Originally Posted by millvalleyca
...We finally got the HAHA installed yesterday!:...Now for the questions
...I tried to tighten the jack assembly to the "middle line" ...First line ok?
...mine is almost vertical. ok?
...can you bend it too much?
...there are 3 holes open on the spring bar link. Is this right for my trailer and tv?...
hi millva' and congrats on the install and maiden trip in the haha zone...
no mention of hookup/disconnect...this must have gone well?
my understanding as to your questions, and based on having the correct drop stinger...
---3 holes is ok, i've got 2 open holes exposed, and the spring bar attached to last hole.
too many holes exposed will required further tightening of jacks for adequate tension...
---level is certainly ok for the main body; might be the ideal position under tension.
---the bars won't break under maximum flexion, but after reaching the "rating' additional flex doesn't transfer more mass...
---which 'line' depends on # of holes exposed and amount of weight transfer needed...
---you'll need to measure steering/drive axle weights on your tv for the most precise setting...
BUT using a tape measure to level the trailer and restore tv attitude can get ya pretty close...
here is my early experience with the process, the first 40 or so posts may be useful 4 u ...
http://www.airforums.com/forums/f238...ers-17984.html
IF you have weight distribution, tow vehicle/trailer adjustment questions (which apply to all w/d hitches) please add your questions/results to that thread!
good to read the towing in the rain was uneventfull too!
cheers
2air'
