Closed Thread
Old 05-22-2013, 07:45 AM   #1863
Harlingen , Texas
The housing is aluminum, but the shank is steel.
Rendrag is offline
Old 05-23-2013, 02:28 PM   #1864
1987 25' Sovereign
Oregon , Ohio
And the bumble bee keeps flying!!!!
msmcv51 is offline
Old 05-23-2013, 04:55 PM   #1865
SteveH's Avatar
Common Sense , Texas
And the heads are still buried in the sand.
Regards,
Steve
SteveH is offline
Old 05-23-2013, 05:09 PM   #1866
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Close, I spent the day spreading gravel for my new Airstream pad. 90 degrees & max humidity. Killer day!
MICHAEL
AWCHIEF is offline
Old 05-23-2013, 05:24 PM   #1867
Noggin's Avatar
On the Lake , Georgia
Originally Posted by dkottum View Post
As long as you are listing the pros you got from these threads and ignoring the cons I posted earlier, I'll submit them again. And there is another:
4) It has never been demonstrated that the Andersen can distribute sufficient weight in many applications. This is a safety factor when a larger trailer is hooked to a lighter tow vehicle due to loss of traction at the steering axle.
doug k
Time to post this again, Been over a day! Maybe he'll post the other three also.
Cheers,
Noggin Inmearse
Noggin is offline
Old 05-24-2013, 03:08 PM   #1868
2013 25' Flying Cloud
san mateo , California
Set-Screws
After more than 1200+ miles w/ the Andersen hitch I must say that all of the glowing remarks made here in the forum about the Andersen hitch is true. I will not rehash nor bore you w/ them but will remark on perhaps other unmentioned matters that may be of more interest.
Set-screw placements? There’s no choice as to the placement of the set screws for the outside brackets which is bottom outside part of the frame. The inside part of the frame is another matter though as it could be mounted on the bottom as well as the top part of the frame just by flipping the brackets upside down. I chose to place mine on the top. I just thought it was designed that way. How did you mount yours? I followed the instructions but found it difficult to get the set screws to imbed flush. After twisting my initial allen wrench out of shape. I went ahead and tapped the hole slightly for some help. That helped some but again didn’t get it completely flush but it was solid w/ about 1 to 1 ˝ of threads exposed. Needless to say it was a primary concern of which I checked on every opportunity but after 1200+ miles they’re holding firm. I will keep checking for any slippage or movement and see whether I need to change it or not. I will see after another 5000 miles.
I will try to post pictures that I took in Vegas w/ about 800+ miles.
dmand001 is offline
Old 05-24-2013, 05:50 PM   #1869
Set-Screw w/ Pix
dmand001 is offline
Old 05-24-2013, 06:58 PM   #1870
1981 31' Excella II
New Market , Alabama
I am concerned about not enough flex in the chain bushings. A bar will tend to bend more less in a linear fasion but the chains and bushings are only going to flex to a certain point and then the loads go way up. This would be like running load bars way too stiff on a conventional hitch. That is my engineer's perspective. I also don't like that the main structure is aluminum which has a finite fatigue life compared to steel.
Perry
perryg114 is offline
Old 05-25-2013, 07:32 AM   #1871
AWCHIEF's Avatar
Images: 33
Perry, I recall that your concerns have been brought several times before. Actual experience would suggest that they are not an issue.
MICHAEL
AWCHIEF is offline
Old 05-27-2013, 10:27 PM   #1872
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Well this weekend I became initiated in the Airstream community and Andersen hitch users community. I took ownership of a 27FB, enjoyed 4 days of camping then drove about 300 miles home in pretty annoying winds (30 mph or so). I ordered my Airstream and purchased the Andersen hitch last February prior to the Atwood compatibility issue.
I'm conflicted about the hitch. I've never experienced sway on my prior trailer, but today's drive up I-5 in high cross winds with endless semi's passing seemed no big problem. My issue was getting weight off the rear axle. At a truck stop, CAT scale, I tried twice to get loads under spec by repeatedly tightening the bolts. In the end I torqued the bushings to where their bulged a lot but I couldn't transfer the last 80lbs off my rear axle to stay within spec.
So what to do? I can put the ice chest and everything else into the trailer, leaving the back of my Expedition empty (was full for this trip). According to the scale, there's 300lbs capacity on the front axle. Driving performance however is just fine. No twichiness or anything. Then there's the Atwood coupler issue. I have the bad coupler. At some point it will fail. So far its fine, its brand new.
I really like how light all the parts of the hitch are. I think the sway technology is a good match for Airstream trailers. I'm not convinced yet the hitch is good at distribution of weight. For me it barely works on my rig (weight distribution) so should I change the coupler and stick with the Andersen , or should I walk?
kscherzi is offline
Old 05-28-2013, 06:53 AM   #1873
Harlingen , Texas
I hope your dealer gives you the opportunity of trying a different hitch. I like the Andersen, but it is not for those that need to unload as much weight as possible off the rear axle. My Silverado 1500 required 50% front weight restoration and my 2500 requires 0%, so it is fine with both. The Andersen works great for those of us who have plenty of rear axle capacity and payload. Light, clean, easy to use, quiet, and good resistance to sway. If I had to take four or five hundred pounds off the rear suspension, I would look elsewhere, Equal-izer makes some good looking hitches.
Rendrag is offline
Old 05-28-2013, 08:12 AM   #1874
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
kscherzi, we had the Andersen but with the Atwood and weight distribution problems, as well as other concerns posted here previously, we decided it was not compatible to our needs.
We bought a Propride hitch and now know what comfortable and safe towing is really like.
doug k
dkottum is offline
Old 05-28-2013, 12:47 PM   #1875
Rich of SCal's Avatar
2012 16' Sport
San Bernardino , California
evolving design
I towed my AS up the mountains for the MemDay weekend for the first time. As I stumbled over all the Reese dual cam hardware in my shed to get my Andersen shank to hook up the Andersen I was so glad not to have to mess with all that Reese weight again. Hook up and unhooking with the Andersen is so much easier and lighter that I will never go back. I am reconciled with the fact that I should eventually have my Atwood coupler replaced. But even that inconvenience doesn't come close to the hassle of using the Reese system.
Granted, I have a smaller, lighter AS. All the more reason I don't want to use a heavier "traditional" hitch.
I did notice that when I tensioned the Andersen properly I was getting some rise on the "shark fin" on the coupler. Returning from camping I tensioned it less and the ride was much more bouncy. So replacing the coupler is something I will eventually do once I find a good welder with rv coupler knowledge. I don't want a hack job!
Rich of SCal is offline
Old 05-28-2013, 12:51 PM   #1876
1974 Argosy 20
Kooskia , Idaho
Originally Posted by Rich of SCal View Post
(snip)
Find a place which builds or repairs horse trailers. They do it all the time and are fast and reasonable. There are always horse trailer places around.
idroba is offline
Closed Thread
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
