Closed Thread
Old 10-01-2007, 10:20 PM   #309
_
Originally Posted by tin sista
So watcha think about a pink hensely hitch??
I LIKE IT!
dat be cool....
how about rainbow? or tie dye?
or beads and rhinestones!
seriously any fun color would be neat but go for durable too...
i've considered something like rhino or linex spray coatings, rough and tough!
be sure to take pictures of the facelift 'sista!
2airishuman is offline
Old 10-02-2007, 08:10 PM   #310
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
After reading the all thread and 1,000 miles with the new AS and Haha I checked it to see how it was doing. I had to tight the trust as they were a little loose... I'll go tomorrow to buy a grease gun as I am already late for the service. What kind of grease should I get?
And I think to order soon a kit from hensley not to be short in case of problem. I am heading to Vancouver and I am right now in Winnipeg.
That's quite a drive and I want to be all set to take care of the haha.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline
Old 10-02-2007, 09:01 PM   #311
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Grease That Haha
GREASE...Any good quality automotive chassis grease will work just fine.
I'd recommend a standard size hand grease gun, the one with the pistol
grip handle and rubber hose is easier to use.
As far as the parts kit goes, I did get one from Hensley, I talked them
into including it with the purchase, but you could get most, if not all the
various pins, clips and retainers at any good Home Store...Home Depot
Lowes etc. I'm not sure, but I think Hensley gets $29.95 or so for the
kit. Any good RV supply store like ,Camping World should Have the
zirk grease fitting, there was only one included with kit that Hensley sent.
Good luck on your up-coming trip........Stream safe!!!
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
ROBERT CROSS is offline
Old 10-02-2007, 10:08 PM   #312
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Wink Get yer head on straight!
Originally Posted by hookedonclassic
I took my HA off this summer to lubricate ball etc. Since then I notice that my TV wants to pull to the right when I hit the TV brakes hard. ... Anyone run into that issue. HA looks like it mounted squarely to the trailer.
I had that issue. I'll bet that when you put the Hensley back on you didn't get it perfectly straight. Eyeballing it isn't good enough, I've found. Just one turn on the strut bars can misalign the head enough to cause this issue.
I'm not sure of the factory-recommended procedure, but I cured it by finding a flat straight stretch of road, and repeatedly braking to test the adjustment. After each stop I'd twist both strut bars evenly, 1/4 turn at a time. After 30 minutes of trial-and-error I got it to where I could hit the brakes at highway speeds with hands off the steering wheel and get a straight stop every time (on level ground). Make sure when you're done that both strut bars are tight.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline
Old 10-02-2007, 10:18 PM   #313
Braking Straight
Originally Posted by rluhr
1/4 turn at a time.
I assume, loosening one and tightening the opposite.
PFC
"Tahawus"
RLC
John Prine
Old 10-02-2007, 10:36 PM   #314
_
well richL is definitely correct about adjusting the struts to straighten it...
the haha comes with 2 small reflective tabs/squares on top...
and these 2 'marks' are used in the alignment process...
it may be necessary, in loosen one side (rc) while tightening the other...
but IF one sticks to 1/4 turns only and makes several stops to adjust,
loosening the opposite side isn't usually needed.
just DON'T OVER TIGHTEN the struts
and always check it on a very straight section of roadway...
i usually touch the brake controller just as it rolls to a stop to pull the trailer back/into alignment.
cheers
2air'
Old 10-03-2007, 03:09 PM   #315
Thumbs down NOTICE ANY DIFFERENCE?? (mistake)
OPPS
2AIR, I CAN'T BELIEVE YOU DIDN'T CATCH ME ON THIS.
MUST HAVE BEEN THAT ONE BEER!!!!!!
ID:	46497   Click image for larger version
PFC
"Tahawus"
RLC
John Prine
Old 10-03-2007, 07:43 PM   #316
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
Originally Posted by ROBERT CROSS
OPPS
Yep, the jacks are backwards in one.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline
Old 10-03-2007, 09:02 PM   #317
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
And the struts are pinned in different holes curb side is in the center driver in the bottom.
The torque on the curb side front ubolt bolt is incorrect.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline
Old 10-03-2007, 10:00 PM   #318
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Now that would make perfect sense to me because I did have to adjust the strut bars when I put them them back on. And they could be off just enough to make it pull to the right. Any guess which way it needs to be adjusted since it pulls to the right when I brake. My first guess would be the right side is shorter and the left side is longer now. Opinions?
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline
Old 10-03-2007, 11:40 PM   #319
_
OPPS
too funny...
yep i was too busy looking at the beer bottle brand...
it takes a village...
in haha land.
cheers
2air'
Old 10-04-2007, 01:56 PM   #320
Thumbs down U-bolts And Struts
As a matter of fact..the u-bolts arn't torqued at all, maybe some others
have had the same problem. Was tightening them in stages, at 45ft/lbs
three of the lock washers split...off to Home Depot for stainless replacements
2air mentioned that in the original pic's the strut bars weren't quite
parrallel, down to the third hole he said.
Quess I hadn't done both sides when
I took the pic.
PFC
"Tahawus"
RLC
John Prine
Old 10-07-2007, 11:40 PM   #321
Thumbs up Haha Shakedown, Letchworth St Park
Well the first haha trip is in the books. Started well and ended even
better.
With the cargo doors of the Burb about a foot further away
we can now hook-up with them open. Using the Hitch'n Rods from
Camping World made it a back up 3 time experience.
Used a nearby vacant parking lot to get used to the different driving
techniques, and to take the four corner measurements for the wd bars.
Ended up at the center mark on the jack bar with three holes showing.
The Burb only needed a little over a one inch shift to the front axle on
a 50/50 split. With no wd we dropped from 36" to 34" measured at the
rear wheel wells. Tried several different settings on the drive home, but
the original seemed to be the most comfortable ride.
Used the NYS Thruway to Letchworth St. Park and the two lane country
roads on the way home. It was simply the BEST DAMN Stream ride I have
ever taken. It is just so nice to see that AS stay right behind the Burb.
Even on the exit ramps you'd look in the rv mirror and you still couldn't
see your rear clearance lights. Absolutely no sway at all, and the most
comfortable tv ride ever. Can't wait for the first "real" trip, 250mi just
not enough
Take a close look at my "one trip" main assembly. If thats powder
coat I'll eat your shirt, will need some attention over the winter for sure.
What do you all think an the wd bar deflection, looks a bit more than
two inches to me, but the ride was so good I always returned to that
setting!! Been Stream'n for 18 yrs, and I feel this has been THE
best Investment I have made, both for safety and comfort.
THE FRANTIC BANANA RIDES AGAIN
Name:	HAHA SHAKEDOWN 007.jpg
ID:	46712   Click image for larger version
Name:	HAHA SHAKEDOWN 015.jpg
Name:	HAHA SHAKEDOWN 024.jpg
ID:	46714   Click image for larger version
Name:	HAHA SHAKEDOWN 008.jpg
Name:	HAHA SHAKEDOWN 019.jpg
PFC
"Tahawus"
RLC
John Prine
Old 10-08-2007, 12:13 AM   #322
_
hi robert...
nice looking rig, pooch and mate!
good report. it IS quite the tow, that's for sure.
looks like you coated the U-bolts too?
nice.
the trailer nose looks a tad high, but on grass and in a pic that's only a guess.
did you measure the trailer for level as well as the burb?
you didn't mention brakes...
the haha/trailer should NOT push the tv at all when braking.
some have had to boost the controller to address this.
as to the crappy paint, it might be useful to apply 3-4 coats of automotive clearcoat.
it will reduce the orange fade significantly.
doubt it will help with chipping.
cheers
2air'
Closed Thread
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 12:01 AM
Price guide for site? ViewRVs General Motorhome Topics 7 01-04-2003 11:06 PM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 05:53 AM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
