Closed Thread
Old 09-24-2013, 01:45 AM   #2301
OrangeKid
2013 23' Flying Cloud
Portland , Oregon
Originally Posted by Rendrag View Post
"......the whole rig is very quiet."
That is the first thing I noticed. It is almost eerie, as one waits for the usual squeaks and clatter.
We pulled into a campground after prolonged rainfall fall with the Equalizer hitch many years ago and the whole campground heard us. This was before Equalizer offered Sway Bracket Jackets. In fact we tested early versions of these jackets for Equalizer on our first trip to Alaska in 2008.
OrangeKid is offline
Old 09-26-2013, 11:58 AM   #2302
2013 25' Flying Cloud
san mateo , California
Functional Simplicity
Have always sought simplicity but yet superior functionality hence immediately gravitated towards an Airstream. I feel likewise for the Andersen Hitch. Fine tuning the Andersen to achieve that driving feeling of oneness w/ a trailer and having to glance at the mirror occasionally insuring that the trailer is still there is simple, just loosen or tighten the nuts starting w/ half turns. You're set and experience the softest, quietest ride ever. But when there's any significant weight changes w/ your TT/TV like maybe adding 40 gallons of fresh water or whatnot, just fine tune again like above. After a while on the road you just know how much to turn the adjustable chain nuts for that ultimate towing feel.
Enjoying being on the road now for over a month and currently in Missouri somewhere. So thankful for the Andersen in igniting my interest in trailer traveling once again, of course, Airstream trailers, that is. Have a general goal of ending up in Disney World Florida and back to the west coast sometime via the southern route. I just can't imagine of going back to the complexity of a bar-type hitch ever again. It's more fun traveling when it's simple, safe and fully functional. Attached some pictures on some stops w/ the new 25' flying cloud and of course my new simple QB coupler I had put in. Traded my vintage 31' which equally ran great w/ the Andersen. May post again in the near future.
ID:	196395   Click image for larger version
dmand001 is offline
Old 09-26-2013, 12:42 PM   #2303
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
dmand001, that's the same model trailer we attempted with our Andersen, it seemed quite rosy as well (until multiple issues caused us to remove it). But take it to the weight scales and see how little weight transfer the Andersen can accomplish for you. You will be heavy on the rear axle and too light on the front. Drives fine until you need good steering control such as slick roadways.
There is virtually no flexibility in this hitch design. We had elongated mounting bolt holes and possible trailer damage where the A frame meets the shell. Keep an eye on it as you continue to use the hitch.
Doug and Cheryl
dkottum is offline
Old 09-26-2013, 06:15 PM   #2304
Gainesville , Florida
And the beat goes on. Jim
xrvr is offline
Old 09-27-2013, 04:46 AM   #2305
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
dmand001-
Thanks for sharing your positive experience. Please do post again in a few months and let us know how the hitch is working for you over time. Personally I'm intrigued but haven't yet decided to be an early adopter. I'm looking forward to learning more from actual users about their experiences over time and many miles.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline
Old 09-27-2013, 07:14 AM   #2306
Harlingen , Texas
Thanks dmand001 for another user report. I will be on the road to South Texas before noon and look forward to the tow, with the Andersen Hitch. I will be watching for problems, as I would with any mechanical device.
Rendrag is offline
Old 09-27-2013, 09:52 AM   #2307
1987 25' Sovereign
Oregon , Ohio
Good morning all you Andersen hitch users. Last weekend we towed 300 miles with the Andersen and Quick-Bite combo. The combo worked very well on both two and four lane roads, both with heavy truck traffic. For those of you with Quick-Bite couplers, I added a third aleighment rod by wielding a small diameter collar on the Andersen stinger inline with the ball and with a rod at the ball I was able to back right into the coupler first time, every time. Hooking up has become so easy with the Andersen and the Quick-Bite that I just might try to train my dog to do it.
msmcv51 is offline
Old 09-27-2013, 10:53 AM   #2308
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Could you post a picture? I'm not quite following your description.
Stephanie
Stefrobrts is offline
Old 09-28-2013, 08:18 PM   #2309
1987 25' Sovereign
Oregon , Ohio
I will see if I can add a picture tomarrow
msmcv51 is offline
Old 09-30-2013, 08:43 AM   #2310
1987 25' Sovereign
Oregon , Ohio
I hope that I uploaded the pictures. This is the best that I can do until I hookup again, and that may not be till spring.
ID:	196748   Click image for larger version
msmcv51 is offline
Old 10-04-2013, 06:09 AM   #2311
Harlingen , Texas
Another complaint with the Andersen hitch came about after a thousand miles of towing last weekend. It wastes gasoline! Before, where I had to plod along at 45-50 mph to reduce the slam bang bouncing on some of our roughest highways, I was now able to maintain my normal 62-65 mph. I have traveled this route before and was pleasantly surprised by the improvement. I use a minimal amount of compression, just enough to take the bounce out.
Rendrag is offline
Old 10-05-2013, 08:47 AM   #2312
1987 25' Sovereign
Oregon , Ohio
I love Rendrag's post. Lower miles per gallon, but a much smoother ride. Could this mean less damage and repairs to the trailer. Maybe the lower amount of repair cost will make up for the little more gas burned at high speed.
msmcv51 is offline
Old 10-05-2013, 02:08 PM   #2313
HowieE's Avatar
Princeton , New Jersey
Images: 12
And after several thousand miles I to am beginning to see some problems with the Andersen.I find myself repeatedly looking in the mirrors to see if the trailer is still there. Ford has just sent me a notice that my mirrors needed to be replaced form over use. Just another cost of having an Andersen
2004 Excursion 4x4
HowieE is offline
Old 10-05-2013, 02:34 PM   #2314
Ottawa , ON
OK, now I get it. I was reading your post, and trying to put it together with the photo in your profile, which was definitely NOT a 31-footer. Congrats on getting a new TT!
Um, why not update your profile now/
Aage is offline
Old 10-05-2013, 08:53 PM   #2315
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Thanks, I see what you meant. I'm very interested in upgrading to one of these quick bite couplers because our old coupler is getting worn out. I figure why not upgrade if there's better solutions out there, and the quick bite sure looks like a better mousetrap to me.
Stephanie
Old 10-07-2013, 02:14 PM   #2316
In Florida
Did make it x-country and staying here for a wk or so then back to the west coast. Yes did travel in all sorts of conditions, even inadvertently going beyond 75 mph on decent driving conditions that have had to put it on cruise control from over speeding. It is that good once finely tuned and not hard to achieve as stated in a previous post. My wife even suggested driving it and perhaps a good idea. Looking at the rear view mirror is inevitable and always amazed at how quietly it tracks the TV. Remarked to my wife on how more solid and stable the TV feels w/ the trailer than w/out.
For those new here, I've had to put in a QB coupler and welded the in/outside brackets to the frame. Attaching photos, too.
ID:	197276   Click image for larger version
dmand001 is offline
Old 10-07-2013, 02:24 PM   #2317
Savings
Time is money and getting there quicker pays dividends, besides not sure if gas consumption is significantly different.
dmand001 is offline
Old 10-07-2013, 06:59 PM   #2318
Harlingen , Texas
No hurry these days. I am retired and getting there is part of the fun. I do get quite a bit better mileage at 50 MPH compared to 65 MPH. I was having fun with the mileage thing, but meant it about the lack of bouncing.
Rendrag is offline
Old 10-17-2013, 06:29 PM   #2319
2014 16' Sport
RWC , California
Atwood Coupler on 16 Bambi
Question for you Anderson users:
On a new 16 foot bambi, will the coupler need to be replaced with a QB in order to use the Anderson? I'm struggling searching to find which coupler I have and whether or not it needs to be changed. Steve at Anderson mentioned the Atwood 88000 is the one that doesn't work well with the Airstreams. Is that all of them, certain ones? Any help?
Thanks.
norcal bass is offline
Old 10-17-2013, 06:51 PM   #2320
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Thanks.
The 88000 series are what Atwood calls flip latch couplers, they also make what they call Yoke style and these are supposed to be fine. I have used the 'bad' flip latch style (with a few mods) for 2000 miles with no signs of any problems. However I will go to one the yoke style this winter before next years trips. Check their website RV Components, Gas Appliances, Marine Products, Chassis Components, Seating Systems, Windows and Doors from Atwood Mobile for pictures to see the difference.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline
Closed Thread
