Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 07-30-2006, 04:26 PM   #1
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
sunday fun with the welder!
a couple of us got together today to attach a sway control to dave and pats argosy.
good chance to try out my new used welder!
we decided to weld the ball onto the frame because the supplied ball mount was the same size as the frame on the minuet. if we had used the supplied self tapping screws they would have been installed into the webbing of the C channel comprimising the strength. welding it on seemed to be the better option.
fun and games, arcs and sparks and a few beers to keep us cool!
john
ID:	24046   Click image for larger version
you call them ferrets, i call them weasels.
Old 07-30-2006, 04:27 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
some more shots
ID:	24052   Click image for larger version
Old 07-30-2006, 04:29 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
and our guest supervisor norbert!
Old 07-30-2006, 04:29 PM   #4
Retired.
. , At Large
Is that a (gasp!) Dodge Caravan that is the iminent tow vehicle?
Old 07-30-2006, 04:32 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yes, it is. and it tows the little argosy quite nicely! the minuet is about 1000 lbs under the tow capacity of the dodge!
john
Old 07-30-2006, 04:36 PM   #6
Retired.
. , At Large
john
Whooda thunk it?
BTW, is you barn leaning, or is it just a trick of the camera? Enquiring minds want to know.
Old 07-30-2006, 04:51 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yes terry, that side of the barn has a bit of a lean to it. the walls are rebuilt using salvaged power pole cross arms from work. i have new lumber to reframe the opening, i plan to square the whole thing up when the new doors go on.... someday! i was lucky to save the old horse barn, it is original from the teens when the place was built. not many cars then. i had a huge tree land on it and almost flatten it, it got caught by another tree saving it from being demolished.
john
Old 07-30-2006, 04:55 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
in additon we straightened norby's bumper and reriveted dave and pat's belly pan.
good day!
john
Old 07-30-2006, 06:03 PM   #9
RobertC's Avatar
1970 21' Globetrotter
Pickens , South Carolina
Ah Ha!!
I've been meaning to post about that ball do-hickey thing on my AS. I also found in one of my compartments that bar thing too. I guess the tow vehicle needs to have something added in order for this thing to work. Now what does this thing actually do?
Skip Callaham
RobertC is offline   Reply With Quote
Old 07-30-2006, 06:06 PM   #10
Retired.
. , At Large
Originally Posted by RobertC
Ah Ha!!
Skip Callaham
The little ball that goes on the side of the A frame is for a friction type sway control unit. There needs to be a similar one on the tow vehicle, and the sway bar goes between them. The friction helps keep the trailer from weaving while you are towing.
Old 07-30-2006, 06:07 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
skip
it is just a slider with two small 1" balls that creates friction in the connection between the trailer and the tow vehicle.
you tighten the handle on the slider to create more friction.
the trunnion on your hitch should have a piece of steel welded on the side of it to accept the ball. the slider just mounts between the two. it is attached by two hitch pins.
john
Old 07-30-2006, 06:44 PM   #12
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Chicken........you took the LP tanks off first before welding........
Where's you sense of adventure.
Old 07-30-2006, 07:13 PM   #13
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
sense of survival! i was NOT into testing darwins theory today!
hey you! out of the gene pool!
john
Old 07-30-2006, 07:31 PM   #14
1960 24' Tradewind
santa barbara , California
Hello john hd,
That welder is old but a great machine ,it has advantages over traditional wirefed mig welders.I own a hobart ironman 210 wirefeed and use a lincoln
225 arc welder for the heavy stuff .Of course it is dependent on the wire size in the wirefeed ,but the variety of rods ( I use 6013 or 6011 ) and the size available make the arc welder a viable piece of eqiupment.I use the wire feed for bigger jobs ,but I used the lincoln with 3/ 16 rod to weld the hitch head
setup .One more thing is careful with the photos and watching the arc!!
Scott
scottanlily is offline   Reply With Quote
Old 07-30-2006, 08:03 PM   #15
RickStream's Avatar
1974 31' Excella 500
, Wisconsin
Long Sleeved Shirt!!
You not only removed the LP tanks, but you wore a long sleeve shirt on a very hot day.
RickStream is offline   Reply With Quote
Old 07-30-2006, 08:04 PM   #16
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
scott,
hey i gotta agree, it is one honking unit! the whole thing with batteries and gas has to be around 500 pounds! it has a 16 horse opposed twin onan.
my personal favorite for pipe work is 6011, flat work is 6013. and 7018 for vertical or overhead projects.
it sure is a fun unit to tinker with, it has a rough and fine control for amperage and a built in 3kw generator to boot!
john
Old 07-30-2006, 08:05 PM   #17
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
no kidding! we were in the shade for this project at least!
john
Old 07-30-2006, 09:35 PM   #18
1960 24' Tradewind
Does that welder have a 1-6 switch or just a high and low? If a high and low
that makes it tougher for controlling the amperage for the thickness of steel
your welding ,that rig probably was made for large jobs mostley where the beam they were welding needed HIGH no fooling with the controls .Ideally
on that airstream frame 130 amps is good ,low may be in that area ,could be
150 or 175 ,the high could be 210 on up to 270 who knows .
Scott
Old 07-30-2006, 09:44 PM   #19
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
Looks like alot of work
Okay guys when you decide to have another work day let us all know and we can bring ours on over
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 07-30-2006, 09:50 PM   #20
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Scott
scott,
it has step settings from 70 to 225 and a fine dial from 1 to 10 amps. i ran about 85 amps with 1/8 rod for this project. plenty hot on full engine speed!
beck,
sure you can come up! just don't expect it to be much cooler than down south!
john
Reopen The Thread Camper! airstreamcaravel Our Community 8 12-04-2008 11:33 PM
withdrawl symptoms-how to survive the winter without your Airstream bhsl8 Our Community 16 11-06-2002 05:28 AM
We need a little fun !! airstreamcaravel Off Topic Forum 8 10-11-2002 01:35 AM
Replacing my 64 Globetrotter Floor BobbyW Repairing/Replacing Floor &/or Frame 4 06-28-2002 11:28 AM
My repair day 3/9/02 ViewRVs Airstream Motorhome Forums 8 03-10-2002 04:29 PM
