Old 06-07-2015, 10:31 AM   #1
Gordon
2014 30' International
Scarborough , Ontario
Sway control bars too tight?
I have a pair of Husky Dual Brake Pad Friction Sway Control bars on my 30' International and when I turn even slightly they creek and groan! It gets everyone's attention, unfortunately!
Have I tightened them too much? If so, what is the correct way to gauge the right tension?
Please and thanks from a newbie.
Gmoore is offline   Reply With Quote
Old 06-07-2015, 10:58 AM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Your alternative is a loose sway bar.
A loose sway bar is a recipe for eventual disaster.
My suggestion is to tighten the bar to the point of being tight and then back off a quarter turn.
I see where Husky recommends left and right for trailers over 24 ft in length; which I would think to be slight overkill, but that's just my opinion.
In any event this is a circumstance where a little creak and groan coming from the sway bar should be considered a GOOD thing.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 06-07-2015, 11:33 AM   #3
1986 31' Sovereign
Miami , Florida
All the friction pad sway controllers "talk", it is especially noticeable at low speed. Seems REALLY loud when you are exiting the campground the long way...
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 06-07-2015, 12:52 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Normal operation for that design.
MICHAEL
Old 06-07-2015, 01:09 PM   #5
Vermilion , Ohio
My Reese Weigh distribution hitch does the same thing, a little bit of grease helps a lot.
Miko38 is offline   Reply With Quote
Old 06-08-2015, 10:49 AM   #6
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
If your Reese setup uses the Dual-Cam sway control bars with the crooks in the ends, Reese recommends that you do not grease the contact points between the crooks and the cam surfaces. Greasing those areas will reduce the ability to control sway. If you're greasing the contact points at the hitch end of the round bars or trunnion bars, that's OK.
My Dual-Cam sway control setup emits loud pops and bangs when making sharp turns at low speed or when backing. We often stop and drop the bars before maneuvering into a tight spot, and wait to hook them up until we're out in the open before hitting the road.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 06-08-2015, 11:07 AM   #7
2018 33' Classic
Newport , Pennsylvania
Maybe you would want to consider a Hensley Hitch they do not use friction for sway control.
More expensive, but considering your safety and the value of the trailer and tow vehicle I think it s money well spent
EarlM is offline   Reply With Quote
Old 06-08-2015, 11:18 AM   #8
1986 31' Sovereign
Miami , Florida
The OP specified that he had dual brake pad friction sway control. Standard issue metal bar sliding fore and aft between slabs of brake pad material. The rigidity is controlled by tightening/loosening a nut/lever combination.
So, NO grease -- it would defeat the whole purpose.
The noise is only noticeable and annoying at low speed, is normal to this type of device and if you stop hearing it, something is wrong.
Mike
Young, lovely bride
Old 06-08-2015, 11:25 AM   #9
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'll contribute to the melee here by suggesting that there are many better options than friction-type sway control bars.
I like my Reese dual cam; otheer people like the Hensley or the Equalizer brands as well. I'm sure there are other good options. 30' is a lot of weight to handle back there.
Old 06-08-2015, 11:41 AM   #10
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
We have the same setup with two of these Husky units on my 20. They DO groan! I like the idea of installing them at the entrance and exit of campground, less embarrassing!
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 06-08-2015, 11:42 AM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I had a Eaz-Lift with a friction sway control bar. I would tighten as tight as I could, and then back off 1/4 turn.
They will sound like the wreck of the Edmund Fitzgerald or a trailer load of zombies...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-08-2015, 11:47 AM   #12
1996 25' Excella
Tillsonburg , Ontario
Gordon has what he has! As long as he sets up the tension sufficiently to control sway he should be OK. On my 89 -25 ft I did not hook up the anti-sway becauseI felt it was just fine. Andy Thompson told me I would never miss the anti-sway until I had an emergency and then I would be glad I had it. I always ran with it after that and found the rig was just so much more stable in the wind and passing trucks. Mine always creaked at slow speeds. We did have that 'emergency' in Texas and came out in one piece, so the friction bar does work.
JCW
JCWDCW is offline   Reply With Quote
Old 06-08-2015, 12:31 PM   #13
AWCHIEF's Avatar
Images: 33
I think any one that goes off topic by suggesting that someone buy a hensley/pp should have to write the check for at least half the price.
MICHAEL
Old 06-08-2015, 12:55 PM   #14
m.hony's Avatar
2013 30' Classic
I didn't read every post-
Was that suggested or implied?
TAC #MS-10
Airforums #70955
Brakes, How tight is too tight? rhutson Brakes & Brake Controllers 5 03-15-2012 12:48 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
How tight is too tight? Alden Miller Awnings 16 06-01-2006 09:09 PM
