Old 02-26-2006, 06:52 AM   #1
1978 29' Ambassador
bethesda , Maryland
Sway on 28' Ambassador
Hello Airstreamers...
Had a little sway last weekend on our maiden voyage...I had little to none when I picked up my unit in NJ and towed it to Maryland. Recently I "heavyed up" the rear of my Suburban by adding additional leaf springs which raised up the rear noticeably..I also re-adjusted the ball to the recommended 19 1/2" height and I do have a Reese weight distribution Hitch...Do I need to go with Anti Sway control like a Reese HP dual cam anti sway control? Thanks in advance for any advice you more experienced Airstreamers may have for me!!
popeyedoyle1 is offline   Reply With Quote
Old 02-26-2006, 07:13 AM   #2
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Sway is caused by a variety of factors. Sway is the ability of the trailer to move the rear of the tow vehicle over the axle of the tow vehicle. It can be caused by improper loading of the trailer (not enough weight on the tongue), but it can also be caused by low or unequal tire pressures on either or both the tow vehicle and the trailer.
So, presuming that your tire pressures are at or near max (especially on the tow vehicle), and since you didn't experience sway without the suspension mod and have it now, and since you mentioned the "tongue height" issue, my guess is that you probably are now towing in a "tongue high" attitude. New, your tongue height was probably 19". As a result of the start of axle rubber failure, your actual tongue height may now be as low as 17", but if you have it set at 19" you could be as much as 2" out of balance tongue high. The shift in weight being as much as 2" tongue high might very well be enough to cause sway issues.
Measure your frame at the tongue and bumper while the trailer is on level ground to make sure it's level. The distance from the ground to the top of the hitch connector will be your actual tongue height now.
If, in fact, the new measurement is around 17" when the spec sheet says it ought to be 19", you're probably getting due for an axle replacement, and that wouldn't be unusual for a trailer that's over 20 years old.
The answer to your last question about the dual cam setup... I'd certainly recommend it AFTER you figure out why the trailer is swaying. Sway controls mask the bad stuff that happens until it can't mask it any more. Then you're REALLY in trouble. If you sort out your issues BEFORE you use sway control, then the sway control merely gives you an added measure of safety.
Good luck and keep us posted!
Roger
electrical diagram for a 1966 Ambassador 28 foot ups guy Electrical - Systems, Generators, Batteries & Solar 2 09-10-2004 04:24 PM
Square footage (floor) 1967 Ambassador flamingo-kid1 General Interior Topics 1 04-18-2004 09:48 PM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
What is an Ambassador Model dinoburb Airstream Trailer Forums 1 01-01-2003 07:56 PM
