Closed Thread
Old 06-06-2012, 11:27 AM   #29
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Thanks HowieE. I tow with a 2011 F-150 and a 2012 Chevy 1500. I use a 4 inch drop Hensley stinger on the Ford and a 2 inch drop stinger on the Chevy.
I like the Hensley and it pulls great. But:
Hensley is very heavy
Can not use my tractor to move the trailer with out taking the Hensley off.
Always getting grease from the stinger and hitch head on me.
The hitch is 16 years old and needs rebuilding which would cost as much or more than the Andersen.
If I can lower my tongue weight by 100 pounds or more it would really be nice.
I'll be watching for anyone that has gone to the scales.
Regards,
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline
Old 06-06-2012, 12:09 PM   #30
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by danlehosky View Post
I think this one is to stiff. Different bar lengths produce different amounts of force.
Don't be so defensive, you know you've opened a can of worms here.
Dan
I am not defending anything. As I mentioned earlier I have used and advised others for years on WD hitches. What I am doing here is advising people on a product that I feel is an improvement over anything currently in use. I realize the method of accomplishing the transfer of weight is not the easiest concept to envision. But once you can envision the ball/coupling as replacing the upper trunnion of a Reese hitch it becomes clearer.
In a static position the force created by bars to gain a given WD is the same as that produced by the Andersen. The principle differences with this hitch occur when you go over a bump. Springs have a reflex action that tends to put the system in a reducing oscillation thus causing porpoising. The urethane bushing do not produce this reaction and thus completely dampen this effect.
The historical discussions over the weight of the bars was mainly to deduce shock transmitted into the trailer while crossing a bump. Route #10 in LA. killed one of my trailer batteries knock everything off the plates and shorted it out, in Jan I have to go back and see what happens now.
2004 Excursion 4x4
HowieE is offline
Old 06-06-2012, 01:03 PM   #31
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
HowieE, I predict that when you go over the same bump again, you will ask yourself "When did they fix that nasty bump?"
MICHAEL
AWCHIEF is offline
Old 06-06-2012, 01:21 PM   #32
HowieE's Avatar
Images: 12
Are you speaking of the new hitch or a life style change in LA.
2004 Excursion 4x4
HowieE is offline
Old 06-06-2012, 07:22 PM   #33
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
It would be great to see some long term testing on this unit. I really like the simplicity of the product. Your right.. this could be a game changer. Lots of great viewpoints here and we appreciate the civil discussion :-)
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline
Old 06-06-2012, 07:28 PM   #34
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
Second opinion here,,,, I like it and understand the dynamics. The only question I have HowieE is about the amount of force applied to the pawl. If I got one I would go with a hand crank assembly rather than a lever lock.
Am I seeing this right? It seems like the WD is all there.....
Dan
TAC
Hope is not a plan.
danlehosky is offline
Old 06-06-2012, 09:23 PM   #35
HowieE's Avatar
Images: 12
Dan
What are you referring to here? I don't recognize either term with respect to the hitch.
2004 Excursion 4x4
HowieE is offline
Old 06-06-2012, 09:42 PM   #36
Phoenix , Arizona
I like the concept of the hitch. I would like the shaft to be longer coming out of the bottom so that it would give more leverage forward for the same amount of force on the chain (or reduce the force of the chain for the same amount of forward leverage). I would also weld a tab on the frame for the chain mount instead of having the bolt on components, but that is just me. I really like the ball that swivels with no movement in the hitch itself. That is a great idea.
When watching their 5th wheel offset hitch for short bed pickups they really missed the boat. What they need is a weight distibuting hitch setup so that the 5th wheel or goose neck can be mounted behind the axle while still giving the truck the WD as if it were 3" or so, forward of the axle. All these problems with broken rear windows and the trailer hitting the cabs would be eliminated. There would be no need for sliding 5th wheel hitches on short bed trucks. The chains can pull upward to accomplish the same forward WD. I think I need to build one. I should patent it.
M2HB is offline
Old 06-06-2012, 09:53 PM   #37
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Dan
That is a good question... I'd assume the pawl would be quite sturdy, as it has to take the load of the trailer hammering back and forth on it all the time... this WD setup would keep the trailer pulled forward, putting all the load on the pawl... but the off-setting factor is the coupler and ball rotate as one assembly and all the wear is on the tapered sleeve...
It is possible this would actually reduce the chance of wear on the pawl... no?
In any case... I'd gladly try one out except for the $200 premium for Canadians...
Friday is offline
Old 06-06-2012, 10:00 PM   #38
Phoenix , Arizona
That could be a problem since the force is against the rear of the coupler instead of the front, where the force was designed to be placed. The torsion bars put the force downward on the top of the ball where weight was designed to be. I think this is a serious problem with the Andersen design. Having said that, I would design one with the chains vertical with the bottom plate cantilevering rearward so that the force is downward on the hitch. It would accomplish the same WD, but the force would be applied to the top of the coupler and not the back. It is the same concept I mentioned above that should be used on short bed hitch systems. Again, I should patent it.
M2HB is offline
Old 06-06-2012, 10:04 PM   #39
danlehosky's Avatar
HowieE, sorry. It looks like all of the force from the ball is going to be directed to the front of the coupler when WD is used. Will the coupler take this force? The safety pawl is a locking mechanism. Do you think an ordinary coupler with a lever lock on say an AS will withstand the forward force of the ball without egging out and becoming sloppy?
If there is a weak point it's the only one I can see.
Dan
Other than that, I really like it.
TAC
Hope is not a plan.
Old 06-06-2012, 10:15 PM   #40
danlehosky's Avatar
M2HB, better huerry on that patent. Thats a good idea. Lots of engineers on this forum that can draw, submit and licence.
Dan
TAC
Hope is not a plan.
Old 06-06-2012, 10:37 PM   #41
2007 Base Camp
But the pawl takes a pounding anyway every time the trailer decelerates... every bump... with a constant force on it, and it pivoting WITH the coupler... it might work even better?
I can't be much more load than already designed... these couplers are used on 8,000lb trailers...
Friday is offline
Old 06-07-2012, 06:18 AM   #42
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is there a reason that RV manufacturers use the pawl type couplers? Seems like the Bull Dog would be a perfect fit. No pawl at all.
TG Twinkie is online now
Closed Thread
