Old 06-08-2015, 01:13 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by m.hony View Post
I didn't read every post-
Was that suggested or implied?
Yes, read the thread.
MICHAEL
Old 06-08-2015, 02:14 PM   #16
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
Omg
Oil/Lube your 'Friction' sway bar! That's a sure route to failure - that noise you hear is proof it's doing its job. My hitch, set-up by Andy at CanAm RV, has two sway bars and 1400# Flat bars to control the STOPPING of my Panamerica - PERIOD! When you hitch up, leave the sway bars loose. Once you straighten the train up, then tighten the sway controllers. I tighten to full, then back-off 1/4 turn. Drive for a distance to see how much control and tightness there is as I change lanes. Based on this, I then make micro adjustment to the sway controllers. BE SAFE!!
Urbanologist is offline   Reply With Quote
Old 06-09-2015, 01:47 PM   #17
Vermilion , Ohio
I could be wronge but On The Reese dual cam system the spring pressure is what keeps the trailer aligned and Reese does recommend some lubricant at the contact points. I will have to call them to be 100% sure.
Mike
Miko38 is offline   Reply With Quote
Old 06-09-2015, 02:07 PM   #18
Vermilion , Ohio
I called Reese and the only thing they recommend is a thin layer of vasoline on the contact point. On a friction control system you shouldn't ever grease that. Sorry about the confusion, I have to go out and remove some grease from my cams.
Mike
Old 06-10-2015, 04:49 AM   #19
Gordon
2014 30' International
Scarborough , Ontario
Thank you everyone for your help, much appreciated.
CanAm set up my unit so I am confident that my equipment is appropriate. I just forget the instructions I was given for tightness.
I'll leave the bars loose until I leave the campground tomorrow and then tighten them up when we are straight and back off a quarter turn. No grease on the pads!
We'll let it groan on the highway and allow the other members of the Blue Ridge Caravan some peace and quiet!
Thanks again
Gordon
Gmoore is offline   Reply With Quote
Old 06-10-2015, 10:54 AM   #20
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Sounds all advice given in one post-
Good luck and have fun!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-10-2015, 03:13 PM   #21
heavyjumbo's Avatar
2007 25' International CCD FB
Salisbury , Maryland
sway bar groaning on turns.
A solution for my sway bars (I have a Reese) was to put a thin coating of petroleum jelly on the bracket and the bar. Don't overdo it, just a little coating from time to time and presto my groaning bars now travel nice and quiet letting the Airstream show off.
heavyjumbo is offline   Reply With Quote
Brakes, How tight is too tight? rhutson Brakes & Brake Controllers 5 03-15-2012 12:48 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
How tight is too tight? Alden Miller Awnings 16 06-01-2006 09:09 PM
