Old 04-16-2016, 01:45 AM   #57
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, jack the trailer up and put jack stands at the outer ends of the front axles, and inch by inch, move the jack stands forward under the frame until you have zero tongue weight. Now you have a point of where to load your trailer to lower or raise your tongue weight.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-16-2016, 08:07 AM   #58
dznf0g's Avatar
Oswego , Illinois
I re-read OP's final question about "no effect on TW" and realized I was completely misunderstanding his question...or what he was trying to do. If he is wanting to know where to place individual items and how the placement affects TW, here is the formula.
Name:	weight dist pic.png
The above is the only graphic I had...so pretend the Suburban is my AS. The rear axle is the point midway between the AS axles and the front axle of the Suburban is the tongue jack on the AS. I use tongue jack as that is where most folks weigh the TW....but realize that if you want actual TW, defined as the weight resting on the ball, you will have to do a bit more math.
Assume a dead flat surface and an absolute level AS.
CGA = Distance from placement of object from the midpoint between the AS axles (fulcrum in our discussion)
WB = distance from jack to fulcrum
CGA divided by WB X100% = Percentage of weight of object on the jack
As an example with My AS:
WB = 214"
If I place a 150 pound object 24" in front of the fulcrum:
(24 divided by 214) X 100 = 11.2% is added to jack and 88.8 % is added to fulcrum..or 16.8 lb to jack; 133.2 lb to fulcrum
If I place a 150 pound object at the fulcrum:
(0 divided by 214) X 100 = 0% is added to jack and 100% is added to fulcrum..or 150 lb added to fulcrum and 0 lb added to jack
If I place a 150 pound object in the AS trunk 96" behind the fulcrum:
(-96 divided by 214) X 100 = -44.9% off the jack and 144.9% is added to fulcrum...or 67.4 lb REMOVED from jack and 217.4 lb added to fulcrum.
Maybe that's what you were looking for or maybe not??????
-Rich-
Old 04-16-2016, 09:10 AM   #59
clamb's Avatar
2002 25' Classic
Portland , Oregon
Attachment 260843
WB = 214"
That is exactly it. The spreadsheet has 14 places where cargo can be located. For each location the distance to the tongue(ball) and the weight is entered. The ball-to-axle distance (what I was after) is entered elsewhere, and the spreadsheet calculates how much weight goes to the axle and how much goes to the tongue.
clamb is offline   Reply With Quote
Old 04-16-2016, 12:04 PM   #60
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How does this "spreadsheet" work when you are traveling down the non "dead flat" surface at 60-75mph? Where is that place on the road where the TV and coach are perfectly level?
I believe this is one of those places that "it works on paper" but in the "real world" the data won't match up.
And how do you prove your theory while the rig is moving?
How do you say to the authorities. "But officer, my spreadsheet says this can't happen" or "should not have happened"
Just sayin'
Old 04-16-2016, 01:20 PM   #61
clamb's Avatar
2002 25' Classic
Portland , Oregon
Just sayin'
Not using it for trailer in motion- just using it to get a good estimate of what my axles would weigh at a scale, while stopped and level. For me, that scale is too far away and my driveway is too hard to get in and out of. If I can get the spreadsheet to come close to actual scale weights, then I am using it.
I am leaving this thread with this post, as I arrived at the answer I needed. I thought I worded my OP well enough so it didn't stretch out for 5 pages and I'm sorry that happened.
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Pivot Point Projection handling in marginal conditions Gsmblue Towing, Tow Vehicles & Hitches 30 08-23-2015 06:57 AM
Driver seat does not pivot 180 dateem Land Yacht/Legacy Motorhomes 11 11-12-2014 02:32 PM
Single vs. Tandem and Smallest tandem axle JimGolden Airstream Trailer Forums 27 11-29-2009 09:04 PM
Wiper Motor Pivot Shaft realpank Argosy Motorhomes 3 08-05-2008 06:35 AM
