Old 07-08-2010, 03:30 PM   #1
2010 28' International
HiGhlands Ranch , Rockies
Sway Bar Advice Needed.
Have an Equal-i-zer sway control system (Equal-i-zer® Hitch - The “American Original” with 4-Point Sway Control™ and Weight Distribution) and noticed that the trailer is tilting forward a bit as the sway system connection point is lower than that the tucks hitch. Should I be concerned that there is too much weight on the front tires/axle? Really like the sway system, but want to make sure that we are not setting ourselves up from trouble down the road.
Thanks for the help!
Coloradoair is offline   Reply With Quote
Old 07-08-2010, 05:04 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I think you need them to be level. Do you have an adjustable hitch that can be raised to level it out?
Stephanie
Old 07-08-2010, 05:32 PM   #3
_
post a few PICTURES.
it reads like a LOT of issues are possible...
without more details.
basically the trailer tongue SHOULD be a tad low...BEFORE the w/d is tensioned.
once tensioned the w/d will RAISE the trailer tongue.
HOW MUCH?
depends on a lotta things (bar rating, receiver/ball heights, stinger drop, tv suspension ...)
along with pix, the rig really needs to be WEIGHED to know if the w/d is properly adjusted.
measurements can be made at the front/rear of the stream and 4 corners of the tv...
but that's still only an indirect assessment of w/d.
post more info and photographs...
cheers
2air'
Old 07-14-2010, 07:48 PM   #4
1974 31' Excella 500
marshfield , Missouri
Sounds like your weight distribution bar is not set correctly. Try parking on a level surface and readjusting the chains for the W.D. bars. Thisshould level the trailer and tow vehicle out together. The sway control chould'nt cause them to be out of level.
mcm5aaa is offline   Reply With Quote
Old 07-14-2010, 09:11 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
On the web site you linked to you can download the PDF of the owners manual. There are instructions exactly how to properly set up your hitch. Also, there is a help line phone number listed. They are most helpful.
Old 07-14-2010, 09:18 PM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
The owners manual goes to great lengths to describe how to properly set up your hitch...
http://www.equalizerhitch.com/pdf/eq...small_0610.pdf
We've got an Equal-izer hitch and it works great for us...
If the trailer is to low in front, you've got to adjust the hitch on the 'L' shaped shank, most likely...try moving the hitch UP one set of holes on the Shank - It's easy to check your trailer for 'level' running by using a tape measure up front and aft along the lower to the ground...
When set up properly, that hitch is the easiest to hook/unhook, and the ride is great with out particular rig - we have 1K bars and about 875# tongue weight...
Ray
Ray & Pat; Morada, CA
Sway bar help for dummies patis Hitches, Couplers & Balls 23 03-22-2010 09:53 PM
Sway bar help Diana Langley Hitches, Couplers & Balls 13 06-10-2008 05:02 PM
New Sway Bar or Just New Bushings? streamlean General Motorhome Topics 48 09-25-2007 10:12 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
How essential is the sway bar? 63overlander Hitches, Couplers & Balls 25 11-03-2004 06:11 AM
