Old 03-08-2008, 09:23 AM   #1
Raleigh , North Carolina
Sway, Big trucks, accidents?
Hi everyone! We're in the active shopping phase of airstream hunting and I have heard way too many stories from people lately about big trucks passing, sway, and people rolling the trailer & tv. Can someone please give me an idea of how common an issue this is?
A good friend of mine, who is very conscientious rolled her Suburban and trailer (non-airstream) this past summer. What can we do to lessen our chances of this happening?
Thanks for your thoughts!!
Liz
bakerliz is offline   Reply With Quote
Old 03-08-2008, 09:45 AM   #2
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Hi Liz, and welcome to the forums.
There are lots of threads here discussing sway control (use the Search tool to find them), but the bottom line is having a properly set up load equalizing hitch with sway control, a properly sized tow vehicle, and maintaining a safe speed are the answer. I use an Equal-i-zer hitch and tow around 62.5 mph. I have pulled my 23' Safari (6,000 lbs GVW) behind my F-150 (rated to pull 9,000 lbs) in some very windy conditions and never had any trouble from passing trucks.
Randy
PS: The Airstream's shape is a big advantage over a slab sided white box on wheels trailer in windy conditions.
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 03-08-2008, 09:45 AM   #3
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Hi Liz,
Can and does happen though I haven't heard about that happening with many Airstreams from the forums. Lots of factors in play here - driving speed, road conditions, attention to the road, type of tow vehicle (size & weight have to be matched up), traffic conditions and type of hitch.
I would never recommend towing a trailer without some sort of hitch support like a Equal-i-zer, Hensley, Pull-Rite, Reese, Blue Ox... Lots of brands out there and equal number of folks who swear by 'em. A good brake controller also helps you regain control of a trailer that is begining to fishtail...
Go do a search on hitches & brake controllers and start reading. There is a whole bunch of info in the forums on this very topic. Do a search on "towing" and read up on experiences.
It's all here!
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 03-08-2008, 09:48 AM   #4
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Hi Liz. In my opinion the risk of rolling a rig or getting into an accident isn't nearly as high as it might seem reading posts on these forums, but prudence is the order of the day. The short answer is that there's no simple answer to your question. I'd suggest educating yourself on the art and science of towing. Here's a good primer to get you started...RV Towing Tips - Home page
Good reading!
Gary
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 03-08-2008, 10:01 AM   #5
TIMEMACHINE's Avatar
Huntington Beach , California
The best you can buy for towing
One of the best reasons to get an Airstream is safety. Yes, there are many accidents out there with folks violating most of the prior mentioned safety precautions. Keep in mind that because of the design of an Airstream, low wind resistance, low center of gravity, torsion suspension, frame rigidity and more, it is considered by many the safest and easiest trailer on the market. If set up properly with the adequate tow vehicle, and driving rationally at reasonable speeds...it can't be beat for safe towing.
This of course is an opinion.
time
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 03-08-2008, 10:17 AM   #6
Wayward's Avatar
Cary , North Carolina
Not so common I'd say when you consider the huge number of tow rigs running down the road every day - the disasters get lots of exposure on the forums and everyone has an opinion on the causes. Common sense driving goes a long way toward safety.
A properly setup rig with particular attention to the weight distribution hitch with anti-sway bars will deal with any sway or truck buffeting problems.
You do not have to spend a lot to get a stable rig but proper setup is key. The Airstream dealer setup our Safari with a Reese Dual Cam and it is rock steady in all road conditions.
.............Scott
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 03-08-2008, 10:33 AM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up What All Have Said Here....
Take time and use the Forum to do some research, a lot of very informed
folks here. Just like Mother Nature, there are Big Bucks and Little Bucks,
It's what your are comfortable with spending. Most important to match the
T/V, trailer, brake controller and hitch. Good luck and keep us posted.
p.s. we love photo's
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-08-2008, 07:00 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The key is properly setting your trailer up to tow which includes some form of sway control. Tractor trailer trucks passing you do set up a wave of air that can cause your trailer to pull towards the passing truck as it goes by. The amount of force the wave has in it depends upon the winds you are towing in and the difference in the speed of your vehicle compared to the passing truck. Also adding into the equation is level of the road. Generally your trailer is more subject to sway when you are going downhill than up.
In essence, severe conditions of sway usually are caused by multiple factors. The right combination can put you in the throws of severe sway. So you do things to lessen your chance of sway. Some of these include using a weight distribution hitch which is properly set up, some type of sway dampening device, and having the proper sized tow vehicle.
In addition you actively practice sway avoidance. For example, I watch my speed, I don't pass going downhill, I don't allow (if I can help it) a tractor trailer to pass me going downhill, I watch behind me and move a little further to the right (if possible) if I detect an fast truck passing me. Some other things include avoiding hard braking in a downhill situation, looking out for strong cross winds when you are coming out of a wind protected portion of the road, and finally knowing what kind of vehicles produce a lot of turbulence (auto carriers, tank trucks, busses or class A motor homes, large box trucks).
Even with all this, one might still get into a situation. Just understand that safety is a full time job and not only do you have to take care of yourself, but you need to be vigilant of the other vehicles on the road.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-08-2008, 09:14 PM   #9
nilesrob's Avatar
Marietta , Georgia
Images: 12
Some years back we had a not-great tow vehicle with not-great load balancing bars and a not-Airstream travel trailer, and white knuckle trips (sway) were not unusual.
Based on experience, we have corrected all three and the problem literally no longer exists. World of difference.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 03-08-2008, 09:48 PM   #10
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Liz
Hi, Liz. A friend of mine rolled his Suburban / SOB combination too. His Suburban was rated to tow 7,800 lbs of trailer and his first toy hauler was rated at 10,000 lbs; But the one he rolled [second toy hauler] was rated at 12,000 lbs. He also raised the Suburban 6"s and installed huge off road tires. He claims that he was going down hill and was being passed by a big rig. He said he thinks one rear tire on the Suburban went flat. He said that the trailer started to sway and wouldn't stop swaying; I asked him if he hit the trailer brakes to stop the swaying and his answer to me was "Are you supposed to do that?" He had a good hitch that was set up right, but everything else, including his towing knowledge, was wrong. The truck and trailer were totalled, he's too scared to ever tow again, and that's good for the rest of us.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-09-2008, 05:54 AM   #11
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I have tracked the ocurrances within our 100 unit local club that has about 60 active trailer rigs operating. We have averaged two accidents per year over the last 10 years. Some of the accidents are small like just running off the road due to falling asleep or construction. but we also have had a number of roll overs and rear end collisions. The causes are many but loss of control resulting in going off the road is a pretty common. Reaction time of the driver and skill are critical to avoiding big problems, once the accident starts to occur.
Old 03-09-2008, 06:24 AM   #12
1984 31' Excella
Norfolk , Virginia
Images: 11
Sway
As I remember, the last two for certain and probally three rollover accidents involving Airstreams were probally caused by the absence of anti-sway devices of any sort.
Carefull examination of the pictures provided indicated this.
http://www.airforums.com/forums/f48/our-loss-35568.html
Notice in the photographs that there is only the "snap ups" for the weight distribution bars.
This item which has been removed from ebay, the pictures have been removed but when I examined them showed no evidence of sway control.
So
Just go with a good sway control of any type (friction, dual cam, dual cam high performance, hensley, pro-pride or pull rite) and set it up correctly and you should be ok.
Beginner
Beginner is offline   Reply With Quote
Old 03-09-2008, 06:57 AM   #13
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Hello and welcome to the forums. There is an abundance of information here, and a considerable amount of experience.
An adequate tow vehicle, a weight distributing hitch system, and all the experience you can gain are the secrets to safe towing.
Opinions will vary widely about all of the hardware. As to the experience factor, I believe all will agree. Watching your speed and situational awareness are the keys in learning to tow safely and comfortably.
Have fun and learn as you go.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 03-09-2008, 03:51 PM   #14
Arrgh! I wrote a huge post addressing everyone's replies and I've lost it! I *thought* I hit submit. Aack!
Anyway, thank you to all of you. And to those people with long posts-- extra thanks! As a former professional baker, I remember hearing "long recipes are learning recipes" and so it goes with Airstream posts.
I really appreciate the detailed information and I feel way better prepared. I may not have internalized everything yet, but I know where to find it and I understand it generally. And I have all of you to thank for it.
My husband went to look at '64 Overlander today. He said it was great but that someone else already put a deposit on it. Who knows, maybe it could still work out. It's not over till it's over, right?
We saw a 1956 trailer last week that was cute, but too small and in need of too much work for us right now.
Problem number 2: I think our driveway is too steep to get the trailer up to park it at the house. Booo! Time to find a new house, I guess! :-)
Mileage for gas trucks vs diesel trucks? mrchinup1 On The Road... 126 04-21-2008 06:43 AM
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 10:13 PM
Are You Licensed To Drive One Of These Trucks? thenewkid64 Airstream "In the News" 16 07-20-2004 09:09 PM
Accidents-Airstreams...no easy fix Kistler Our Community 20 09-11-2003 04:41 PM
small trucks ALANSD Our Community 3 05-08-2002 05:01 PM
