Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 03-04-2008, 10:21 PM   #491
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by SRW
Ok, now what?...?
hi srw
page 14 of the haha installation manual covers the zerks...
the installation manual is linked as a pdf file here is post #7.
here is my version...
1. loosen the jacks until they are 'sloppy loose'
2. disconnect 1 spring bar from the jack assembles (pull the spring pins)
3. swing 1 spring bar wide and forward toward the tow vehicle.
4. the spring bar SHOULD slide down and out of the bushing now; if it doesn't continue to step 5/6 while SUPPORTING the spring bar.
5. loosen the 'lock nut' on the grease zerk
6. unscrew the zerk.
7. inspect zerk for wear/damage and test the tip/spring mechanism
8. replace zerk, screw in just far enough that the inner nipple is a few mm inside the bushing.
....a long finger inserted into the bushing will feel inner zerk tip.
9. tighten the lock nut, while holding the zerk stationary.
10. liberally grease the spring bar head and
11. with the spring bar rotated forward insert it into the bushing and push UP
12. rotate the spring bar wide and backward toward the trailer/tongue
13. reconnect to the lower jack extension and replace the spring pin.
basically that's the process
IF the zerk is OVER inserted the spring bar will not fit completely up inside the bushing or will not rotate back.
IF the zerk is UNDER inserted the spring bar will fall out.
look back at the pix around post #90, there is a groove in the spring bar, where the inner zerk tip fits.
this is pretty straight forward. take a look at the diagram on page 14 in the installation manual.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-04-2008, 10:32 PM   #492
SRW
SRW's Avatar
Profile:  2008 28' International CCD
Georgetown , Texas
Thumbs up Terrific Help
Originally Posted by 2airishuman
........this is pretty straight forward. take a look at the diagram on page 14 in the installation manual.
cheers
2air'
2Air:
Can't say how much I appreciate your willingness to help, not to mention that the quality of the information you have provided is outstanding.
I will let you know how it goes.
SRW
SRW is offline   Reply With Quote
Old 03-05-2008, 08:54 AM   #493
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
I have a grease gun that is one-handed for pumping, and that I strongly recommend along with a swivel or two. This makes for much easier work when the second hand has to hold the tip onto the zerk (or, when one is using a needle tip, etc)
NAPA Item#: BK 7151230
I prefer a long fiber grease, and use SCHAEFFERS #268
As to electric drills, the Weatherford, TX A/S dealer told me that they get a full years use out of a RYOBI used and abused daily. I picked up one (18V) with flashlight, charger, case, etc for around $70.
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 140,000 miles.
19 city/22 mpg solo (62 mph/1850 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://www.tompatterson.com/Silverst...1983/19831.php
Rig is 15,700#; 15 mpg at 62 mph
REDNAX is offline   Reply With Quote
Old 03-12-2008, 08:07 PM   #494
SRW
SRW's Avatar
Georgetown , Texas
Drum Brakes vs Disc
Any thoughts on changing drum brakes to disc?
My 28' International has elec. drum and they can be replaced with hydraulic disc brakes.
Friends have converted theirs and felt the results are worth it.
Also, when making a brake change larger rims could be installed and Michelin tires used.
Not cheap though.
Old 03-12-2008, 09:28 PM   #495
2airishuman
Profile:
haha only spoken here...
Any thoughts on changing drum brakes to disc?...
please lets not get into the tire size issue in a hitch thread. there is a section JUST on wheels/tires.
the disc breaks work great and are also well covered...
Disc Brakes?...2005 Classic Limited w/Slide
http://www.airforums.com/forums/f439...kes-29208.html
http://www.airforums.com/forums/f439...ler-31649.html
Disc vs Drum Brakes?
disc vs drum brakes
so read these or search IN the brake/brake controller sub forums...
and IF you ask a disc brake question in ANY of those theads, i'm sure the replies will roll on in.
NOW on the haha srw....
did you get that ONE zerk changed? was it ground down? got any pictures?
cheer
2air'
Old 03-12-2008, 10:34 PM   #496
TROPHYJIM2
Profile:  2008 31' Classic
Sweet Valley , Pennsylvania
Propride (new haha) update
Contact with Sean today and all parts and materials are in house , he is in production with the new Hensley Design at this time. I e-mailed him to ask if the Rock Tamers would fit with this new design in that I know others here had to make adjustments with the Arrow to fit with the RTs
Sean called me and indicated he had just spoken with the Enkay folks and is making sure the fit will be correct since he believes many of the users of his new hitch will also be users of the RTs. Weird, but Sean was on the phone with Enkay when he got my e-mail and just had to call me to tell me how strange it was that I had e-mailed him at that exact time about the RT's
TROPHYJIM2 is offline   Reply With Quote
Old 03-12-2008, 10:42 PM   #497
2airishuman
Profile:
but THIS isn't the propride thread either...
HERE it is for now...
http://www.airforums.com/forums/f464...ach-37994.html
while the design concepts are common, ALL of the bits are different.
once we've got some of the other hitch in hand, USERS will have another thread for the other hitch...
i really don't wanna see THIS thread degraded into bullcrap discussions about theory, cost, comparisons and so on...
imo the VALUE of this thread is that NONE of that nonsense is posted here.
mostly it's about USER TIPS and tricks specific to ONE PRODUCT...
IF we have to wade through other hitches and other topics to find the haha stuff...
well, it might as well become a game thread.
there are 20 other threads on hensleys FULL of arguements and useless sidetracks...
any of those threads would be a wonderful place for NON OWNERS to battle with MAYBE OWNERS...
take a LOOK at the hitch subforum and just throw a dart...
http://www.airforums.com/forums/f464...esc&sort=views
cheers
2air'
Old 03-13-2008, 05:04 PM   #498
SRW
SRW's Avatar
Georgetown , Texas
cheer
2air'
2Air:
I did get the nonfunctioning zerk replaced.
Using your direction as a guide, I removed the spring bar.
After I removed the spring bar I could feel that the inside "nib" of the zerk was worn and would no longer depress.
Also, the zerk would not unscrew, hanging up about halfway removed, probably due to the damaged threads.
Score Zerks 14; SRW 7.
I spoke with a Tech at Hensley and screwed a second nut on the zerk's barrel and tightened the two nuts together. Putting the wrench on the inside nut it then unscrewed relatively easily.
Reassembled and regreased, no problem. The spring bar snapped right in with the zerk poking about 3/8" into the spring bar's hole.
Final score Zerks 14; SRW 21.
Thanks for the help.
Name:	Zerk 3_13_2008_1007.jpg
ID:	56177   Click image for larger version
Old 03-13-2008, 07:01 PM   #499
2airishuman
Profile:
nice pix!
...Final score Zerks 14; SRW 21...
alright, we've got a victory here!
good 4 you!
that '2nd nut/lock nut trick is handy and good stuff for the user guide.
i would have probably just grabbed the vice grips, or a hammer!
the zerk has a smallhexed surface that can be used but might not be enough bite, for tough removals.
now you should have easy greasin' ahead...
and don't skimp on the grease!
cheers
2air'
Old 03-24-2008, 08:15 PM   #500
Rob30044
Profile:  Exeter , Rhode Island
Zerk fittings
Where can I purchase zerk fittings? I know I can get them from Hensley, but I have not been able to find them locally.
Rob30044 is offline   Reply With Quote
Old 03-24-2008, 08:22 PM   #501
Sean Woodruff
Commercial Vendor
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
If you want the complete assembly you'll have to get them from the haha company.
If you want to make your own you can buy a spring plunger and a grease zerk from someplace like www.McMaster.com
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Sean Woodruff is offline   Reply With Quote
Old 03-25-2008, 09:20 AM   #502
REDNAX
The "spares" package from Hensley is a good idea, as is a dedicated box for all tools and supplies and copies of information to be kept in one place. I bought new tools for the trailer to be able to keep them all in one place (those tools that are used often). The hitch deserves no less, and makes any work simple and quick.
Old 03-25-2008, 06:51 PM   #503
Rob30044
I went to the Hensley website and noticed they sell a Hensley Arrow Emergency Kit, but no description as to what's in the kit.
Old 03-25-2008, 07:01 PM   #504
Sean Woodruff
Commercial Vendor
It contains a couple strut clevis pins, jack clevis pins, shear bolts, a jack collar and a grease fitting.
ProPride, Inc.
800-960-4767
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 35 07-27-2008 11:38 PM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 01:01 AM
Price guide for site? 1985air345 General Motorhome Topics 7 01-05-2003 12:06 AM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 06:53 AM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 09:33 AM
