hi gstephens...
your 'leveling info is in post 129; i don't recall seeing weights...
here is the thread were i reported on weighing and adjusting my set up...
http://www.airforums.com/forums/f238...ers-17984.html
my goal was 50/50 mass on the tv axles, and i came pretty close...
wow 10,000 miles, what a trip!
are you still using the 6 inch drop stinger?
wearing out the rear tv tires faster than the fronts is usually a sign of TOO LITTLE weight transfer....
so if this were my issue i'd want an accurate rear axle weight...
reducing tire pressure won't reduce wear from my understanding...
except on 'center treads'...
is it possible you've added significant mass to the tv for this trip?
again IF still using the 6 inch drop stinger that could be the issue...
IF the set up isn't level.
as 2 tire rotation...
i am compulsive about rotating f/r every 5,000 miles and crossing every other rotation...
JUST to spread the tire wear evenly from towing....
sorry but that's my only thoughts at this point.
cheers
2air'
