Originally Posted by crabbey1
I read somewhere that the Sway Control Bar doesn't stop sway but it lessens the effects of the sway once it happens. Is there a product that actually can prevent sway?
The Sway Control Bar works by trying to prevent the TT from swinging relative to the TV. It does this by using the friction force generated by the bar multiplied by the offset distance between the big ball and the little ball to produce a yaw-axis torque between TV and TT.
The magnitude of available swing-preventing torque is limited by the magnitude of friction force which can be generated by the sway control bar. If the lateral forces on the TT generate a torque which exceeds the available sway control torque, the TT will swing relative to the TV. But, the sway control still is producing its swing-resisting torque which will cause the amplitude of the sway oscillations to be reduced.
So, in short, a sway control bar prevents "sway" -- up to a point. Beyond that point, the bar works to reduce the amplitude of the "sway".
Ron
P.S. I loved "mstephens" s
s s s depiction of increasing amplitude of sway oscillation.
In the UK, "sway" is referred to as "snaking".
