Closed Thread
Old 11-26-2012, 04:40 PM   #1061
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by Sean Woodruff View Post
Can you get Anderson to chip in for the testing?
I'll chip in with my product and money.
Hi, how and what kind of testing would you do? And would it be more accurate than the totally unbalanced spring bar test done by another vender? [comparing the flexability of a 800 lb bar to a 1,000 lb bar]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline
Old 11-26-2012, 04:53 PM   #1062
Livingston , Texas
Originally Posted by HowieE View Post
Actually if you go back a bit further in my writings, several years worth, you will see that I have written on the Reese systems often. I wrote that one wanted the front axle to drop in the range of a 40/60 ratio to the rear axle, depending on the springs set of the TV. That was based on a need to get the rig in a drivable condition mostly attempting to reduce the Porpoising so characteristic with a Spring Bar system.
Okay, I did a search of your posts using the keywords "40/60" and "60/40".
I found 24 posts over six years in which you told people they should adjust their WDH so that load was added to both the front and rear axles reative to the unhitched values. The recurring emphasis was on steering control. I found no mention of porposing in these 24 posts.
You repeatedly stated you wanted a 40/60 ratio of front-end drop (load increase) to rear-end drop (load increase).
Now, the primary emphasis for your combination apparently is on porposing rather than on steering control. And, you believe that a ratio of -29/+129 is okay instead of your previously-preferred +40/+60.
I really don't care what you prefer to do with your rig. But, are you now advising other Andersen owners that load transfer is not important?
Ron
Ron Gratz is offline
Old 11-26-2012, 06:20 PM   #1063
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Which numbers were you using for me Ron, the ones for the Hensley or the Andersen? I posted both. I'm not sure I'm following you showing the 50%. Or maybe I just do not understand your theory. The Andersen was within acceptable range of less than 10% difference and handled very good.
I have not taken the rig to the scales with my Ford but I'll try to get there this week sometime. I still had a lot of adjustment room with the Chevy so I'll work on the Ford to get as close to 100% to the unhitched front axle as I can and post those numbers. In the past, I was attempting to get within 10 % of front and back axles. Did that and did not do more adjusting.
With the Hensley, I probably could not get it to 100% unless I changed and put stiffer bars on it. I was at 1,000 pounds. REDNAX had posted he also had the same problem with his but I never saw a post where he corrected it. I think he was out about 200 lbs. Jump in if you want to Red.
The lack of porpoising is real. With the Andersen, it is almost gone.
Regards,
Joe
Originally Posted by Ron Gratz View Post
For those who are interested in load transfer data and theory --
Front Axle Load Restoration (FALR) is chosen as the indicator of load transfer effectiveness.
For measured front-axle loads, FALR is defined as the amount of load added by application of WD
divided by the amount of load removed by tongue weight (with NO WD applied).
For measured front-axle heights, FALR is defined as the front-end lowering due to application of WD
divided by the front-end rise due to tongue weight (with NO WD applied) .
When the front end is observed to be returned to the unhitched height, the FALR is taken to be 100%.
The data indicate FALR=100% can easily be achieved for low tongue weights.
However, for tongue weights in excess of 1000#, it is not clear that FALR=100% can be achieved.
The curves labeled "FALR Theory" are calculated from: FALR = 100*CT*2*LA*(1+BOH/TTL)/TW/BOH
where
CT = chain tension in #/chain
LA = lever arm from ball center to chain in ft (assumed to be 6.5"/12 per Bruce H.)
BOH = ball overhang in ft (assumed to be 5')
TW = tongue weight in lbs
TTL = distance from ball to mid-point between axles (assumed to vary from 12' for TW=400# to 20' for TW=1200#)
Contributors of data can be identifed by their TW and achieved FALR in the following table:
TW - FALR - Load/Height - Contributor - DataSource
400---100%----hgt.----SteveH------Airforums.com
400----91%----load----Bruce H.-----Lanceowners.com, RV.net, Airforums.com
900----75%----hgt.----gallifrey------RV.net
600----54%----load----hbillsmith-----RV.net
800----50%----load----airheadsrus---Airforums.com
1250---45%----load----housedad-----RV.net
960----43%----load----renojack------RV.net
600----43%----hgt.----zues----------Airforums.com
670----40%----load----HowieE-------Airforums.com
Ron
Annette
AirHeadsRus is offline
Old 11-26-2012, 07:33 PM   #1064
Livingston , Texas
Joe, I took the unhitched front axle load of 3360# from Post #1031.
The hitched, with no WD, was taken from Post #1034 -- 2900# adjusted up to 3000# as you suggested.
The hitched, with WD, also was taken from Post # 1034 -- 3180#.
The load added via the WDH was calculated as 3180-3000 = 180#.
The load removed by tongue weight without WD was 3360-3000 = 360#.
The Front Axle Load Restoration was calculated as 180/360 = 50%.
I would be happy to add your new scale results to the chart when you have them.
Ron
Old 11-26-2012, 08:51 PM   #1065
HowieE's Avatar
Princeton , New Jersey
Images: 12
Ron
Take your research a bit further and early on in this tread you will see that I questioned Andersen instructions that stated a 1 1/2 in. RISE in the front axle was acceptable. That is clearly beyond the range of the steering geometry of any vehicle.
Yes historically Andy T, Andy from Inland, Reese, and Ha Ha have championed adding additional weight to the front axle when using a spring bar WD hitch. While they or the manufactures never stated it was to reduce porpoising you may agree that additional weight on the front axle would shorten the ring out of that. I doubt that the lawyers would have ever suggested they openly comment on that as a problem with spring bar type of system but anyone who has ever driven with one knows about it.
No I am not suggesting that weight transfer is not necessary. Rather as stated above I now conclude that weight transfer does not have to return ALL vehicles to there unloaded position but rather in my case with the heaver TV I have accomplished good ride, good steering control and don't have to bust my self tightening down on the Acme screws to accomplish this. There will be some combinations of mostly of lighter TV that may require transferring enough weight to return the TV to it's original position to accomplish these conditions and to keep the rear springs from bottoming out. But I do not see any reasonable combination that would require adding additional weight to the front axle to cause it to ride below the original position.
Andersen is a completely new approach to both sway and WD and should not be bound by the rules that applied to spring bars systems. The warped wing approach was the first attempt to control flight. Yes it works for birds but it did not survive with rigid bodied planes. Who is to say that counter weights similar to those used to control earthquakes in building may not someday be hung on our back bumpers to control sway. I doubt that but I am sure there will be those that will question it and attempt to hold it to older standards if it comes.
I am glad you have afforded me some freedom in the management of my life. That is a diminishing quantity now days.
2004 Excursion 4x4
HowieE is offline
Old 11-27-2012, 06:06 PM   #1066
Rivet Idiot
1999 34' Excella
CAT Scales for F-150 Andersen
I took the Ford to the scales today. First, I got the tongue weight with my Shurline and it was just a tad over 800 lbs.
CAT scales have a 20 pound +- accuracy and it showed up in my weights. The total rig weight has a 40 pound delta from 13,380 to 13,420.
Next are weights of the truck empty and attached with the WD loose. The target weight for return of front axle weight is 3500 pounds.
Next is the reading with 9 threads showing. That put 100 put back to front.
At 10 threads showing, got it within 100 pounds at 3400. That was very close to the limit that I could adjust. I may have to move my bracket back a little to get more adjustments. I did not have the tools to do it there and a truck broke down on the scales and had a line backed up waiting to get on.
I conclude that this hitch will move weight both to the front and back to the trailer. My last adjustment from 9 threads showing to 10 threads showing moved another 80 pounds back to the front. At 3400 pounds back on front, it is probably better than most of what is riding around out there but it should do better. The fender measurements were dead on 37 inches tightened up to 10 showing and unhitched from the trailer.
Last photo of bushing, I forgot to measure.
Enjoy!
Joe
ID:	173449   Click image for larger version
Name:	Ford 11-27-12 Empty0001.jpg
Name:	Ford Hitched Max0001.jpg
ID:	173454   Click image for larger version
Name:	Tongue 11-27-12.jpg
Annette
Old 11-27-2012, 07:04 PM   #1067
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Hi 'Rus, My urethane bushings compressed more than that I think to return the truck to it's unhitched attitude, about 2 3/8" front to back, so you have more to go if you need it.
I think if you run out of threads you could add washers behind the urethane bushing to get more compression, to save readjusting the brackets or changing chain length.
doug k
dkottum is offline
Old 11-27-2012, 07:09 PM   #1068
HowieE's Avatar
Images: 12
Great Joe you just popped their balloon and proved that the Andersen hitch works for WD. What are they going to challenge next?
Don't move your brackets just add some washers before the nut if you want more adjustment. There should be room before the eye on the bolt hits the face of the bracket
2004 Excursion 4x4
HowieE is offline
Old 11-27-2012, 07:26 PM   #1069
Livingston , Texas
Joe, It looks as though your scales data are of really good quality.
I have taken the liberty of making two 20# adjustments to make your three hitched weighings internally consistent -- all three GCWs will equal 13,400# and the loads added to front axle, removed from rear axle, and added to trailer axles will have ratios of approximately 2:3:1.
I changed the 9-link trailer weight from 6380 to 6400 and the 10-link front axle weight from 3400 to 3380.
The "adjusted" values are: front axle -- rear axle -- trailer axles -- GCW
TV only: 3500 -- 2760
No WD: 3220 -- 3820 -- 6360 -- 13400
9 Links: 3320 -- 3680 -- 6400 -- 13400
10links: 3380 -- 3580 -- 6440 - - 13400
The indicated TW is (3220+3820)-(3500+2760) = 780# which agrees very well with your Sherline value of 800#.
The Front Axle Load Restoration for 9 links is (3320-3220)/(3500-3220) = 36%.
The FALR for 10 links is (3380-3220)/(3500-3220) = 57%.
I will add the two new FALR values to the chart.
Ron
Old 11-27-2012, 08:07 PM   #1070
Rivet Idiot
1999 34' Excella
doug k
That is a great idea Doug. Thanks! Would be simple. And thank you also HowieE.
Annette
Old 11-27-2012, 08:11 PM   #1071
Rivet Idiot
1999 34' Excella
Ron
Thanks Ron, it is a work in progress.
Joe
Annette
Old 11-27-2012, 08:19 PM   #1072
Livingston , Texas
Error correction --
In my previous post, please read "link" as "thread".
Missed the 30-minute limit for editing a post.
Ron
Old 11-27-2012, 09:21 PM   #1073
Livingston , Texas
The previously-posted chart is updated to include two data points (800#,36% and 800#,57%) calculated from data provided by AirHeadsRus for 9 threads and 10 threads respectively.
where
800----57%----load----airheadsrus---Airforums.com (updated for 10 threads)
800----36%----load----airheadsrus---Airforums.com (new data for 9 threads)
Ron
Old 11-28-2012, 09:01 AM   #1074
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Please don't think I am trying to undermine this beautifully designed piece of equipment. I know many of you owners personally, and highly respect your opinions.
Looking at the Anderson, the fulcrum for weight distribution is the front surface of the ball. Looking at the HAHA or PP, I really can't tell, but the fulcrum appears to be inside the hitch assembly. Is the Anderson exerting a force on the trailer coupler, that the other designs don't? Or, is the fulcrum also on the ball with the other designs?
Does it even matter lol
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline
Old 11-28-2012, 09:08 AM   #1075
SteveH's Avatar
Common Sense , Texas
With all previous designs of WD hitches, the force of the bars is applied downward onto the ball.
With the Andersen, the force is applied to the rear of the ball, and with the tongue weight, it's sort of an angled forward and downward force on the ball.
This was discussed early in this thread to the point a call was made to Andersen to clarify.
Regards,
Steve
SteveH is offline
Old 11-28-2012, 09:14 AM   #1076
HowieE's Avatar
Images: 12
As noted above the fulcrum is on the back face of the ball. It is hard to envision at first but after a good nights sleep I came to terms with that and bought one.
Sky
You will be surrounded with Andersen hitches at the Can Opener so you will be able to see first hand what we at talking about.
2004 Excursion 4x4
HowieE is offline
Old 11-28-2012, 09:29 AM   #1077
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Thanks for the replies so fast. You guys are really on the ball. Yes Howie, I can hardly wait to see them, and their owners, at the CO.
Sky is offline
Old 11-29-2012, 07:22 AM   #1078
Rivet Idiot
1999 34' Excella
HowieE,
I went out yesterday and checked and sure enough at 10 1/2 threads the eye bolt hit the face. After work I went out and slid the brackets back about a full inch. Impact wrenches are wonderful things so it did not take long at all. After hooking up it now looks like around 5 threads showing get the bushing compressed to where the 10 threads were before.
For those that might ask, the previous brackets position had not slid forward. They were still on my pencil line. The dimple I drilled for the set screw held fine. I am glad I had not welded the bracket to frame and do not recommend doing it until you are sure where you need to be.
I'll get back to the scales sometime in December or maybe on the way to the Canopener.
Sky,
We look forward to seeing you guys at the CO. Are you still getting in on Thursday? Probably will be a few pots of chilli going that night.
Regards,
Joe
Annette
Old 12-02-2012, 12:25 PM   #1079
SteveH's Avatar
Just got back from a 500 towing mile weekend with the little Casita and Andersen hitch, and it's doing great.
Regards,
Steve
SteveH is offline
Old 12-02-2012, 07:23 PM   #1080
1987 25' Sovereign
Oregon , Ohio
I have not yet installed my new andersen WD hitch yet. I have weighted both heads that that go to the TV, the old Reese straight line is 48 lbs., and the new Andersen is only 28 lbs.. This is quit a differance as I get older and very important should my wife have to hitch the trailer should something happen to me.
msmcv51 is offline
Closed Thread
