Old 11-07-2011, 11:03 AM   #15
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Originally Posted by elfirebob View Post
After a suggestion at a recent AS resto rally in ABQ, we started using a plastic baggie each time we connect (over the ball) . I keep a box in the back of the TV and easy to get at. After the haul and we disconnect, into the trash. Not real green but neither is grease. To date, no problems, ball and inside of trailer hitch look good.
Works for us...
Our 10 year old daughter suggested that to us (and I don't think she's been reading this forum) and it works well. I also use them to cover the greasy part of the trunnion bars when I remove them; keeps me clean and them clean.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 11-07-2011, 02:47 PM   #16
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
A mechanical engineer friend of mine have been using square pieces of aluminum foil for years. Says it works great. Just keep a small supply of pre-cut foil available for each time you hitch-up.
JStanley is offline   Reply With Quote
Old 08-26-2013, 01:40 PM   #17
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I know that the teflon covered balls exist but I cannot find them. Searched the internet but still know luck.
TinCan
graysailor is offline   Reply With Quote
Hitch advice - Safari Sport 22 nesvt Hitches, Couplers & Balls 17 12-16-2011 04:50 PM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Adjusted the ball and hitch today Lucky Dog Hitches, Couplers & Balls 15 03-30-2011 11:03 AM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
