Closed Thread
Old 07-10-2013, 02:53 PM   #2073
SteveH's Avatar
Common Sense , Texas
Been gone for a few weeks (I'm so sure you have all missed me ), and I see lots of new posts on the Andersen hitch.
Too bad it seems nothing has changed and the Airstream coupler still won't work with the hitch, the brackets are still slipping if not welded, and it still won't transfer weight adequate for a big trailer.
Wonder if Andersen will redesign in the near future because I still like the idea of the hitch, just wish it would do what it's supposed to do.
Regards,
Steve
SteveH is offline
Old 07-10-2013, 03:24 PM   #2074
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes Steve your absence was noticed. During that time no one was misrepresenting the facts quite as well as you do.
Yes there is an ongoing problem with the Atwood coupler. That is not a problem with the hitch. While it would be nice to have all new products full compatable with all older ones that is not always the case. Progress often requires some modifications or replacement of older systems. I trust you remember the 8 track and the fact that it will not play on an I Pod.
Brackets are subject to slippage, but easily secured by several methods other than welding. A second set screw at the top of the brackets or bolts through the brackets each work. None of this would be necessary if Andersen increased the tilt angle of the brackets and they were installed with the bolts preloaded against the frame before marking the location of the set screw.
I must restate that my 34 ft 8,900 lbs trailer is working very well with the Andersen. Something that you may have missed
or refuse to accept.
By the way I just ordered my second Andersen for my daughter's trailer.
2004 Excursion 4x4
HowieE is offline
Old 07-10-2013, 05:01 PM   #2075
SteveH's Avatar
Howie,
No one here doubts you like the hitch as much as you push it, but we do doubt that it actually transfers the tongue weight as it should.
Really, why would we believe it does for you when it doesn't for anyone else with a large heavy trailer?
Regards,
Steve
SteveH is offline
Old 07-10-2013, 06:02 PM   #2076
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
It might be time that we all just agree to disagree.
MICHAEL
AWCHIEF is offline
Old 07-10-2013, 07:46 PM   #2077
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I can get behind that. :-D
SteveSueMac is online now
Old 07-10-2013, 09:37 PM   #2078
1986 31' Sovereign
Miami , Florida
Just can't let it go, can you Steve?
It is getting really, really old...
I plan on replacing my aging Straight Line with the Anderson this winter after changing out my rather tired Atwood. I have a 4 ton, 31' Sovereign and I do not have the slightest doubt it will work just fine for me.
Why not get a PP tattoo and start a new thread all about the wonders of that miracle product...
Mike
n2916s is offline
Old 07-10-2013, 09:57 PM   #2079
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
No Steve, not much has changed; the hitch still doesn't work, another user got rid of it (because it broke the latch and uncoupled from his trailer), and a few ardent supporters still verbally attack anyone who questions it.
It would be good for Andersen to redesign the hitch to work out it's many problems, although they are so intrinsic in its nature I wonder if it would ever be suitable for a large trailer.
The "works for me attitude" would also be true of the great towing characteristics of an Airstream with no w.d. hitch, and some who do have reported similar results.
doug k
dkottum is offline
Old 07-11-2013, 06:22 AM   #2080
SteveH's Avatar
Yes, it seems it has gotten so bad here now that the "supporters" of the hitch have nothing else to do now than to attack anyone who has any question of it's greatness. Yes, that would be me, and I am an owner of an Andersen, and a user.
There is no perfect hitch at this time that I know of, and not even the ProPride is without issues. I say "that I know of" because I have not tried them all. I actually wish I could try an Equalizer, and some of the others, but it's just not practical. This is the reason I bought my Andersen, this and the fact that I was intrigued by it's revolutionary design.
Maybe we could set up a network on this forum to trade hitches around so everyone could share their hitch and that way everyone could get to try every brand out there while not having to actually go and buy one of every hitch. Lots of logistical problems with this idea, but it could be made to work.
However, I feel sort of sorry for those that blindly get on the bandwagon of a product just because they like the idea of it while closing their eyes to it's faults and limitations which are evident all around them.
Regards,
Steve
SteveH is offline
Old 07-11-2013, 07:13 AM   #2081
1964 24' Tradewind
Lawrence , Kansas
Doug you have make your point and it is time for you to move on, please.
ttbikes is offline
Old 07-11-2013, 12:24 PM   #2082
AWCHIEF's Avatar
Images: 33
Howie, who did you buy the new Andersen WD system thru? I am doing some additional trailer shopping and might be needing a new Andersen WD system before long.
MICHAEL
AWCHIEF is offline
Old 07-11-2013, 01:00 PM   #2083
Tempe , Arizona
3,800 miles and still going
I just got finished with about 3,800 miles of camping through Arizona, Yellowstone, Grand Tetons, Bear Lake (UT), North Rim of Grand Canyon, and the Mogollion Rim forest north of Phoenix. We towed up hill, downhill, rain, snow, windy and calm. I wish I had a little more horsepower however the Anderson performed as I expected, perfect, and I could make slight adjustment as our load changed throughout the trip by adding or removing turn of the nut.
I also noticed that my other travel companions that have more traditional WD hitch setups with bars and such were always hesitant to disconnect once we arrived at camp because a of the pain of setting up again.
I keep looking for the problems reported here but my setup have been working great so far. I will certainly post otherwise should that change.
Happy camping to all!
2005 Land Rover LR3, 2014 Lance 2185, Anderson WD Hitch
Craiglud is offline
Old 07-11-2013, 01:34 PM   #2084
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We just got home from a short trip through New York and New England states. Still happy with the Anderson. This morning I drove through probably the most stressful area that I know of. That is I-95 through southern Ct. and into New York. Narrow lanes, lots of heavy truck traffic, construction ( of course ) and heavy rain, bad roads all added up to make one of the highest stress areas to travel through. Trailer or no trailer. I usually go to great lengths to avoid this route but this time just had to bite the bullet and go for it. Truck and trailer in combination with the Anderson hitch did a fine job. So, still liking it and will be off again in about 2 weeks.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline
Old 07-11-2013, 08:00 PM   #2085
Rich of SCal's Avatar
2012 16' Sport
San Bernardino , California
coupler gone!
Originally Posted by Rich of SCal View Post
OK, I am finally ready to tackle the coupler replacement issue. After reviewing several posts on this thread and other places I decided to go with the Quickbite. So I have ordered one. Apparently quickbite no longer has a website, but I was able to locate the 2 5/16" version on Tweety's website.
My understanding from a couple of posts is that the best way to add it is to weld it OVER the old Atwood plate after cutting off the ball area at the front. If I were to strip off the old plate I would need spacing strips to line everything up correctly. I would love to hear from anyone who has successfully done it this way.Thanks
p.s. my next door neighbor is a welder and volunteered his services. How great it that!
Post 1396 and after will give you my experience with the quickbit.
http://www.airforums.com/forums/f464...92131-100.html
it is important that you keep the top plate of the old Atwood to align the jack and hold the frame while working.
Thanks Howie! That's what I was looking for. I did do a search and read dozens of post at both ends, but just didn't come to it. This thread needs it's own table of contents. lol.
Those pics and comments will help me and my neighbor immensely.
Now that I have accepted the fact that I have to change the coupler I am looking forward to trying out the quick bite. It comes with the 2 guide rods. I used to use the tennis ball on a car antenna method. Currently I use a cheap wireless camera, but this looks way better. BTW I usually hitch up alone, and prefer it that way.
Well my neighbor cut and ground off the old Atwood this afternoon. We had to redrill the tongue jack bolt hole cutouts on the new quick bite, as they did not quite line up with the atwood holes. But now everything fits well. Monday his boss is bringing the heavy duty welding shop on a truck to my backyard and the welding will commence.
There was more gap between the atwood and the quickbite than I expected. If we had cut off the old atwood completely it would have been huge.
But the quickbite is a nice piece of trailer tech. And now that I see it in person I will definitely feel more secure towing with my Andersen system. And I won't be afraid to tighten it up more for better weigh transfer and handling.
BTW I bought my quickbite from Tweety's rv. It was $22.74 for shipping/handling and arrived in about 3 days. Very pleased with the quick service. Total bill was $160.08. This is the black powder coated version with mostly stainless parts inside, but not the XT model (couldn't find that one anywhere). Looks quality and has a lifetime warranty (life of the trailer).
Rich of SCal is offline
Old 07-13-2013, 09:44 AM   #2086
2013 25' Flying Cloud
san mateo , California
Detractors
Just ignore these Andersen hitch DETRACTORS especially those heavily invested in the rigid PP or any bar-type hitches. The bar-type hitch unless you're meticulous in weighing your set-up as I am not will cause problems in wear down the road. Andy of Inland has commented on that early on in the PP thread. Rear-end separations, doors not shutting properly and so on and on due to their rigidity from not being perfectly weight balanced regularly.
The Andersen has been such a soft ride a huge difference in my towing life. Guess what, no more weighing, too. After towing for thousands of miles it is the best hitch bar-none for me. BTW, no welding on my brackets either, just flip the inner brackets w/ the set-screws on top opposing the outer bracket screws is holding just like they were welded. The Andersen is the best today and will only get better or unless someone else will topple it. Free market is great.
dmand001 is offline
Closed Thread
