12-03-2012, 09:37 AM
#1081
2013 25' Flying Cloud
san mateo
Brackets
On Tue, Nov 27 at 10:41 PM , Andrew Porter< andrew@anderseninc.com> wrote: As far as our brackets go, we did make a slight modification to the design of the outside brackets, but we do not have a set of brackets that are specifically made for Airstream or any other brand. Just for reference, the 8" frame brackets did not change, the 5"–6" outside brackets are now angled slightly, and the 3"–4" and 4-3/8" brackets have a more pronounced angle. While we did make this minor upgrade a few weeks ago, we did not make a big announcement since the previous shipping brackets worked just fine for about 98% of installations out there. In fact, if a customer has their outside brackets welded in place, that would actually take care of 100% of all installations since the customer could then place the bracket at any angle they desired. For the other 2% whose chain angle is greater, the 'straight' brackets work fine, but a few users may experience a little wear on the edge of the bracket tube – which (assuming they don't want to weld their brackets to compensate) we will cover under the lifetime warranty.
The reason we made the change was to accommodate the few customers with Aluminum frames that could not weld their brackets to the frame, and also for customers who very severe angles found with some trailers that have couplers that are much lower than the standard ones. Because the new angled brackets would work equally well on standard installs, it was an easy decision to change it going forward.
A few customers wanted the option to ship their unused brackets back to us (postage paid both ways by the customer) and we shipped out a replacement set at no charge to them.
If, for whatever reason, you would like a set of the angled brackets they are priced at $69.99 retail + shipping 2 outside brackets only.
Please contact us if you need further help.
--Andrew
Customer Service
Andersen Hitches …Made in America!
Off: 208.523.6460 | Fax: 208.523.6562
customerservice@andersenhitches.com
www.andersenhitches.com
12-03-2012, 01:38 PM
#1082
Princeton
, New Jersey
Thanks Andrew. I trust you are still following this thread. That was an upright thing for Andersen to do.
That may make it a little harder for the Nay Sayers now.
It is getting harder to fine quality products with quality support.
2004 Excursion 4x4
12-03-2012, 02:05 PM
#1083
1987 25' Sovereign
Oregon
, Ohio
I just started to installe my new Andersen hitch. Set the trailer level and coupler is at 18 3/4". Now to set the hitch ball height, problem. The top of the ball needs to be between 19 3/4" and 20 1/4". The shank will raise the ball to 18 1/2" on the drop side and lower the ball to 22 1/2" on the riser side. There appears to be a 4" dead space right were my hitch ball needs to be.We have a 2001 F150 crew with only 76,000 miles that a wondreful job of towing our 25' Airstream. Do I need to sell it and buy a new truck with a higher rear end to put the receiver up at least 2" higher.
12-03-2012, 02:11 PM
#1084
Common Sense
I had the same problem, and seems to be kind of common. Take a look at what I did on page 48 of this thread, post #661. Had the stinger part welded locally (35 bucks) so I could get the ball height I needed.
Much cheaper then buying a new truck, or even buying a new hitch part.
Regards,
Steve
12-03-2012, 02:55 PM
#1085
Biloxi
, Mississippi
I honestly cannot tell any difference when towing using the new angled brackets supplied to me by Andersen, but it does look better. Everything lines up nice and straight and I am definitely getting less if any at all rubbing on the chain as it moves in and out of the box.
MICHAEL
12-03-2012, 06:17 PM
#1086
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I installed the Anderson a month or so ago but haven't had it out yet. I did take it for a test drive at the time of installation. We are planning a southern trip but not until
mid-Feb so I will keep an eye on things then. The brackets they sent me were the former design. I installed them without welding for now. When I see how things are and work out any bugs I will weld them at that time. I did call them and asked to have a hitch with a longer bar made since the original would cause the tailgate on my truck to interfere with the A-frame jack. Haven't heard back from them to arrange payment and shipping for the modified hitch. Are the modified brackets made longer also or just angled to ease the abrasion on the chains ??? I think several inches longer would be the best of both worlds. I may just make my own down the road a bit.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
12-03-2012, 06:26 PM
#1087
Princeton
, New Jersey
Roger
Don't weld the brackets. If you have to weld weld small blocks against the brackets and weld them in place. Future removal or adjustment will be greatly facilitated.
Angling the brackets you have so that the chains are centered in the square tubes will solve the ware problem. Extending the bracket legs beyond the bottom of the A frame just to square thing up may result in the bracket arm bending under load applied to the extra length. Not worth the risk to find out.
2004 Excursion 4x4
#1088
Common Sense
I think longer would be better, at least on an Airstream with the coupler mounted so low, but wonder if they wouldn't need to be built from stonger material.
Any Mechanical Engineers here that can get some numbers going on this?
Regards,
Steve
12-03-2012, 06:28 PM
#1089
Princeton
, New Jersey
Roger
Angling the brackets you have so that the chains are centered in the square tubes will solve the ware problem. Extending the bracket legs beyond the bottom of the A frame just to square thing up may result in the bracket arm bending under load applied to the extra length.Not from chain tension but from hitting something on a turn. Not worth the risk to find out.
2004 Excursion 4x4
12-03-2012, 06:56 PM
#1090
2012 25' Flying Cloud
Battle Lake
Roger, I think you should install the hitch as designed. A lengthened stinger would give the trailer more leverage in sway, defeating some of the benefits of the Andersen or any hitch.
I would also wonder if lengthened brackets would put too much stress on them, and possibly your A-frame. Again it's added leverage that may be above design strength of the whole assembly.
doug k
12-04-2012, 08:46 AM
#1091
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Thanks for the input. The added length is minimal and I will keep an eye on it after giving it a try. It is only 2" longer and I will keep the original one in case I find any issue with its use.
Howie, I was thinking about the added length issue and if I decided to try that out I would probably go a little heavier on the steel. I measure the original at 0.625". I don't plan to do any welding for awhile so I will have time to think on that one too. A few posts back one of our Canadian friends had done this and I liked his idea. I don't know if he went a little heavier or not on the metal though. But I will leave all things original to try it out.
Bye-the-way Howie, how did you manage during our big storm ??? Lots of big trees around your neighborhood. We, personally, did OK but lots of trees down all around. Still cleaning up. Mother Nature at work.
Roger in NJ
TAC - NJ 18
12-06-2012, 05:40 AM
#1092
1987 25' Sovereign
Oregon
, Ohio
I talked with Dave at Andersen. They are making a shank that will cover the 4" dead space for our truck. It is only $75 including shipping and it will be powder coated just like new. It is cheaper than a new truck.
12-27-2012, 07:53 PM
#1093
2004 25' Classic
Prescott
Weight Distribution?
78 pages is a LOT to go thru  Hope I did not miss it. My question is about how much hitch weight is put on the TV. I have an suv and hitch weight is very important. From what I understand about this set-up, it looks to me that ALL the hitch weight is put on the TV, compared to the roughly 66% TV and 33% back on the trailer. I like this set-up, but not if all the hitch weight is put on the suv. Any ideas?
Julia & Bob
W/ Deedee & Boo
AIR #30685
12-27-2012, 08:17 PM
#1094
Common Sense
I know the trailer I'm useing the Andersen on has a light tongue weight, but it transferred the weight just like a conventional WD hitch would.
I see no reason it would do any different with your trailer.
Regards,
Steve
12-27-2012, 08:51 PM
#1095
2004 25' Classic
Prescott
My reasoning is how the torque is applied between the two. On a reg. wd set-up, the torque is forcing the frame down towards the bars which puts weight back onto the trailer. The Andersen has the torque applied in a horizontal plane, which in my way of thinking has no effect on adding weight back onto the trailer??  Have you been to the scales to see if any weight was applied back to the trailer?
Julia & Bob
W/ Deedee & Boo
AIR #30685
12-27-2012, 10:20 PM
#1096
Princeton
, New Jersey
The Andersen complies to Newton"s law of equal and opposite reaction.
In order to apply a force to the TV it has to distribute an equal weight, force times distance, to the trailer. There is no set ratio for this hitch or any other hitch because each combination of TV and trailer have different distances from the hitch to the axles effected.
It just appear like less force is being transferred to the trailer because of the generally longer distance from the hitch to the trailer axles. However if you do the force calculation they will be equal.
2004 Excursion 4x4
12-27-2012, 11:03 PM
#1097
Battle Lake
12-27-2012, 11:30 PM
#1098
2004 25' Classic
Prescott
Call me dense, but I am having a very hard time understanding how a chain being tightened on a horizontal plane squeezing a bushing (opposite force) transfers weight down on the axles. I know all about different lengths having effect on how much is transferred, but can not see how it is transferred from a horizontal pull to a vertical down force.
The reg. wd ones I can understand. They use a chain connected to the frame that pulls the wd bar up, causing a down foce on the trailer frame. I really like the Andersen set up, just cannot put my head around how it transfers weight back to the trailer. What am I missing  Has anyone actually weighed their trailer to see an increase in trailer axle weight after hitching up? I am close to my limits on how much the suv can take and 300lbs. more would not be good.
Julia & Bob
W/ Deedee & Boo
AIR #30685
12-27-2012, 11:38 PM
#1099
2004 25' Classic
Prescott
Originally Posted by dkottum
Thanks for showing that. Now I am more convinced there is no weight transfer to the trailer. Those diagrams show what I am saying. The force is in a horizontal plane, having no down (vertical) force applied to the frame. The other diagram shows the arrow of force in a vertical plane which transfers the force down (more weight to trailer axles).
Dang, I was hoping to be wrong on this one. I really like the Andersen.
Julia & Bob
W/ Deedee & Boo
AIR #30685
12-27-2012, 11:44 PM
#1100
Battle Lake
Bob, the diagrams show that the applied force is exactly the same, conventional or Andersen. Look again.
doug k
