Old 03-07-2010, 10:17 PM   #1
Los Angeles , California
Question Sway bar help for dummies
I just purchased and will pick up a 74 sovereign next week and do not know much about sway bars. From this picture, can anyone tell me what I will need to purchase to make it work? It looks like two bars are connected to chains at the tongue. I'll be towing with a MB GL450. The previous owner has no clue about trailering and does not know how to use it either.
Thank you!
patis is offline   Reply With Quote
Old 03-07-2010, 10:19 PM   #2
Old 03-07-2010, 10:19 PM   #3
Originally Posted by patis View Post
I just purchased and will pick up a 74 sovereign next week and do not know much about sway bars. From this picture, can anyone tell me what I will need to purchase to make it work? It looks like two bars are connected to chains at the tongue. I'll be towing with a MB GL450. The previous owner has no clue about trailering and does not know ow to use it eather.
Thank you!
What exact tow vehicle will you be using?
Different rating hitches match the trailer to the tow vehicle.
Old 03-07-2010, 10:22 PM   #4
Looks like you will also need a 12 volt umbilical cord.
Old 03-07-2010, 11:17 PM   #5
I forgot to mention one more thing. I have done some research and figured out that it is a weight distribution system. My truck has an automatic levelling feature which is part of the 4MATIC air suspension.
Old 03-08-2010, 03:24 AM   #6
You cannot use an automatic leveling system with a load equalizing hitch, as that system defeats the purpose of the hitch.
Old 03-08-2010, 09:01 AM   #7
Thanks Andy: That's what I had suspected. I am glad I didn't buy a new hitch setup for the WDH.
Old 03-08-2010, 09:18 AM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Here is something you may want to look over.
Preparing for the First Tow Home
Ken
Old 03-08-2010, 09:51 AM   #9
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
What is the towing capacity of that Mercedes ? Dave
easyride is offline   Reply With Quote
Old 03-08-2010, 10:07 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
7500lbs...
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-08-2010, 11:47 AM   #11
Originally Posted by ROBERT CROSS View Post
Correct.
Can I still use a WDH to reduce tongue weight with levelling air suspension?
Old 03-08-2010, 12:11 PM   #12
Correct.
As I understand it, only if there is provision to over-ride the system while towing.
Our 3/4 Suburban does not have the auto-leveling function that the 1/2 ton's do when equipped with the AutoRide option. GM realized a lot more of the 3/4's were destined to be dedicated TV and it would be more difficult to adapt the system for WD applications.
I do know that some here tow with the system, maybe they can chime in on their experiences.
Have you weighed the trailer or know the actual weight?
PFC
"Tahawus"
RLC
John Prine
Old 03-08-2010, 12:13 PM   #13
Correct.
There is only ONE WAY, none other.
You must defeat the auto leveling system, so that it cannot activate, and drop the air pressure to minimum.
Anything short of that will defeat the purpose of the load equalizing hitch, no if's, and's or but's. NO EXCEPTIONS.
Old 03-08-2010, 12:25 PM   #14
Ag&Au's Avatar
74 weights
Thought I would put this here for what its worth. The 31 is on page 4
Regards,
Ken
Sway Bar Drops off RichHog Hitches, Couplers & Balls 6 10-22-2009 09:24 PM
Sway bar help Diana Langley Hitches, Couplers & Balls 13 06-10-2008 05:02 PM
New Sway Bar or Just New Bushings? streamlean General Motorhome Topics 48 09-25-2007 10:12 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
How essential is the sway bar? 63overlander Hitches, Couplers & Balls 25 11-03-2004 06:11 AM
