07-21-2013, 08:19 PM
#2221
Harlingen
This is from a Andersen hitch user who preferred that I post his experience here rather than his becoming a member of this forum.
RV.Net Open Roads Forum: Towing: Andersen No-Sway Experience
For those who do not want to follow the link, I will give my condensed version:
He give it a "thumbs up" for the way it performs. He liked its "predictability", "Quietness", "Ease of Use", "Sway Control", and "Weight Distribution". All in all, he is happy with the Andersen hitch and feels good about recommending it to others.
I will add that he is towing a 10,000 pound trailer (his estimate) with an adequate tow vehicle (2500HD). That may have something to with his success as well as the fact that he is an experienced driver. (He is also a very good writer)
07-21-2013, 08:24 PM
#2222
Biloxi
, Mississippi
Tell your friend thank you and very well worded write up.
MICHAEL
07-22-2013, 06:24 AM
#2223
1987 25' Sovereign
Oregon
, Ohio
Just got back from a 100 mile jaunt over the weekend. The Andersen hitch, Quick-bite coupler and the EZ electrical connector are working great together.
I agree with AWCHEIF above, thank you for the write up.
07-22-2013, 07:05 AM
#2224
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
WOW, a very well written, thoughtful and comprehensive write up. And a positive one too. I guess there's hope for US Anderson users yet. I hope to do a conversion to the QB coupler in the next month or so myself. At that time I will carefully inspect the original Atwood coupler, after removal, to see if 13 years of use and recently with about 8k miles of Anderson use has caused any concerns.
See ya'll on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
07-24-2013, 03:52 PM
#2225
2012 16' Sport
San Bernardino
New chains coming
Ordered new chains to go with my new quickbite coupler. I found that I was almost 3 links short reaching the triangular plate under the new coupler. So instead of adding a screw open link I ordered 2 new chains with 3 extra links. Anderson is sending them to me at cost. Don't have the final price yet, but it's estimated to be around $30 apiece. That's $28 for the standard chain plus a couple bucks.
Not long ago I bent one of the adjustable screws when using a trailer mover, so I wanted to replace that one anyway. I figure I am going to all this trouble to get it set up correctly, I might as well spring for the chains. Will not have to worry about some vandal unscrewing them when I am not looking, as well.
07-29-2013, 12:03 AM
#2226
1974 Argosy 20
Kooskia
, Idaho
Another way to attach brackets
I have had an Andersen hitch for over a year now, and used it very successfully on my '74 Argosy 20'
I have a new 20' FC with a 5 inch frame, so I could not use my older brackets and had to order new ones.
Someone posted an idea of mounting the brackets with the set screw on the bottom on the chain tube side, and on the top on the inside of the frame. They said it would prevent the rotation that has been experienced. Add to that the fact that I don't want to weld anything on to my frame, so I can easily go to another hitch chain bracket if I want to. So, I thought that was a good idea.
In addition, the problem with the set screw system is that it is very very hard to tighten to the "three full turns" that Andersen suggests, and on the inside the battery box on my new rig prevents me from accessing the screw at all. So, I decided to pre thread the set screws into the brackets, then place the brackets against the frame and use the big bolts to squeeze the brackets with the set screws into the frame, dimpling the frame in the process with the set screws.
Well, it worked like a charm! I actually pre screwed the set screws (one on top, one on the bottom) in two turns from flush (three is too much). Then tightening the brackets onto the frame forced the set screws into the frame with one on the top on the inside, the other on the bottom on the outside. The brackets do not rotate on the set screws and remain vertical.
See the attached photo to understand the top/bottom set screw idea. Clamping the frame with the set screws already extended can't be photographed but I think you can understand what I did and how it would work.
I have only towed 200 miles with it so far, but there is no indication of bracket movement, they are both vertical as they were when I put them in place.
Thanks to the poster who suggested the top/bottom set screw idea, and I think my pre set and squeeze is another improvement to make the install much easier, and this avoids welding.
07-29-2013, 12:54 AM
#2227
1974 Argosy 20
Kooskia
, Idaho
In love all over again
I was one of the early users of the Andersen hitch, and have made a number of posts to this thread. I like the hitch very much.
I recently got my first new Airstream, a 2014 FC 20'. It has a 5 inch frame so my older 4 inch frame brackets would not work and I had to order new ones. In the mean time, I picked up my new FC, and took it on two trips of over 1500 miles total using the old Reese hitch system I had used for 35 years. I selected 500# bars from my "stash" and had a good time with the new rig.
But then I got the Andersen brackets and mounted them (see post above). As soon as I took it out I realized how nice the ride was with the Andersen, in comparison to the Reese, how quiet, and how the rig handles as one unit, not two. The Reese is not bad mind you, but the Andersen is certainly superior in the way it feels, rides and sounds.
I don't think that many have had the experience of going back to a normal spring bar hitch after having used the Andersen, then back to the Andersen. BTW, last summer I towed about 7000 miles with the Andersen and my Argosy 20'. This year with the new AS, I made the change after about a month of the old system. The Andersen is superior.
Yes, I understand that there will be a time I need to change the coupler on the trailer, but I will monitor that carefully. The Argosy got a new coupler prior to the recommendation that one not use the Atwood 880xx series of couplers, so it had a new Atwood installed, and no wear has shown up in the first 7000 miles of use with it. I do keep the ball lightly greased which I think helps with any potential wear on that coupler.
Today I did the scale thing with the Andersen. I will report the numbers when I get them all sorted out.
Attached are photos of the Reese and the Andersen hitch ups with my new AS.
07-30-2013, 11:12 AM
#2228
1974 Argosy 20
Kooskia
, Idaho
Scale results for my rig with Andersen hitch
Scale numbers with my Andersen hitch.
The rig: 2012 Jeep Grand Cherokee Overland, full air suspension (no springs, no shocks) loaded as I travel, large toolbox in rear, plus 14 gal of extra water (small tank in AS). Air suspension turned to "off" while all numbers were taken, as it has a mind of it's own at times.
The AS: 2014 Flying Cloud 20, loaded as I normally travel, full propane tanks, full water tank (behind axle) empty holding tanks.
The scales: Idaho Department of transportation scales are left on when not weighing trucks, so they are available for public use. The one I used had two platforms, with electronic readout for each. The numbers were then read and recorded, no tickets are available. I got back into the drivers seat whenever I was reading the weights.
Results:
Jeep alone: Front: 2940
Rear: 2920
AS alone: Axle: 4240
Tongue: 680
Hooked up but chains unloaded
(no weight distribution) Front: 2640
Rear: 3900
Trailer axle: 4240
Hooked up, 6 threads showing
Front: 2740
Rear: 3780
Trailer axle: 4300
Hooked up, 8 threads showing
(my final decision)
Front: 2800
Rear: 3640
Trailer axle: 4360
BTW, the Jeep ratings are: Front: 3200
Rear: 3700
The hitch is capable of doing more distribution, I simply did not test it at higher levels. The bushings now show a very slight bulge when 8 threads show on the adjustment.
And, it tows beautifully, solid as if it was one unit, not two connected together.
07-30-2013, 11:33 AM
#2229
2012 16' Sport
San Bernardino
Very nice. Congrats on the new Stream, Idroba!
07-30-2013, 01:39 PM
#2230
K.C.
, Missouri
Results:
Rear: 2920
Tongue: 680
Rear: 3900
Trailer axle: 4240
Front: 2740
Rear: 3780
Trailer axle: 4300
(my final decision)
Front: 2800
Rear: 3640
Trailer axle: 4360
Rear: 3700
The Jeep has no shock absorbers ? And no springs at all ? That's interesting, I'll have to crawl under one to see the layout.
From your numbers, it sounds like your results as for weight distribution fit in with what everybody has been saying about how it works.
Glad to hear you are happy with the towing experience.
07-30-2013, 02:09 PM
#2231
Harlingen
...snip.......
Nice report and your summary says it all. Thanks for contributing.
07-30-2013, 03:07 PM
#2232
2012 25' Flying Cloud
Battle Lake
Results:
Rear: 2920
Tongue: 680
Rear: 3900
Trailer axle: 4240
Front: 2740
Rear: 3780
Trailer axle: 4300
(my final decision)
Front: 2800
Rear: 3640
Trailer axle: 4360
Rear: 3700
I like your Jeep/Airstream combo very much, however with Andersen weight distribution applied as you like it, the trailer still added 720# to the Jeep rear axle and lightened the front axle by 140#. How can that be good weight distribution, even with a relatively light trailer?
Mine towed beautifully with the Andersen too, but I realized when I came on wet roadways and gusting side winds it is definitely not one unit, and probably would have towed nearly as well without the Andersen.
Please know I am not trying to be personal here, but am trying to understand why the Andersen would be recommended with this poor weight distribution performance. How can that even be considered safe towing?
doug k
07-30-2013, 03:25 PM
#2233
Princeton
, New Jersey
Idroba
Those are great numbers. You and the wife get back in the front seat and that front axle will be fine. I real like the amount of weight transferred to the trailer. That is a function of the shorter coupler to axle ration but clearly demonstrates the hitch is functioning.
I just came in from an afternoon of installing an Andersen on my daughter's trailer. Well I say that most of the time so far was spent on painting the tongue in preparation.
I do have a question on the real axle suspension on the Jeep. Are they individual A frames or a solid axle with a sway bar. if it is a solid axle and no sway bar I would consider looking into the after market for one to stiffen up the rear against sway. Not from thew trailer but just a general improvement to the Jeep.
Another comment.
The new Andersen manual has incorporated several of the comments that have been presented on this Forum.
2004 Excursion 4x4
07-30-2013, 03:29 PM
#2234
St. Catharines
, South Western Ontario
doug k
and...... with all due respect to idroba the Reese setup he was using is very poor (IMHO). The ball is at least a foot past the bumper and dollars to doughnuts there is a lot of flex* going on with that set up. Also I'm just seeing a basic WDH and no sway control. No wonder it was not working well.
Note: With a flexing receiver it is difficult to get the weight to transfer effectively.
07-30-2013, 04:02 PM
#2235
Princeton
, New Jersey
Road Ruler
You are correct. He did not have any sway control with thta Reese system and yes the longer shank probably amplified the porpoising that is inherent to a spring bar system. But FLEX in the receive. If you can show me FLEX in a receiver I will show you a cracked or failed receiver.
Given that why would you question his new and improved system. It has done away with the porpoising, added effective sway control, improved hitching time, reduced noise, eliminated the need to readjust periodically due to trunnion ware, and save on his dry cleaning bill.
2004 Excursion 4x4
07-30-2013, 04:09 PM
#2236
Salem
, Oregon
Hi, I understand that with some air suspension systems there are no metal springs, just air bags, but I don't believe that your Jeep has no shocks.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-30-2013, 04:38 PM
#2237
St. Catharines
Originally Posted by HowieE
Road Ruler
The point is that we know roughly 80% of the rigs on the roads are not connected to their full potential. Idroba's Reese is the classic example. If they were set up properly they would work soooo much better........like ours.
Ball is as close to the back bumper as possible.
The properly adjusted Reese dual cam with right sized bars, (with built in sway control) works great.
The porposing stopped when we replaced the worn out rear shocks on the vehicle.
The receiver platform was reinforced to prevent the common and dreaded flexing.
07-30-2013, 05:03 PM
#2238
Salem
, Oregon
Hi, now that's close.
07-30-2013, 06:32 PM
#2239
St. Catharines
Yes Bob, and Can Am even got it closer on our Infiniti. Check the cut out on the bottom of the license plate ......
07-31-2013, 05:18 PM
#2240
1974 Argosy 20
Kooskia
, Idaho
I only presented my information to you, other than saying that my rig tows exceptionally well, and I like it, I leave the argue up to others.
I am sitting in Cabin Creek NF campground, off I 90 near St. Regis MT. Last night I was on the St. Joe river in Idaho, at another NF campground. I went over a pass between Idaho and Montana that I had never been over, the Montana side was gravel for 20+ miles. I have the ding marks in my segment protectors already. The point is I use my AS and enjoy it. Having had about 15 of them over the past 35 years, and having towed them somewhere between 150,000 and 200,000 miles, I am not a newbe to how a trailer feels behind a tow rig. How many of you have been north of the Arctic Circle with your Airstream on the Dempster Highway? I have.
Some comments on the various responses to my posts.
The Jeep total Air Suspension system has no shocks or springs. What holds up the rig looks like a strut on all 4 corners, but it has some kind of a compressed nitrogen air system which holds it, and is managed by computers. The rear suspension is a wishbone looking thing. The computer has a mind of it's own at times, but it is very comfortable and so far is a great towing rig. A bit hard to set up until you understand how to turn it off so it does not fight the WD features of the hitch. Once set up, it behaves like any other spring suspension system. I have about 17,000 miles on it, with well over half of them towing.
The hitch box on the GC is high, and my old Reese stinger bar would not go low enough, so I had to buy another bar for my temporary Reese use, and what you saw was what was available locally when I needed it. No, not an optimum length, but realize that the Jeep has a very short rear overhang to begin with. Also understand that I have a lot of tow experience (see above) and the Reese has been used for over 30 years, on trailers up to 25'. I know what the Reese feels like. I used a friction sway control for a while, but found it simply made no difference, and was just one more thing to attach and detach. I have never had a trailer sway issue, not once, ever. Mud and slime in the Yukon, yes, but not on a dry road or a gravel road.
The Andersen re distributes enough weight so I am within the axle rating of the Jeep, and it tows exceptionally well. BTW, the Jeep also has some kind of electronic sway control system, which to my knowledge has never activated.
This is an Andersen users thread, I am an Andersen user, and report what I observe and have found.
My only grumble is: For those who wish to "shine" with "IMHO" I always wonder what the H stands for? Humble? Half Baked? Honest? Just say it is your opinion, and let it go at that. We know what opinions are, like mine on the Andersen, an opinion which is based on certain experiences. Not fact, but worth considering.
Oh, Howie, no wife here, so the additional front seat weight is just my junk piled over there...LOL.
Currently Active Users Viewing This Thread: 17 (0 members and 17 guests)
