Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 04-17-2003, 09:47 PM   #1
Diana Langley
Diana Langley's Avatar
Profile:
Images: 13
Sway bar help
Or is it an anti-sway bar? I have a Globetrotter and there is a ball welded to the frame for one, so it must be a good idea even for a smaller trailer.
Any information on what to get and what to avoid would be appreciated.
Pet Sitters take the "Board'em" out of Travel !
http://www.pawprints-petsitting.com
Diana Langley is offline   Reply With Quote
Old 04-17-2003, 11:10 PM   #2
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Do you want to get one for yours? The little ball is where a friction sway once went and the current Drawtites will most likely attach to it. As far as little trailers needing them I would say the smaller the trailer the greater the need for one, especially single axle ones like your Globetrotter.
Chas
Chas is offline   Reply With Quote
Old 04-18-2003, 08:00 AM   #3
Diana Langley
Profile:
Images: 13
Thanks, Chas!
Yes, I do want to get one. I've read too many stories about swaying, rollovers, big scary 18 wheelers, and idiot drivers to assume it will never happen to me.
I'm towing with a '97 Toyota 4Runner with the tow package and have really done OK so far. (I know, get a bigger tow vehicle, but I can't justify it for only 4 short trips a year)
I just want to be as safe as possible with what I have for now.
Old 04-18-2003, 01:40 PM   #4
Rickk48
Rickk48's Avatar
Profile:
My Bambi has the small ball on the A-Frame and another small ball on the ball mount which goes into the receiver on my tow vehichle. I use a Reese Friction Sway Control which is a fairly simple bar which goes onto these two balls and then by tighten you get some control over sway due to the friction or "braking" mechanism built into the bar. I believe these are available from any Reese hitch dealer for something around $100.
By the way, Diana, know of any good pet sitter in Orange County?
Rick Klein
'01 Bambi
'99 Land Rover Disco
Rickk48 is offline   Reply With Quote
Old 04-18-2003, 03:03 PM   #5
Diana Langley
Profile:
Images: 13
I went out this morning and bought one. You're right, it was around $100. It looks easy to put on, simply a matter of putting the small ball on the w/d hitch. The ball is already welded on the tongue.
My next questions is: how do you know how tight to adjust it?
Rick, if you'll e-mail me privately, I'll get you some info on sitters in your area.
pawprints@earthlink.net
Old 04-18-2003, 03:39 PM   #6
hhuber
hhuber's Avatar
Profile:
Images: 8
I was just wondering about the sway control for my '67 Caravel.
Tried to get one last week but the RV guy told me they were all alike. I asked for Reese and he had one called pull-rite.
I have not found anyone in my city with Reese products in stock.
Since that's seems to be what most people use I thought it
would be a good idea.
There is no ball on my frame. Can it be added?
Any suggestions would be appreciated.
Heidi
'67 Caravel/'03 Tahoe
hhuber is offline   Reply With Quote
Old 04-18-2003, 04:18 PM   #7
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Competitive products
There are several sway bars on the market that vary only in details; DrawTite and Reese being the most available. They all work essentially the same.
Reese says to tighten the lever until it is parallel with the bar. I find that is about as tight as I want to go comfortably with my arthritic hands.
My 22' International behind my Silverado is rock solid in any sort of crosswind and traffic with my Reese bar. I have driven, albeit slowly, in 70 mile cross gusts and torrential rain, to the point that construction signs were blowing away, and had no control problems..
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 04-18-2003, 06:27 PM   #8
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
If you do go with the anti sway bar use caution when backing up it is possiable to bend the bar or break the ball off in a sharp turn in reverse. I have never had a problem but was warned of the potential.
When I think of it I always disconnect the sway bar if I'm going to back with a sharp turn.
Garry
Old 04-18-2003, 06:45 PM   #9
Pahaska
Pahaska's Avatar
Images: 12
Backing
I never disconnect it and I have never had a bit of trouble. If the ball on the trailer tongue is located correctly, there should be no problem short of actually jacknifing the trailer. The forces on the bar are the same backward or forward.
John W. Irwin
Old 04-18-2003, 07:01 PM   #10
garry
garry's Avatar
When I bought the anti sway bar the sales person told me backing to the side the bar is on "you could" back sharp enough that once the slid is in as far as it will go you could snap the ball or damage the anti sway bar !! Sounded good to me so I have used caution and never had a problem !!
I wonder if this has happened to anyone ??
Garry
Old 06-10-2008, 04:15 PM   #11
crowldawg
crowldawg's Avatar
Profile:  1966 20' Globetrotter
Orient , New York
I was told to take it off when backing my Globetrotter up. I'm a little confused about adjusting the length and tension . When I had it put on along with the stabilizer bars and hitch parts that was the only thing I didn't get documentation for .I have towed the camper about 5000 miles .I would like to check if everything is still OK
crowldawg is offline   Reply With Quote
Old 06-10-2008, 04:57 PM   #12
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
When manevering in tight quarters with large angles between the TV and trailer, unhook the friction anti-sway so you dont bend it. The adjustment is easy. With the ball disengaged, tighten the lever on the friction pads until you cannot move the bar up and down at the ball end with you hand, note the position of the lever and then loosen the adjustment so you can hook up the ball again. Then bring the friction lever back to the previous position and go 1/2 to 3/4 turn further. It's just a brake type set up so "goldilocks" it-not too loose and not too tight.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-10-2008, 05:51 PM   #13
Excella CM
Excella CM's Avatar
Venice , California
Part the second.
Here is the Reese data sheet for their # 26600 friction sway control
ID:	62170   Click image for larger version
ID:	62172   Click image for larger version
Old 06-10-2008, 06:02 PM   #14
easyride
Profile:  1977 27' Overlander
naples , Florida
Heidi
If you buy new sway bar it will come with new balls,attach one end to your hitch,slid it out half way and thats where the one on the frame should go,either bolted,or welded. dave
easyride is offline   Reply With Quote
Tires Causing Sway? Pick Tires 14 12-03-2006 05:38 PM
Reese R54995 hitch bar davidz71 Hitches 0 03-17-2003 11:16 PM
Sway Control WayWard Wind Hitches 24 03-12-2003 09:21 PM
Replacement Reese hitch bar davidz71 Hitches 11 02-20-2003 05:22 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 03:48 PM
