06-07-2015, 10:31 AM
Gordon
2014 30' International
Scarborough
, Ontario
Sway control bars too tight?
I have a pair of Husky Dual Brake Pad Friction Sway Control bars on my 30' International and when I turn even slightly they creek and groan! It gets everyone's attention, unfortunately!
Have I tightened them too much? If so, what is the correct way to gauge the right tension?
Please and thanks from a newbie.
06-07-2015, 10:58 AM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
Your alternative is a loose sway bar.
A loose sway bar is a recipe for eventual disaster.
My suggestion is to tighten the bar to the point of being tight and then back off a quarter turn.
I see where Husky recommends left and right for trailers over 24 ft in length; which I would think to be slight overkill, but that's just my opinion.
In any event this is a circumstance where a little creak and groan coming from the sway bar should be considered a GOOD thing.
06-07-2015, 11:33 AM
1986 31' Sovereign
Miami
All the friction pad sway controllers "talk", it is especially noticeable at low speed. Seems REALLY loud when you are exiting the campground the long way...
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
06-07-2015, 12:52 PM
Biloxi
, Mississippi
Normal operation for that design.
MICHAEL
06-07-2015, 01:09 PM
Vermilion
, Ohio
My Reese Weigh distribution hitch does the same thing, a little bit of grease helps a lot.
06-08-2015, 10:49 AM
Slowpoke
2012 27' Flying Cloud
Portland
, Oregon
If your Reese setup uses the Dual-Cam sway control bars with the crooks in the ends, Reese recommends that you do not grease the contact points between the crooks and the cam surfaces. Greasing those areas will reduce the ability to control sway. If you're greasing the contact points at the hitch end of the round bars or trunnion bars, that's OK.
My Dual-Cam sway control setup emits loud pops and bangs when making sharp turns at low speed or when backing. We often stop and drop the bars before maneuvering into a tight spot, and wait to hook them up until we're out in the open before hitting the road.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
06-08-2015, 11:07 AM
2018 33' Classic
Newport
, Pennsylvania
Maybe you would want to consider a Hensley Hitch they do not use friction for sway control.
More expensive, but considering your safety and the value of the trailer and tow vehicle I think it s money well spent
06-08-2015, 11:18 AM
1986 31' Sovereign
Miami
The OP specified that he had dual brake pad friction sway control. Standard issue metal bar sliding fore and aft between slabs of brake pad material. The rigidity is controlled by tightening/loosening a nut/lever combination.
So, NO grease -- it would defeat the whole purpose.
The noise is only noticeable and annoying at low speed, is normal to this type of device and if you stop hearing it, something is wrong.
Mike
Young, lovely bride
Dismissive cat
06-08-2015, 11:25 AM
1978 25' Tradewind
Metro Phoenix
I'll contribute to the melee here by suggesting that there are many better options than friction-type sway control bars.
I like my Reese dual cam; otheer people like the Hensley or the Equalizer brands as well. I'm sure there are other good options. 30' is a lot of weight to handle back there.
06-08-2015, 11:41 AM
2019 25' International
Traverse City
, Michigan
We have the same setup with two of these Husky units on my 20. They DO groan! I like the idea of installing them at the entrance and exit of campground, less embarrassing!
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
"Don't let perfect be the enemy of better."
06-08-2015, 11:42 AM
2013 30' Classic
Greenwood
, Mississippi
I had a Eaz-Lift with a friction sway control bar. I would tighten as tight as I could, and then back off 1/4 turn.
They will sound like the wreck of the Edmund Fitzgerald or a trailer load of zombies...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-08-2015, 11:47 AM
2012 23' FB International
Woodstock
, Ontario
Gordon has what he has! As long as he sets up the tension sufficiently to control sway he should be OK. On my 89 -25 ft I did not hook up the anti-sway becauseI felt it was just fine. Andy Thompson told me I would never miss the anti-sway until I had an emergency and then I would be glad I had it. I always ran with it after that and found the rig was just so much more stable in the wind and passing trucks. Mine always creaked at slow speeds. We did have that 'emergency' in Texas and came out in one piece, so the friction bar does work.
JCW
06-08-2015, 12:31 PM
Biloxi
, Mississippi
I think any one that goes off topic by suggesting that someone buy a hensley/pp should have to write the check for at least half the price.
MICHAEL
06-08-2015, 12:55 PM
2013 30' Classic
Greenwood
, Mississippi
I didn't read every post-
Was that suggested or implied?
TAC #MS-10
Airforums #70955
06-08-2015, 01:13 PM
Biloxi
, Mississippi
Yes, read the thread.
MICHAEL
06-08-2015, 02:14 PM
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area
, Michigan & Texas
Omg
Oil/Lube your 'Friction' sway bar! That's a sure route to failure - that noise you hear is proof it's doing its job. My hitch, set-up by Andy at CanAm RV, has two sway bars and 1400# Flat bars to control the STOPPING of my Panamerica - PERIOD! When you hitch up, leave the sway bars loose. Once you straighten the train up, then tighten the sway controllers. I tighten to full, then back-off 1/4 turn. Drive for a distance to see how much control and tightness there is as I change lanes. Based on this, I then make micro adjustment to the sway controllers. BE SAFE!!
06-09-2015, 01:47 PM
Vermilion
, Ohio
I could be wronge but On The Reese dual cam system the spring pressure is what keeps the trailer aligned and Reese does recommend some lubricant at the contact points. I will have to call them to be 100% sure.
Mike
06-09-2015, 02:07 PM
Vermilion
, Ohio
I called Reese and the only thing they recommend is a thin layer of vasoline on the contact point. On a friction control system you shouldn't ever grease that. Sorry about the confusion, I have to go out and remove some grease from my cams.
Mike
06-10-2015, 04:49 AM
Gordon
Scarborough
, Ontario
Thank you everyone for your help, much appreciated.
CanAm set up my unit so I am confident that my equipment is appropriate. I just forget the instructions I was given for tightness.
I'll leave the bars loose until I leave the campground tomorrow and then tighten them up when we are straight and back off a quarter turn. No grease on the pads!
We'll let it groan on the highway and allow the other members of the Blue Ridge Caravan some peace and quiet!
Thanks again
Gordon
06-10-2015, 10:54 AM
2013 30' Classic
Greenwood
, Mississippi
Sounds all advice given in one post-
Good luck and have fun!
TAC #MS-10
Airforums #70955
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
