Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Closed Thread
Old 07-23-2007, 04:02 PM   #267
Sky
Classic 30
Sky's Avatar
Profile:  Sum Wear , Ohio
Originally Posted by razorback
Every pair of jeans I own have had grease spots "Go-Jo'd" out of them and I have two shin scars.
This may have been mentioned already, Im still in the middle of reading this thread. When I purched our Airstream with a HAHA, the tech actually told me to use Go-Jo instead of grease on the stinger bar for lubrication. It seems to work OK. It still hurts like hell, but doesn't stain.
"Only dull people are brilliant at breakfast." - Oscar Wilde
"Nothing is so permanent as a temporary government program." - Milton Friedman
"Ah! böwakawa poussé, poussé" - John Lennon
2500HD DMax............30' Classic w/ Hensley
Sky is offline
Old 08-18-2007, 05:08 PM   #268
2airishuman's Avatar
Profile:
Originally Posted by moosetags
Yours looks a lot more square than mine. Mine seems to be turning into a circle.
any progress or resolution on this issue moosetags?
did you contact the haha factory?
cheers
2air'
DISclaimer...da pixels above confused 4 words are clearly ALL just silly opinions...
2airishuman is offline
Old 08-18-2007, 09:29 PM   #269
Razorback
razorback's Avatar
Profile:  2005 30' Classic
Springdale , Arkansas
Smile
For the past 6 months I have placed a red grease rag over the stinger when I leave it in and my jeans are a lot cleaner. Still have the pain, but not the stain. And the red rag makes it more noticeable to others who may walk by so they can avoid it.
If I move the TV to go get fuel, etc, I wrap a short bungee around the rag and hook the ends through the clip pin holes. Works like a charm.
Razorback
Sid and Becky
2005 Classic 30 "Twinkie II"
Hensley Arrow
2008 Bighorn 4X4 Dodge 2500 Cummins
WBCCI Member At Large #2786
Life is not a dress rehearsal, live your dreams!
razorback is offline
Old 08-18-2007, 09:39 PM   #270
Profile:
hi sky and razorback...
it's the end of the swimming season...
noodles are now 2 bucks at wallyworld...
see d pix in post 25 here...
http://www.airforums.com/forums/275530-post25.html
that noodle is in the 3 year of duty, 12 inches at a time....
no pain, no stain and the old wounds are all betta!
perhaps an ORANGE one would be more oem?
cheers
2air'
Old 08-18-2007, 10:11 PM   #271
Razorback
razorback's Avatar
I may not even have to go to WallyWorld. That is if my granddaughter wouldn't miss a short section off the end of of her pool noodle!
Razorback
Sid and Becky
Hensley Arrow
Old 08-28-2007, 05:49 AM   #272
dpandorf's Avatar
Profile:  2000 34' Limited
Somewhere in Western , North Carolina
Rich Luhr has just posted an incident he just had with his haha on his blog. Too hard to cut and paste the link from my iPhone.
But he lost his WD bar enroute and only knew it since his better half was following in their new car.
It appears it may have failed due to fatigue from not greasing the hitch at recommended intervals when first installed.
Duane
Air# 16888
2000 34' Limited
2008 F250 Powerstroke
Hensley Hitch
dpandorf is offline
Old 08-28-2007, 07:33 AM   #273
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
Airstream Registry
Airstream Life Hitch Failure
Here's the link to Rich's Blog wher he describes the failure.
Tour of America: Hitch damage
Randy and Pat Godfrey
President, Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline
Old 08-28-2007, 10:34 AM   #274
Profile:
morning hitchin' buds...
the part that broke is pictured here..
http://www.airforums.com/forums/302952-post89.html
and in the next post #90.
the 'greasin' issue is specific to the w/d bar heads where they insert into the main haha body...
shown in posts 91-95 above...
there may be other and several issues contributing to this/his specific part breaking..
but YES YES YES grease those bar heads!
that's why there are grease zerks in that location folks.
and another caution...
should your spring bars fall out in camp, or drop partially out, or bind in the slightest AT the bushing/head...
CHECK THE GREASE ZERKS FOR DAMAGE...
it is very easy to grind, break or otherwise bugger up the inner zerk tips...
so carry spare zerks, and a grease gun,
and check this area each time you disconnect/connect...
cheers
2air'
Old 08-28-2007, 11:11 AM   #275
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Yes, 2air is, as usual, correct in his point: grease is good. The blog entry speaks for itself but I'll add a few things to further the conspiracy:
1) I've been using a mini grease gun, to keep the load of equipment in my bumper compartment to a minimum. But it takes 40-50 pumps of that silly little tool to fill the grease chambers every 500 miles, which is part of why I wasn't doing it as much as I should have initially. I'm switching to a "big boy" grease gun.
2) I have noticed (long ago in my misspent haha youth) that lack of frequent greasing can cause wierd tracking issues. GREASE GREASE GREASE as 2air rightly recommends.
3) I've already replaced my zerks twice due to having worn off the nubs and will be removing and replacing the current ones to check them as part of this repair. I carry a spare set because you can't just pick them up anywhere -- not a hardware store item. They do wear out in normal use, so expect it.
4) About 20 minutes before this failure, we crossed over a VERY rough train track. I was caught off guard by a severe bump at about 20 MPH and my wife who was following reported that the wheels of the trailer actually left the ground! This may have overstressed the bracket, leading to the failure only a few miles later. So I can't state the cause of this failure conclusively. It may be a complex set of issues.
5) Non- haha owners take note: this U-bracket and bar arrangement is used on other brands of hitches -- and I was told by a dealer that the bracket is a common failure point on those hitches as well. It's not an issue exclusive to Hensley.
WBCCI #9990 | Former full-timer | AIRSTREAM LIFE magazine | Tour of America | Man In The Maze
rluhr is offline
Old 08-28-2007, 12:14 PM   #276
dpandorf's Avatar
Thanks for the update Rich. I was just out at our trailer this morning going over everything as we're about to venture on a 3 week trip out to the Grand Canyon area. (A 5,000 mile round trip)
I've insured my haha has been properly greased, checked the torque on the nuts securing the hitch brackets, checked tire pressures and checked those lug nuts too.
I too keep a grease gun and plan on picking up additional refills as I'm down to one extra.
My wife and I will be posting a blog of our trip and will post a link to it in a new thread.
Glad no other damage was done to your rig Rich!
Duane
Air# 16888
2000 34' Limited
Hensley Hitch
dpandorf is offline
Old 08-28-2007, 01:19 PM   #277
Profile:
Originally Posted by rluhr
...I'll add a few things to further the conspiracy....
thank's for the additional info rich,
here in the repository of all things haha...
it's seldom just one thing true, true.
and high mileage users gotta do what they gotta do...
my concern was that some less familiar with the inner workings of these doodads...
might interpret 'grease yer hitch' as grease the stinger...
messy, messy, messy, as tin sista might say
as with all hensley controversies,
i'm pretty sure this contraption can be traced to medieval french drama...
which would make it a...
brouhaha...
cheers
2air'
Old 08-29-2007, 03:19 PM   #278
rluhr's Avatar
2005 30' Safari
Cracked U-brackets
OK, I replaced both U-brackets on my hitch and I advise other owners to go check theirs if they have a lot of miles.
See larger image at:
http://tour.airstreamlife.com/weblog...des%20rust.jpg
I talked to some more knowledgeable folks about this and they said that if the part failed due to metal fatigue, I'd see a rust line where the metal has been breaking for some time. In the photo above, you can see a clear rust line on both of the broken sides of the U-bracket, as well as sharp shiny steel where it finally broke.
You can also see severe stretching of the holes where the pin ties this U-bracket to the screw jack. This part needed replacement.
See larger image at
http://tour.airstreamlife.com/weblog...%20bracket.jpg
You can see the same metal fatigue rust line in the second photo, which shows the remains of the bottom part of the bracket. Also note distortion in the plate from the last bits of metal bending before they broke.
See larger image at http://tour.airstreamlife.com/weblog...%20bracket.jpg
The last photo (above) shows the other U-bracket. At first glance it appears OK. It's very hard to see in this photo, but the upper corner has a distinct crack in it. It was already in the process of failing! This crack is so subtle that you would not notice it in a casual inspection. You really have to look closely.
I will be replacing both U-brackets annually from now on.
Name:	haha broken sides rust.jpg
ID:	44033   Click image for larger version
Name:	haha broken u bracket.jpg
Name:	haha failing bracket.jpg
rluhr is offline
Old 08-29-2007, 03:43 PM   #279
Profile:
oh yea baby!
i can definitely see the rust in your crack!
it appears this u-bracket is the same piece on the 1000 and 1400 lb bars...
with that much MORE stress on the heavier bar users...
so it may be that your gradually failing u bracket broke on the rr tracks,
then it took a few miles for the bar to work itself out and fall...
u r really lucky 4 no trailer, gas line or brake line damage...
excellent post!
cheers
2air'
Old 08-29-2007, 06:41 PM   #280
Sky
Classic 30
Sky's Avatar
Rich,
Thank you very much for taking the time to post this information. I just purchased a haha in June, and will be keeping an eye on those U brackets. Do you have any idea how many miles were on those brackets before they broke?
Thanks again
Dale
Sky is offline
Closed Thread
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 41 05-21-2010 07:01 PM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 12:01 AM
Price guide for site? 1985air345 General Motorhome Topics 7 01-04-2003 11:06 PM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 05:53 AM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
