Old 07-05-2018, 04:01 PM   #1
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Cool Sway Control Only possible for my small Vintage Trailer?
I would like to find out if there is a Sway Control system available without the usual weight distribution component for use with my small Vintage Trailer?
The 2800 pound trailer will be towed behind a 2016 RAM 2500 with rear air leveling with an "alt trailer height" option. So weight distribution should not be necessary when towing a trailer of this size. I'd still like have anti-sway.
Does anyone know of a stand alone sway control system that might fit the bill?
SilverWind is offline   Reply With Quote
Old 07-05-2018, 04:10 PM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Use this:
https://www.walmart.com/ip/CURT-Sway...&wl13=&veh=sem
vintagemotor is offline   Reply With Quote
Old 07-05-2018, 04:18 PM   #3
2007 22' International CCD
You would also need the sway control ball mount from the same page. That lets you couple the friction anti-sway bar to the tow vehicle. The other end mounts on the trailer A-frame.
Note, if the drop on the ball mount is not right, it's going to possibly take some modifying and welding to get everything lined up right so the trailer tows in a level attitude.
Old 07-05-2018, 09:41 PM   #4
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
https://www.google.com/url?sa=i&rct=...30931062432031
This is what I use on our 19FC
It mounts onto your ball mount, no welding required
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 07-05-2018, 11:05 PM   #5
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Why not carry it in the bed of the truck?
Laurence
LAWBC is offline   Reply With Quote
Old 07-06-2018, 06:50 AM   #6
Lakes Region , New Hampshire
There are a couple electronic sway control devices, mounted in/on the trailer itself that control the brakes separately, Tuscon Sway Control is one. Not cheap, but effective.
"Anyone, who actually fought for it, would know that the freedom we fought for, was so no one could tell us what we have to do." -me
RandyNH is offline   Reply With Quote
Old 07-06-2018, 11:25 AM   #7
1972 23' Safari
Phoenix , Arizona
Check you truck manual....it may have built in sway control. Our Titan XD has this and your turck may also. It could be all the extra you would need.
Lensman is offline   Reply With Quote
Old 07-06-2018, 01:22 PM   #8
Terre Haute , IN
Sway control
I have not used this but may work for you.
Andersen 3350 No-Sway Weight Distribution
Terry4470 is offline   Reply With Quote
Old 07-06-2018, 01:43 PM   #9
DBW
2018 Basecamp
Charleston , South Carolina
sway control
Take a look at the Reese Pro Series 83660 Value Friction Sway Control. I use this on my Basecamp
DBW is offline   Reply With Quote
Old 07-06-2018, 02:31 PM   #10
helmsman's Avatar
1967 22' Safari
Long Beach , California
Smile
[QUOTE=SilverWind;2124359]I would like to find out if there is a Sway Control system available without the usual weight distribution component for use with my small Vintage Trailer?
Hi Silverwind:
My vintage 1967 22' Airstream weighs only a few hundred pounds more than yours. I have used this Reese sway control for over 50 years on this trailer. It looks just like the sway control "vintagemotor" shows in his Walmart hyperlink.
AlinCal hyperlink shows the Reese Sway Control with an Adapter. I don't have the adapter because I don't need it. I only use one Reese sway controller because my trailer is light enough I don't need the 2nd one.
Should your trailer start to sway a light application on your trailer brake controller will put a small drag on your trailer which will help to straighten out the sway.
Take your time and enjoy the scenery!
helmsman is offline   Reply With Quote
Old 07-06-2018, 05:12 PM   #11
SilverWind's Avatar
1968 17' Caravel
Not sure that I understand your comment.
Old 07-06-2018, 06:43 PM   #12
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
I think that was tongue in cheek.
Maybe it means your trailer is small and your truck is large so put the trailer in the bed of the PU.
Even though emojis are silly they help sometimes when dry whit, humor and sarcasm don't translate over to the written word.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-06-2018, 07:56 PM   #13
SilverWind's Avatar
1968 17' Caravel
Ha Ha....yes. I'm sometimes guilty of the same dry sense of humor.
Old 07-06-2018, 07:58 PM   #14
SilverWind's Avatar
1968 17' Caravel
I'm considering the Reese Pro 83660. I ran it on a 2012 International 19. I need to determine if the frame rail width is sufficient and the 24 ball center to center clearance is possible......form afar.
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 06:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 11:05 AM
Can 2011 Toyota Sienna tow a Bambi 16' with Sway control only? rjd111 Towing, Tow Vehicles & Hitches 27 11-03-2013 09:16 PM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 06:48 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 09:28 AM
