Old 04-11-2009, 04:05 PM   #1
Augie R.
1960 22' Safari
carlsbad , California
sway bars making a litle noise
Like Pageclots thread I was wondering about how tight to make them and since mine are so old I thought i would post a few pics for you guys to go over... They only make noise when I turn really slow I think it might be that i forgot to grease the ball oops... I 'll get right on that one but about the tightness of it? I'm on the road (In Mississippi right as I'm writing this) so I will check between stops. The brand is reese (travel lite)
ID:	78217   Click image for larger version
augier is offline   Reply With Quote
Old 04-11-2009, 04:18 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Can't really tell without looking at everything. From the pictures I see it looks OK. If the noise is a popping sound on turning it's normal. Grease the ball. You could spray some WD-40 on the head where the bars attach too.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-11-2009, 04:28 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
On my Reese I geese the ball and use a little oil where the arms attach to the head. There are two holes on the top of the hitch head that say "oil" on them.
BTW, it still makes noise. If I hitch the bars extra tight, it makes more noise. You should tighten the bars until your truck is level with the same amount of drop on the front wheels as the rears. At that point there should be a noticeable bend in the bars.
Richard
Old 04-11-2009, 04:41 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
This is a picky point but those are not "sway bars". Their function is to transfer weight to the front axle of the tow vehicle and also back to the trailer axles, and also level the trailer. The do a little to control sway, but that is not their main job. Your tongue (on your trailer that is) does have a small ball above and in front of where the WD bars attach to the tongue. That is where your friction "sway bar" is attached.
Some may dissagree with me but on a trailer your size I just use the pipe section that came with the hitch to tension the bars. The general idea is to put enough tension on the bars so the trailer and tow vehicle are level. The techniques can get pretty techy and has been described in great detail in other threads.
Old 04-11-2009, 05:52 PM   #5
Check your chains. They are the old style small links.
They have a habit of breaking at their pivot points.
Each time you make a turn, the chain that attaches to the torsion bar, moves, and will snap when hitting a good bump, as soon as it's thin enough.
The bars you have are torsion bars. They have nothing to do with sway control.
Those bars look like they are old old old Reese bars.
two sway bars ifly4cal Hitches, Couplers & Balls 17 07-20-2006 03:39 PM
One or Two Sway Bars? jimmysub Hitches, Couplers & Balls 2 07-18-2006 02:37 PM
Sway Bars william Haym 1993-1997 Limited 1 06-23-2006 04:56 AM
Sway Bars tincanholiday Hitches, Couplers & Balls 5 05-28-2004 06:42 AM
