Old 11-06-2011, 07:32 PM   #1
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
Teflon coated Hitch Ball?
I am SOOOO sick of black sticky grease on any pair of pants I wear around our hitch!! I've seen what looks like teflon coated hitch balls at my local trailer store. Anyone tried one? Opinions?
25' Safari
EazLift WD hitch with sway control
'07 Tundra 5.7 TV
Don
DJW is offline   Reply With Quote
Old 11-06-2011, 08:22 PM   #2
dznf0g's Avatar
Oswego , Illinois
Never seen one, but I can't imagine it would be very durable, based on all the pots and pans I've had.
-Rich-
Old 11-06-2011, 08:25 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
You know, a friend of ours does something different (that I haven't tried yet): He cuts a chunk out of a plastic milk bottle and places it over the ball. Lowering the hitch over the ball forces the plastic around the ball, and the plastic serves as the lubricant.
Lynn
WBCCI 21043
Old 11-06-2011, 08:40 PM   #4
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Try a baggie...
After a suggestion at a recent AS resto rally in ABQ, we started using a plastic baggie each time we connect (over the ball) . I keep a box in the back of the TV and easy to get at. After the haul and we disconnect, into the trash. Not real green but neither is grease. To date, no problems, ball and inside of trailer hitch look good.
Works for us...
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 11-06-2011, 09:10 PM   #5
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Some good ideas here. I am intrigued about the plastic milk bottle idea. Anyone else tried something like that?
Living life on the Road
deauxrite is offline   Reply With Quote
Old 11-06-2011, 09:14 PM   #6
65CV's Avatar
Western , Massachusetts
McLube
Has anyone tried the old favorite of sailors -- McLube?
John
65CV is offline   Reply With Quote
Old 11-06-2011, 09:18 PM   #7
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
It was common in sailboat mast bearings... where the mast rotates, to place a disc of plastic as a bearing.
Milk cartons, coffee can lids etc. were used when the offical type where not available.
Very simular as it would deform to the shape needed, and act as a bearing
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-07-2011, 04:52 AM   #8
r carl's Avatar
Lin , Ne
I just use this stuff with good results.
http://www.le-inc.com/products/documents/9200_flyer.pdf
Old 11-07-2011, 05:42 AM   #9
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
will that stuff ruin a pair of light colored geezer Dockers if you brush against the hitch? I can see that ground up plastic milk bottle would probably brush right off.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 11-07-2011, 06:24 AM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Just wipe it off and put a cover on it.
Old 11-07-2011, 06:28 AM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I use the baggie method mentioned above to keep the hitch ball covered while stored. I use white lithium grease for lubing. I wipe the grease off the ball with a paper towel every couple of tows to keep the grit off of it as much as possible. There is less black on hands and clothing, but still some.
Alan
Old 11-07-2011, 06:40 AM   #12
SteveH's Avatar
Common Sense , Texas
I use a totally different lubricant, and method. I use a good quality chassis grease, injected thru a grease fitting I installed in the hitch before I hitched it to the ProPride hitch, and the trailer hitch never comes off the ball.
Regards,
Steve
Old 11-07-2011, 08:17 AM   #13
65CV's Avatar
Teflon Disc
I won't be traveling for a couple of months, but the disc idea is worth a try.
This is the teflon disc that I use on the boat, should anyone be interested. It's about a 2 1/2" diameter disc.
Teflon Mast Disc for the Laser®
John
Old 11-07-2011, 10:26 AM   #14
DJW
DJW's Avatar
2004 25' Safari
Hmmm. In looking at the hitch ball after unhitching, it looks like it bears the weight in a narrow (1/4" of so) band about 1/3 of the way down from the top. How do you get/keep the plastic to form around that??
Don
Hitch advice - Safari Sport 22 nesvt Hitches, Couplers & Balls 17 12-16-2011 04:50 PM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Adjusted the ball and hitch today Lucky Dog Hitches, Couplers & Balls 15 03-30-2011 11:03 AM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
