Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 07-30-2006, 04:26 PM   #1
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
sunday fun with the welder!
a couple of us got together today to attach a sway control to dave and pats argosy.
good chance to try out my new used welder!
we decided to weld the ball onto the frame because the supplied ball mount was the same size as the frame on the minuet. if we had used the supplied self tapping screws they would have been installed into the webbing of the C channel comprimising the strength. welding it on seemed to be the better option.
fun and games, arcs and sparks and a few beers to keep us cool!
john
ID:	24046  Click image for larger version
you call them ferrets, i call them weasels.
Old 07-30-2006, 04:27 PM   #2
john hd's Avatar
madison , Wisconsin
Images: 40
some more shots
ID:	24052  Click image for larger version
Old 07-30-2006, 04:29 PM   #3
john hd's Avatar
madison , Wisconsin
Images: 40
and our guest supervisor norbert!
Old 07-30-2006, 04:29 PM   #4
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Is that a (gasp!) Dodge Caravan that is the iminent tow vehicle?
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 07-30-2006, 04:32 PM   #5
john hd's Avatar
madison , Wisconsin
Images: 40
yes, it is. and it tows the little argosy quite nicely! the minuet is about 1000 lbs under the tow capacity of the dodge!
john
Old 07-30-2006, 04:36 PM   #6
Images: 52
john
Whooda thunk it?
BTW, is you barn leaning, or is it just a trick of the camera? Enquiring minds want to know.
AIR#2611
Old 07-30-2006, 04:51 PM   #7
john hd's Avatar
madison , Wisconsin
Images: 40
yes terry, that side of the barn has a bit of a lean to it. the walls are rebuilt using salvaged power pole cross arms from work. i have new lumber to reframe the opening, i plan to square the whole thing up when the new doors go on.... someday! i was lucky to save the old horse barn, it is original from the teens when the place was built. not many cars then. i had a huge tree land on it and almost flatten it, it got caught by another tree saving it from being demolished.
john
Old 07-30-2006, 04:55 PM   #8
john hd's Avatar
madison , Wisconsin
Images: 40
in additon we straightened norby's bumper and reriveted dave and pat's belly pan.
good day!
john
Old 07-30-2006, 06:03 PM   #9
RobertC's Avatar
Profile:  1970 21' Globetrotter
Pickens , South Carolina
Ah Ha!!
I've been meaning to post about that ball do-hickey thing on my AS. I also found in one of my compartments that bar thing too. I guess the tow vehicle needs to have something added in order for this thing to work. Now what does this thing actually do?
Skip Callaham
RobertC is offline   Reply With Quote
Old 07-30-2006, 06:06 PM   #10
Images: 52
Originally Posted by RobertC
Ah Ha!!
Skip Callaham
The little ball that goes on the side of the A frame is for a friction type sway control unit. There needs to be a similar one on the tow vehicle, and the sway bar goes between them. The friction helps keep the trailer from weaving while you are towing.
AIR#2611
Old 07-30-2006, 06:07 PM   #11
john hd's Avatar
madison , Wisconsin
Images: 40
skip
it is just a slider with two small 1" balls that creates friction in the connection between the trailer and the tow vehicle.
you tighten the handle on the slider to create more friction.
the trunnion on your hitch should have a piece of steel welded on the side of it to accept the ball. the slider just mounts between the two. it is attached by two hitch pins.
john
Old 07-30-2006, 06:44 PM   #12
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Chicken........you took the LP tanks off first before welding........
Where's you sense of adventure.
Old 07-30-2006, 07:13 PM   #13
john hd's Avatar
madison , Wisconsin
Images: 40
sense of survival! i was NOT into testing darwins theory today!
hey you! out of the gene pool!
john
Old 07-30-2006, 07:31 PM   #14
Profile:  1960 24' Tradewind
santa barbara , California
Hello john hd,
That welder is old but a great machine ,it has advantages over traditional wirefed mig welders.I own a hobart ironman 210 wirefeed and use a lincoln
225 arc welder for the heavy stuff .Of course it is dependent on the wire size in the wirefeed ,but the variety of rods ( I use 6013 or 6011 ) and the size available make the arc welder a viable piece of eqiupment.I use the wire feed for bigger jobs ,but I used the lincoln with 3/ 16 rod to weld the hitch head
setup .One more thing is careful with the photos and watching the arc!!
Scott
scottanlily is offline   Reply With Quote
Pingbacks are On
withdrawl symptoms-how to survive the winter without your Airstream bhsl8 Our Community 16 11-06-2002 05:28 AM
We need a little fun !! airstreamcaravel Off Topic Forum 8 10-11-2002 01:35 AM
Reopen The Thread Camper! airstreamcaravel Our Community 7 10-08-2002 07:41 PM
Replacing my 64 Globetrotter Floor BobbyW Repairing/Replacing Floor &/or Frame 4 06-28-2002 11:28 AM
My repair day 3/9/02 1985air345 Airstream Motorhome Forums 8 03-10-2002 04:29 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
