08-27-2012, 03:23 PM
#341
Ladera Ranch
Do I still need an Andersen Hitch with an F250 TV?
Originally Posted by Bill M.
"I am sure I ignorantly added to the problem by choosing a Ford F250 as TV."
I know lots of people who pull Airstreams very successfully with Ford 250's without the trailer suffering damage. I suspect you are hitched too stiffly or have a bad imbalance in the running gear. I think the Ford 250 was an great choice for a TV. Maybe your torsion bars are too heavy? Or you are transferring more weight than needed to the front wheels? Or you have 10 ply with 80 psi in them? I pull an older 25' with a 2500 Dodge that is not sprung nearly as well as the Ford and we marvel at how stuff stays in place in the trailer and does not bounce around.
Hi Bill,
Just yesterday, my husband and I were test driving potential tow vehicles (3/4 Ton Ford, GMC & Dodge) and he asked me, "Do you think we'll even need a WD hitch if we are towing with one of these big boys?" I told him I'd ask the pros on Airforums. So, what do you think?
08-27-2012, 05:11 PM
#342
2010 25' FB Flying Cloud
Davenport
, Iowa
I got mine today; now to set-it up. Looks simple and good instructions. Now to compare it to my Equi-lizer.
08-27-2012, 07:16 PM
#343
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by sierrafun
Hi Bill,
It depends what you will be towing with it. For any TT (travel trailer) other then a popup an anti-sway hitch is very helpful some would even say necessary. With a 3/4 ton a 23' Airstream would be the biggest I would want to tow more then a short distance without WD, but I would rather not do that on a regular basis.
Using a WD/anti-sway hitch just increases safety so why not?
08-27-2012, 07:40 PM
#344
1964 26' Overlander
Milton
, ON
Also, check the rating on the truck's hitch (receiver). On my F350's factory installed hitch the maximum is 500 lbs tongue weight and 5000 lbs trailer weight without a weight distributing hitch.
08-27-2012, 07:48 PM
#345
Ladera Ranch
Thank you so much for the help Wazbro and DavidsonOverlander. We never considered looking at the rating on the truck's hitch. That would be an important consideration especially since the 27FB International has a hitch weight of 770 lbs.
Thank you again! It is really so nice to meet such nice and helpful people on this forum :-)
08-27-2012, 09:12 PM
#346
2012 25' Flying Cloud
Battle Lake
It's more than hitch weight that you need a w.d. hitch, you need the sway control features as well. A 3/4 ton truck suspension and high center of gravity is not the most stable thing on the road in emergency maneuvers or if the trailer starts to sway.
doug k
08-27-2012, 09:40 PM
#347
1974 Argosy 20
Kooskia
, Idaho
I hope this thread can remain information about the Andersen hitch and not the need for a WD hitch in general. Just a heads up not to let the topic drift too far from the original title.
08-27-2012, 10:31 PM
#348
Ladera Ranch
Will the Andersen Hitch Make A 3/4 Ton More Stable?
doug k
Hi Doug,
So do you think the Andersen Hitch will make a 3/4 ton pulling a 7600 lb Airstream more stable?
08-27-2012, 10:43 PM
#349
Salem
, Oregon
Hi Doug,
Hi, I think the hitch [any hitch] is supposed to make the trailer more stable. [not the tow vehicle] Or I miss-understood what you are saying.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-27-2012, 10:55 PM
#350
Ladera Ranch
Looks like I'll be buying an Andersen WD Hitch I love the ease of use and no grease! I was just looking on their website and noticed that they also offer a "Greaseless Hardball" (costs extra) but looks like it might work better than the ball that comes standard with the hitch.
Below is the link:
3453 - 2" Greaseless Single AlumiBall
08-27-2012, 11:05 PM
#351
Salem
, Oregon
Below is the link:
Hi, this looks like the wrong size ball and for a completely different type hitch.
08-27-2012, 11:17 PM
#352
1974 Argosy 20
Kooskia
, Idaho
Yes, most of our trailers use the 2 5/16 ball. It is interesting that they have this, while saying you don't need grease on the ball. It is a new hitch concept, and I can see that there may be a learning curve from the factory as to what works best in the real world of us users. As I have mentioned, I use a little grease on the ball of my Andersen and Howee had found that a small amount of lube on the bottom ring and shank is helpful. I have been experimenting with teflon tape in that location, but have reached no conclusions as to weather it is really useful or not.
This is a great thread to toss out ideas and things we have tried with the Andersen.
08-27-2012, 11:25 PM
#353
Port Orchard
You are absolutely correct about the wrong hitch. It says it's for the Rapid Hitch. If you click on the Rapid hitch button on the left, you can see it is a completely different thing.
Ken
08-27-2012, 11:36 PM
#354
1968 28' Ambassador
Cedaredge
My 68' is a 2" ball.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
08-27-2012, 11:50 PM
#355
Salem
, Oregon
Hi, the more that I read about this hitch the more I understand it and like it. Now what about the frame brackets. How far back from the coupler do they go for example 29" to 32"s like my Equal-i-zer so I don't have battery box or propane tank issues? And what about the 5" to 6" brackets? I think I would prefer to have brackets made for my 5" frame only. Or is this partly why I see four holes per bracket? Any close up pictures of the brackets bolted to a 5" frame and showing which holes you used.
08-28-2012, 12:40 AM
#356
1974 Argosy 20
Kooskia
, Idaho
I will measure my backset for the mounting of the brackets tomorrow and give you the dimensions. My frame is a 4" so the 3-4" frame bracket use the top holes. The 5-6" brackets would use the bottom holes, but you could cut the top part off prior to installation if you didn't want the projection.
You can shorten the chains a lot according to Andersen, and they will supply longer ones if you want or need them for some spacing reasons. Mine fit behind the propane tank rings on my Argosy's just perfectly, but your spacing on a newer AS might be different.
08-28-2012, 07:16 AM
#357
Biloxi
, Mississippi
Below is the link:
That ball will not work with the WD hitch. It is for the Rapid Hitch that they make and sell. Look closely at the pictures and videos on their site of the WD system and you will see why it would not work or is even necessary.
MICHAEL
08-28-2012, 09:44 AM
#358
1974 Argosy 20
Kooskia
, Idaho
AWCHIEF: thanks for pointing that out, I sure missed it when I looked at the link.
ROBERTSUNRUS: I just went out and measured my chain bracket setback and it is 28" from the center of the ball to the center of the brackets as I have them mounted on my Argosy. For me, that is behind the propane tank bottom hold downs, which are welded in place on my rig. That dimension is for the standard supplied chains. The supplied chains can be shortened in the field for a closer mount, and Andersen will supply longer ones for a bracket farther back on special order.
08-29-2012, 09:57 AM
#359
Battle Lake
Okay, me too. The Equal-I-Zer has done the job but the light weight, low cost, ease of use, no grease has got to me. I prefer the Hensley/Propride design but the cost, heavy tongue weight, some difficulty hitching, and how we travel holds me back.
Perhaps the great factor in this decision is the jostling of us and our equipment on many older concrete highway sections. (No it's not the hitch adjustment; after many campers, it's lousy roads). Reports are this is greatly reduced by the Andersen design. Is it?
doug k
08-29-2012, 10:07 AM
#360
1968 28' Ambassador
Cedaredge
doug k
I noticed a difference in ride with mine. I have not been down dirt roads with it yet but on the rough highways it smooths out the jolts that I got with my old WD.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
