite level. We go TT nose high with very little tension, well before the first jack marker. My TV is a 4WD, so it sits a bit high for an Explorer. After a quick discussion, the fine folks in Michigan are shipping me an 8" drop to replace the 6". I think that and a little tweaking, and we'll be back to the superfine towing experience.
2008 Safari Sport 22
2003 Ford Explorer NBX, 4.6L, 3.73
Hensley Arrow Hitch, McKesh Mirrors
Whizzo is offline   Reply With Quote
Old 05-22-2008, 11:01 PM   #559
millvalleyca
millvalleyca's Avatar
Profile:  2008 27' International CCD FB
Mill Valley , California
Hi guys...
A little help with my haha please......
I get to step 7 in the hook-up procedure.
Everything appears to be lined up.
I back into the hitch box and the darn thing shifts to the left or right.
Can I back the hitch bar into the opening and be "somewhat aggressive" when this happens or will this damage my haha. (if the hitch box is not centered)
I've been at this for over an hour now and it's getting dark outside
I guess I'll have to try it again in the morning
Dennis
millvalleyca is offline   Reply With Quote
Old 05-22-2008, 11:27 PM   #560
Sean Woodruff
Commercial Vendor
Dennis,
Once the hitch bar sticks in the hitch box go back to your spring bars to see which one is tightened up. Maybe both. Adjust your jacks until the spring bars are sloppy again and that will adjust the hitch head on the hitch bar. Once they are loose continue to back into the hitch the rest of the way.
Whenever the hitch bar sticks in the hitch head you can always go to your spring bars and you will notice one or both are tight again. That is the hitch bar pushing the inside of the box and making them tight. Just adjust the jacks to make the bars loose again and it will take the pressure off the hitch box and allow you to hitch up. You don't need to continue pulling out and trying to line everything up and then trying to go back in. This is also necessary anytime you adjust the tongue jack when the bar is part of the way in the box. Always adjust the spring bar jacks as the last step anytime you raise or lower the tongue jack.
Another note is that when you get the wedges about 1/2 to 3/4 buried in the opening you can use your over-center-latches to pull the hitch bar back into the box.
ProPride, Inc.
800-960-4767
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 35 07-27-2008 11:38 PM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 01:01 AM
Price guide for site? 1985air345 General Motorhome Topics 7 01-05-2003 12:06 AM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 06:53 AM
