Closed Thread
Old 08-09-2012, 03:00 PM   #309
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
I am now over 2,000 miles towing with the Andersen hitch. I am still very pleased with it however I did have one issue which I do not know what to think about it. On I-81 on the way back to Virginia from Airpocono, I ran into some really nasty weather with very high wind gusts. That was not really a problem until a semi passed me on a bridge right when a very high gust was blowing. I was in the right lane and the truck was in the left. The gust hit the truck which swerved into my lane. I swerved as well and about the same time he pulled up and exposed my trailer to the gust. Before I could digest what was going on the computer on the f-150 took over both the throttle and brakes. It appeared to me in that split second the power was cut and the brakes were applied in 4 short bursts. What ever it did fixed anything that was wrong and no other problems on the rest of the trip.
I assume that was the beginning of sway but the anti sway combination of truck and hitch stopped it cold. It was nice to have that working for me as I was more concerned about the truck pushing me into to guard rail.
Annette
AirHeadsRus is offline
Old 08-09-2012, 03:20 PM   #310
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Glad to hear the Ford F150 anti-sway system actually works. Hopefully I will not have to test it on my F150 anytime soon.
MICHAEL
AWCHIEF is offline
Old 08-09-2012, 04:59 PM   #311
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I have read two stories about the F-150 sway control. One that it applied only truck brakes to control sway, and another that it also braked the trailer.
Anyone know?
This in combination with the Andersen Hitch is interesting.
doug k
dkottum is offline
Old 08-09-2012, 05:28 PM   #312
1974 Argosy 20
Kooskia , Idaho
My 2012 Jeep Grand Cherokee Overland also has trailer sway control, but I have not had any indication that it worked or not. The Andersen seems to do any control needed, but my experience is only with trucks passing me on the Interstates. Absolutely no push, pull, or any reaction from my rigs.
Oh, my Jeep did not come with a built in brake controller, so whatever it does would only be to the TV itself.
idroba is offline
Old 08-09-2012, 07:21 PM   #313
AWCHIEF's Avatar
Images: 33
Doug, if I understand my owner’s manual correctly it only applies the TV brakes, but there is more to the system than that. It also controls the throttle. The combination of the two helps to control the sway. The factory trailer brake control also works with the SYNC system to control the trailer brakes using integration with the onboard computer rather than relying on magnets, g-meters or hydraulics as some other brake controllers do.
MICHAEL
AWCHIEF is offline
Old 08-09-2012, 07:46 PM   #314
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the automatic sway control on the TV applies the Brake Lights it would apply the trailer brakes also since that is the signal that the trailer brakes work off. Now that said that signal would be of such short duration that it is questionable what effect it would have on the trailer
2004 Excursion 4x4
HowieE is offline
Old 08-09-2012, 07:57 PM   #315
SteveH's Avatar
Common Sense , Texas
Has anyone heard before of the F150 anti sway system ever being activated with any other type of hitch?
SteveH is offline
Old 08-10-2012, 11:24 AM   #316
Rivet Idiot
1999 34' Excella
That is a good question Steve. When it activated, it was so subtle and short duration in control had I not known it had this feature, I would have just shrugged it off.
Annette
Old 08-10-2012, 11:33 AM   #317
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Great feedback on new technologies.. glad to hear it worked out.
Im sure that would have been the perfect storm for under hitched / dated vehicles.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline
Old 08-10-2012, 05:28 PM   #318
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Where is the pressure on the ball??
As you can see in the pictures of my ball, (which now has 3000 miles on it) There is some wear on the back of the ball, but most of the wear is on the side back on both sides, which doesn't hit the ball lock, as so many are worried about.
also, you will notice wear on the top front of the ball, not the back!!
Now some of this will depend on the wear of your coupler. Mine is over 40 years old. Others my have different wear on their ball, (don't go there) It would be good to see some pictures of them.. Stay out of the gutter please So if you get a chance post some pics..
ID:	165363   Click image for larger version
ID:	165365   Click image for larger version
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is offline
Old 08-10-2012, 05:42 PM   #319
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, is this a praise for Ford doing it's job, as per design, or is it to try and find fault in a new hitch?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline
Old 08-10-2012, 06:36 PM   #320
SteveH's Avatar
Not trying to find fault with anything, or praise anything. If I was trying to do either, my intentions would have been clear and no one would have asked, I guess.
It is interesting, however, that this is the first time I have read about the Ford stabilization system kicking in. May not actually be the first time, just the first time I have read about it. Now, if it in fact IS the only time it has happened, then I would ask why?
SteveH is offline
Old 08-10-2012, 06:38 PM   #321
SteveH's Avatar
Jason, Contrary to Andersen's claims, it looks to me like some hitch grease would be a good thing on that ball.
SteveH is offline
Old 08-10-2012, 08:52 PM   #322
1974 Argosy 20
Kooskia , Idaho
My marks on my Andersen hitch are similar to Jason's, but none on the front of the ball. I do use a very small amount of Reese "on the ball" hitch lube (a white grease) and think it is of value. It is so small an amount it wipes off easily with a paper towel when I unhitch. The ball is smoother when I use the lube than when I didn't, so I am continuing to do it.
idroba is offline
Closed Thread
