Originally Posted by bernermom
We have had major problems hooking up the HAHA....
If someone can offer some shortcuts to what we need (2Air  ) I would really appreciate it...Thanks Diane
hi diane
hooking up and disconnecting is a finesse thing not a 'force it' thing...
and the can can be VERY frustrating.
a good HOOKUP actually begins with a smooth disconnect.
in other words IF unhooking is difficult (trailer drags or drops off the stinger)...
the NEXT hookup will be a bear too, because the alignment or height were off already.
does that make sense?
as other users are reporting we've ALL had some frustrating moments with this, but once we finally understand it gets MUCH MUCH easier....
here are the helpful posts...
go back and look at the photos and comments in posts#
29-35, 203, and 215.
the info in posts
176-178 and
197-199 and
209-216 are also useful, so read them.
now IF you've taken some photos PLEASE
post them here so we can visualize your install and the hook up issues...
i'm not clear what u mean by LOOSE.
if it these means the 'hitch is loose' from the frame it will flop all around and that's not good,
don't loosen the hitch 2 trailer connections or strut bars to hook up
IF you mean the
jacks are loose that right, but only up to a point.
i don't agree that the jacks should be sloppy loose for every hookup/disconnect
the jacks really need to be 'loose enough' not to bind, but they also need to be adjusted properly to align the square hole and stinger....
by adjusting (tightening/loosening) one jack or the other the hole changes positions....
add in adjustments to the trailer TONGUE JACK for height...
so the goal is to position the hole to match the position of the stinger tip...
moving the tow vehicle around until it's reasonably straight/inline with the trailer is important but will only get ya so far...
then as the screw jacks on the haha are adjusted the opening moves...
up/down,
right/left,
tilts uphill/down hill and
rotates clock/counterclock wise...
in other words adjusting the jacks moves the haha opening and female channel in ALL directions!
this isn't obvious without the hitching rods or the stinger projecting OUT of the box...
it is also important (especially when just learning) to have the haha box in the CENTER position for all hookups...
we can get hitched with the haha in either of the side slots,
but it's much harder when just learning, so
move the haha box to the center slot before ALL hookups.
also i agree with what the other users are reporting, IF you get within 1-2 inches,
you can
PULL the two 2gether with the over center latches and the wrench...
again go back and LOOK at the posts i've listed, study the pictures and post some of your own...
YES you can call the haha 800 number and someone will help ya from the company, or you can call sean...
but then we
users wouldn't be
helping EACH OTHER, which
is one of the goals of this thread....
keep asking here we won't let ya down, and the results ARE worth it...
cheers
2air'
and as mentioned early a good next hook up begins with an easy disconnect.
just loosening the jacks isn't enough,
the a/s tongue jack has to be at the proper height
to release tension in the hitch and that is a common issue in the beginning/learning process.
many folks get so frustrated and worried about this process that once un hooked or hooked up they avoid doing it again...
my suggestion is practice hooking and un hooking several times all together. it really advances the learning curve.
un hook on a really flat open space, take the van for a 'loop' and reconnect. then disconnect and repeat, there is no need to move the trailer for this....
