Old 09-29-2008, 09:29 PM   #1
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
The Hensley Cub
So, I went looking at Hensley's site tonight and found a brand new product! The Hensley Cub seems to fit the needs of those with smaller trailers (between 2000 and 6000 lbs.) Hey, that's me!
I used the search feature and found nothing about it, so I'm guessing it's just been announced in the last couple days.
MODS: If I'm missing long, detailed discussions elsewhere on the site and thousands of these things have been sold, please delete this and save me the embarrassment of looking totally clueless!
So any details yet on this little brother to the Arrow? Delivery date? MSRP? How much it weighs?
Hensley Cub
bredlo is offline   Reply With Quote
Old 09-30-2008, 06:14 AM   #2
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Thanks for bringing this product to the forum's attention. Sounds like a needed product from a very good company.
willyd is offline   Reply With Quote
Old 09-30-2008, 06:56 AM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Hey Brad that's sweet! A scaled down version. This would be ideal for the vintage trailers. Hopefully the price will be scaled down to something more reasonable.
Admittingly I have only had the Hensley Arrow hitch for a total of two small trips so far but I am impressed. I had my trailer out over the weekend for a quick one night trip. I had two semi-trucks pass me - and I DID NOT feel any wind pushing me around. It works well with my short wheelbase vehicle. My Wagoneer is only 109" wheelbase.
crispyboy is offline   Reply With Quote
Old 09-30-2008, 07:35 AM   #4
bredlo's Avatar
1954 22' Safari
Crispy, you're exactly the kind of guy I was thinking about when I first spotted it. Shorter, lighter trailer, and someone who wants all the benefits of the Hensley but would like to save a buck or two (big assumption it'll cost less than the big one).
If it *is* cheaper, then this is the thing that could be a tipping point for me. I don't plan on upgrading to bigger, heavier trailers and I just can't justify the price.
Probably won't be significantly less though - after all, it's simply a specifically designed hitch for a different application that happens to use a little less steel, but it doesn't seem to skimp on features, safety or the length of time it takes to make and market it.
Old 09-30-2008, 07:55 AM   #5
bredlo's Avatar
1954 22' Safari
If heavier trailers haven't needed that extra piece of steel for strength, how did it get there? And wouldn't Hensley have eliminated it already, if for nothing else than the chance to say "New and Lighter!" in their marketing?
Old 09-30-2008, 08:19 AM   #6
crispyboy's Avatar
1994 30' Excella
Bredlo,
Here is a photograph of a standard Hensley. The extra orange steel has a little finger that locks it into one of three positions when the hitch bar is not inserted. I assume this is to lock the head into place when hooking up the hitch.
Here is a photo of the main unit of the 3P. I didn't know there was a "special code" - you may want to think about one of these. It seems that Sean has cut way down on the excessive amount of steel. It looks lean and mean.
Old 09-30-2008, 10:58 AM   #7
_
Originally Posted by bredlo View Post
... it's simply a specifically designed hitch for a different application that happens to use a little less steel...
well this is basically the take home message, 'lo....
removing the front chunk of iron may have lightened it 20 lbs.
perhaps another 20-30 lbs for the lesser spring bars and hollow stinger.
the lighter spring bars (750lbs) have been available for a year or so...
i'm not wild about a hollow spring bar, but IF they really wanted to lighten THAT bit, it could be aluminum.
lastly, it's still covered with the same CHIP PRONE orange paint!
and sean is right, some significant competition is finally bringing benefits to the customer base.
cheers
2air'
Old 09-30-2008, 03:16 PM   #8
Hensley Ron's Avatar
Oxford , Michigan
Yes, we just announced the Cub. I towed our company trailer (19ft.) out to Hershey with it. We took steel out of the front and bottom plate, reducing the weight of the main unit by about 20 lbs. The hitch bar weighs in at 15 lbs. I've been lugging the solid bar around for 10 years, so it was a welcome change. The spring bars are 550lbs.
The trailer I towed had a 450lb. tongue weight, overall weight of 5000 lbs. I tow with a Chevy Avalanche 1/2 ton, 5.3l engine. I had some pretty nasty weather in and out of Pennsylvania, too. Could hardly tell the trailer was back there.
Give us a call if you have any more questions. I'll have the Cub, along with a new 5th wheel hitch, out at the California RV show next week. That's in Pomona (near L.A.). Stop by and visit if you're in the area.
Ron Estrada
Hensley Mfg., Inc.
www.NoSway.com
Hensley Ron is offline   Reply With Quote
Old 09-30-2008, 03:30 PM   #9
bredlo's Avatar
1954 22' Safari
Looks good, Ron. Glad you added the Cub to the line, as its big brother has always seemed to be a bit of overkill for my modest needs. I'm nowhere near California (I always hate saying that) but I'd like to check it out sometime.
Best of luck!
Old 09-30-2008, 03:48 PM   #10
rogerdodger's Avatar
Fresno/Clovis , California
Any discounts on the new cub for show attendees??
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 09-30-2008, 08:28 PM   #11
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Will the cub work for us?
We have a 68 Ambassador that will weigh under 6000 pounds and will be 28' in length including the tongue......can we use the Cub? pj
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 10-01-2008, 11:05 AM   #12
CanoeStream's Avatar
St. Cloud , Minnesota
Hello -- this thread has been edited to remove a variety of hijack posts and related responses. Mods do show restraint when doing this. I've messaged some members. Please let this post serve as my communication to other members that they've violated no policies but may have had posts removed to keep this thread on track.
Thanks to all of you for your lively and valuable input!
5 meter Langford Nahanni
Old 10-01-2008, 11:15 AM   #13
_
hi spot...
since it's basically a haha with a few lightened/removed bits, sure u can use it.
but why would u want to?
IF your trailer has 600-900 lbs at the tongue, it will be OVER the spring bar rating.
so while the unit appears to be 40-50 lbs lighter, that may not be much of a benefit with a 28ft/6k trailer.
what will be used as the tow vehicle ?
that may be important in your case, depending on HOW MUCH weigh transfer is needed.
cheers
2air'
Old 10-01-2008, 12:03 PM   #14
Oxford , Michigan
Of course! That's the best part of going to a show. Tell you what, bring me some real food (show food sucks) and we'll talk. I don't see Airstream on the list of manufacturers, though. That's too bad. I enjoy looking at the new models (and dreaming).
See you in SoCal!
Ron Estrada
Hensley Mfg., Inc.
www.NoSway.com
Used Hensley hitches tslanier Hitches, Couplers & Balls 42 01-21-2012 09:27 PM
Hensley loft47 Hitches, Couplers & Balls 38 05-09-2008 06:44 PM
My Used Hensley toddnich Hitches, Couplers & Balls 16 03-25-2008 06:11 PM
Hensley points down... Buttercup Hitches, Couplers & Balls 23 08-26-2006 05:43 PM
Hensley is worth it, right? Big Dee Hitches, Couplers & Balls 61 08-23-2005 09:11 PM
