Closed Thread
Old 06-27-2012, 05:34 PM   #221
1974 Argosy 20
Kooskia , Idaho
Well, sunny today and I decided to un hitch to see just how easy or difficult that was with the Andersen. It is somewhat different than a conventional WD hitch, but easy enough, so no problems there.
I had previously de greased the hitch coupler, but had not looked inside very carefully. With the Andersen, since more pressure is put on the rear of the ball, I wanted to see where the pressure points were on the ball and the coupler. The ball had some marks on it of left over grease, so I could see that and took some photos. When I looked inside the coupler for the spots I had seen on the ball, I found something else: two hairline cracks. Ooops. The cracks were obviously not new, and were NOT created recently or caused by the Andersen, but never the less, at this point I am needing a new coupler so I will have no more information on the Andersen, other than that I posted last night until that is done. Remember this is a very well used 38 year old Argosy. I have towed it many thousands of miles, and who knows how many miles it had gone when I got it 14 years ago.
A wake up call to me, I had never given any thought to coupler life, but mine is at it's end. So, the silver lining of the Andersen is that it caused me to look at my coupler and find that failure was going to happen soon, no matter what WD hitch system I was using.
If you want to see what I found, look for my new thread asking for coupler advice. Photos there. I don't want to hijack this thread.
BTW, I weighed my new Andersen stinger and ball mount, and got 22#. The chains and plate stay on the trailer, so they don't have to be handled or lifted.
I then weighed my old Reese/Draw Tight stinger and ball mount at 40#. The spring bars for that hitch weigh another 18#. I like the lower weights of the Andersen.
This is turning out to be the hitch summer I guess.
idroba is offline
Old 07-03-2012, 01:11 PM   #222
HowieE's Avatar
Princeton , New Jersey
Images: 12
Well another fun 250 mile weekend. Had one truck go by me while I was doing 70 and he was closer to 75+ Did feel him but it was not a sway situation.
Food for thought.
You may want to grind a angle across the center bottom edge on the plate. The plate tends to cut into the jack post as you raise the rig in order to hitch up. Just knock the edge off.
I noticed the plate was getting a bit harder to slip on and off the shank. Took a 1/2 round file and removed the high spots that showed contact marks. Not sure if this will be a continuing issue or not. After cleaning up the fit I did put a light coat of oil in the hole in the plate and now it slips on and off like a dream. Notice I did not say grease. About the same amount of oil you used to put on your weapon.
2004 Excursion 4x4
HowieE is offline
Old 07-03-2012, 01:30 PM   #223
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Howie, that last could be taken so many ways.☺
MICHAEL
AWCHIEF is offline
Old 07-04-2012, 09:43 AM   #224
Vintage Kin
Fort Worth , Texas
And with many of the same consequences.
slowmover is offline
Old 07-11-2012, 08:00 PM   #225
1974 Argosy 20
Kooskia , Idaho
Update on the Andersen hitch:
I have had the Andersen Hitch for a bit now, but have not been able to use it after I found stress cracks in my 38 year old Atwood coupler on my very well used 20' Argosy.
I ordered and received a new OEM stile Atwood coupler and towed the Argosy 125 miles with the new Andersen hitch to the shop in Missoula where I had the coupler removed and replaced. (see story in the coupler thread)
The Andersen is a very very nice hitch. The 125 miles to Missoula for me is over highway 12, along the Lochsa River, a windy and twisty road to Lolo pass, with a 50 mph speed limit in Idaho, then down to Missoula from the pass. 70 mph speed limit in MT. Coming into Missoula, two large semi trucks/trailers passed me at 70, while I was doing 63. No sensations at all. They just passed me. End of story.
The rig, Jeep Grand Cherokee Overland with full Air suspension and the 20' Argosy with a hitch weight of 680# tows as if I were driving the Jeep only. That is there is no sensation whatsoever that the trailer is there. It does not push the Jeep, no oversteer or understeer, no sway, nothing. I never had any objections to the Argosy towing in the past with my Draw Tight or Reese WD hitches, but with the Andersen it is just better, I feel.
The hookup is very easy. One can use the large socket (supplied with the hitch) and a 1/2" drive to do the hookup, or, if the ground TV and trailer are right, use the hitch jack to do all the work, without turning the hitch chain nuts at all from when you disconnected it last time. I don't yet have a lot of hitch/unhitch experience, and the Air Suspension on the Jeep sometimes has a mind of it's own, so I have used both the tongue jack system and the loosen and re tighten the chain nuts system. I am getting used to it still, you have to understand.
From the coupler weld shop, I drove another 70 miles to where I am camped right now, a beautiful Forest Service campground on Lake Alva (Verizon cell net access here). Again, everything is just like driving the Jeep alone. No noise, no sway (but I have never had any sway issues with my old hitches) just one solid unit. I unhitched here at the campsite and it was just super easy. Jack the rig up with the electric jack until the tension chains were loose, pull the pin, drop the triangle plate, lower the jack to take the weight off the ball, pull the coupler lever forward and up (forward is a new feature of the new coupler) and raise the trailer off the ball with the jack. Pull the Jeep forward. Done. Very light weight parts to handle.
I took some photos of the grease that I had put on the ball to determine the pressure points. I may post them later. Visually, there is pressure on the REAR of the ball by the coupler, and on the TOP of the ball. No pressure on the front of the ball. The chains do the pulling on the Andersen system, not the ball. The ball does not rotate in the coupler, it rotates in the hitch head socket against the friction material which does the sway control. Andersen does not recommend lube on the ball, but I wanted to see the pressure points so I did put some on. Non greasy parts is another advantage to this hitch.
OK, only about a total of 250 miles with it so far, but I think it is going to be a winner in my book. I have stressed over and over, that I never had any issues with my Reese or Draw Tight hitches, but this one is lighter and tows in a more solid way.
More as I find out.
idroba is offline
Old 07-11-2012, 08:07 PM   #226
1974 Argosy 20
Kooskia , Idaho
Oh, BTW, I have not, but will put the rigs on the scales to show how the weight is moved forward to the front wheels of the TV with the Andersen. That is another trip to Lewiston Idaho, where I can access the scales at my leisure. I am using the "measure the fenders" system now that I have found out how the Air Suspension system works and how it may be shut off, along with my scale experience with my Draw Tight hitch a couple of months ago to set the Andersen up.
idroba is offline
Old 07-11-2012, 08:55 PM   #227
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
I'm a little surprised that Andersen insists no grease is needed. If for no other reason than to prevent rust.
But, what I haven't seen mentioned is that in fact the ball does move in 2 of the "3 axes of flight" in the coupler. If not, in the pitch axis, you would not be able to go up or down anything other than flat road without the front or rear axle of the tow vehicle being lifted off the ground. Or in the roll axis, the tow vehicle would not have any independence from the trailer and jacking up the left side of the trailer to change a tire would also lift the left side of tow vehicle.
I think everyone is focused on the fact that the ball rotates with the trailer in the yaw axis (by chains), which does normally see the most movement, but not all.
I'm rooting for the Andersen...
The NSA -- The only part of the government that listens.
newroswell is offline
Old 07-11-2012, 09:16 PM   #228
1974 Argosy 20
Kooskia , Idaho
newroswell: I completely agree with you, there is movement of the ball within the coupler, and for that reason I plan to put a slight amount of grease on the ball and wipe it off with a paper towel as I remove the ball from the coupler. I use Reese "on the ball" lube which is a white grease, I assume it is a high pressure lube.
I was siting here thinking of the positives and negatives of the Andersen, and I really can not come up with any negatives of any consequence so far.
The Vintage Rally in Gunnison CO this month will give me a lot of miles and hitching and unhitching to make my evaluation better. I expect about 2500 miles of towing.
One thing I hope everyone is aware of: My Argosy is only a 20', 4000# trailer and the Jeep is a 5200# tow vehicle. So, the combination is one which would generally be stable in any event. But Howee E is towing a much larger AS (I think 31 or 34') with the same hitch and he also seems satisfied at this point.
idroba is offline
Old 07-12-2012, 10:52 AM   #229
1974 Argosy 20
Kooskia , Idaho
I thought I would post three photos of the Andersen hitch setup I have. The first and second are the hitch from both sides. I have not repainted the coupler or area where the old snap up brackets were located. The safety chains always make a messy looking scene, but there is not much that can be done with them.
The third photo shows the hitch ball after disconnect. I had lightly greased it with white grease and towed 70 miles. This was with the brand new coupler. If you look carefully at the black patterns on the ball, you can see that the weight of the trailer rests on the top and left and right sides of the ball. The black back side area is where the coupler pushes against the rear side of the ball as the chains do the pulling from the bottom. The front of the ball, which you cannot see, had no marks on it at all. The chains on the Andersen do the actual pulling. In case of any failure of the chains, mis hook up or things like that, the hitch goes back to a weight cary mode, and pull would be from the front of the coupler, as we normally think happens.
ID:	162979   Click image for larger version
idroba is offline
Old 07-12-2012, 01:23 PM   #230
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I like the simplicity of this design except there is no apparent flexibility (unlike weight distribution bars) when the front of the tow vehicle is lifted in relation to the remainder of the t.v./trailer, such as entering a very steep driveway approach. Or simply the "ups and downs" of roadways.
There would seem to be a bending force somewhere on the trailer tongue. We have been warned of this with too-rigid weight distribution bars
Engineers or mechanical minds?
doug k
dkottum is offline
Old 07-12-2012, 02:52 PM   #231
HowieE's Avatar
Images: 12
All of the flexibility is taken up in the urethane bushings.
As you go over the crest of a small hill the load is reduced on the bushings and the tongue weight would go up for that that short period of time. Crossing the rail road tracks at Ravenel SC is about as drastic as it gets.
As you cross a dip or wash the load increases on the bushings and transfers more weight to the front axle of the TV. Turning up to Eagle Peak in Robesonia Pa is the other extreme.
Neither even is of any significance because of the short duration. Nor do the produce enough force to cause a problem. The real test will be the next crossing on a Canadian ferry in the lower Fundy Bay. I have lifted the rear axle of the TV, with a Reese, enough to lose traction while leaving one of them
As for the comments above about movement in 2 of the 3 axis. Yes there is movement there but clearly not enough to warrant conversation. That level of consideration is tantamount to worrying about the degree of flexure in the frame of you TV.
Remember one of the principle consideration in a structural design is flexure. If rigid it will brake
2004 Excursion 4x4
HowieE is offline
Old 07-12-2012, 07:00 PM   #232
1974 Argosy 20
Kooskia , Idaho
doug k
When the front of the TV is lifted vs the trailere, the coupler and the chains both experience force, and the bushings are put under more pressure. The chains have more tension, and the coupler has more "push" on the back of the ball. There is no bending moment at all applied to the trailer tongue, unlike what happens with normal WD bars which pull down on the frame more in that situation. So, in fact, there is LESS bending force on the frame, not more, on the Andersen system.
How the hitch reacts in a very steep ramp situation with the TV gong up, and the trailer level does not seem to me to be any different than the same situation with a bar WD hitch other than with the Andersen there is more tension on the chains and more push on the ball vs. more pull down on the frame with a normal WD hitch. But, be assured, there is less stress on the frame with the Andersen. The strain on the TV hitch receiver would be the same in both cases, and it would be much higher than normal level towing.
With either type of WD hitch, if I knew I was going to be in such a situation, such as a steep ferry ramp, I would take all tension off the bars or chains and let the movement be at the coupler ball, with the hitch weight on the rear of the TV for a short time. I have a friends driveway that I back into and pull out of which has that steep situation. In the past I have simply loosened the WD bars on the normal WD hitches I have had up to this point. When I visit them next with the Andersen, I plan to do the same thing, loosen the chains to remove the excess torque on the TV hitch platform and the TV itself.
idroba is offline
Old 07-12-2012, 07:08 PM   #233
HowieE's Avatar
Images: 12
If this becomes necessary it can be done with the supplied socket wrench without raising the trailer via the jack and reset afterwards just a easily. Just remember the length of threads exposed before loosening the bushing nut.
2004 Excursion 4x4
HowieE is offline
Old 07-16-2012, 10:01 PM   #234
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Got my Andersen Hitch today. It is so light compared to my other WD. And once it's in I won't have to take the heavy hitch part out so I'm guessing it may be 10 lbs to lift the plate and chains in Place. IF
The chains are made in the USA, but the links that join the chains to the plate say China on them. Will be watching those for wear..
I know there was some concern about the threads striping out. NO WAY. those things are huge. You can see them in the picture compared to my finger. Will get it set up tomorrow, once I get last minute things done on the trailer.
Leaving Friday for Oregon so Will post on the way as how it does, as we are taking 3 days to get there.
ID:	163304   Click image for larger version
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is offline
Old 07-16-2012, 10:30 PM   #235
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Thanks to purman's second picture, I can see that it isn't just a coarse thread, but what I believe is called an ACME thread or Machine thread.
Name:	ACME THREAD.jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline
Old 07-16-2012, 10:41 PM   #236
purman's Avatar
1968 28' Ambassador
That would be it. It's not course at all It's well machine. Everyone was talking about counting threads. I thought that would be a pain but after seeing how big they are it won't.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is offline
Old 07-16-2012, 11:11 PM   #237
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
What is the advantage of that type of thread? Strength? Resistance to unthreading on its own? Longevity?
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline
Old 07-16-2012, 11:31 PM   #238
1974 Argosy 20
Kooskia , Idaho
I will be starting on a 2500 mile trip with my Andersen and Argosy 20 on Wed. That will give me more experiences with hitching and unhitching techniques. I know they are easy enough, even at this point, but more experience will tell me the best way to do things. It is a very easy hitch to use in any event.
My 250 mile return trip from Montana last week was uneventful. The trailer went where it was towed to go and made no notice of itself whatsoever. The Jeep, towing, drives like it does solo.
idroba is offline
Old 07-16-2012, 11:32 PM   #239
purman's Avatar
1968 28' Ambassador
It's strength, it is tacking the place of the torsion bars and their chains. The treads are at least 1/16 inch thick and again as deep.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is offline
Old 07-17-2012, 08:01 AM   #240
AWCHIEF's Avatar
Images: 33
I would say all of the above.
MICHAEL
AWCHIEF is offline
Closed Thread
