Old 06-27-2015, 12:38 PM   #1
Natty Lite's Avatar
Mandeville , Alabama
Stud layout for aft upper body
Does anybody have a picture that I can use to find studs in the back upper area?
Without going into much detail, I'm building a bike rack/latter off the back supported by the frame- but I want to secure any type of vibration at the top by screwing to some studs!
Natty Lite is offline   Reply With Quote
Old 06-27-2015, 01:16 PM   #2
Central , Mississippi
I'm sorry to report that there is no frame behind the endocarps
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-27-2015, 02:55 PM   #3
1979 23' Safari
Wayland , New York
I'll back up hihoag, there is no structural support in the top of the end caps. They cannot support weight!
Old 06-27-2015, 03:13 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Before you totally destroy your beautiful Airstream, do a search on "bike racks" and you'll get the gist of what other people have done and what is and isn't recommended.
Attaching anything to the exterior skin of the trailer is generally a bad thing.
Bob Martel
WBCCI# 5766
Old 06-27-2015, 05:39 PM   #5
Natty Lite's Avatar
I'm not going to destroy my airstream I'm just researching my possibilities so there's no stud or structural framework there. I will not use that application, thank you..
Old 06-27-2015, 06:39 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Load it into your trailer....
tjdonahoe is online now   Reply With Quote
Old 06-28-2015, 12:19 PM   #7
amaier7771's Avatar
2013 25' FB Flying Cloud
Colorado Springs , Colorado
Mounting Points on the rear of our AS.
I purchased some "Brackets" and "Solid Aluminum" bars directly from ZIP DEE, and made a general purpose rack for the back of our 25FB AS. The solid bars are the same stock as used for the Awnings, as are the brackets. The rack is simply bolted together with Stainless Steel bolts. It is attached to the "stud/frame" under the rear window on the top, and to the bumper on the bottom.
The rack is Easy to remove and attach. I mounted a "Grill Bracket" to the rack for a handy place to hang the grill. I fabricated quick attach bike rack out of some scrap aluminum from a salvage place, which simply slips over the rack for transporting of one or two bikes. Total investment about $100.
AL
ID:	241760   Click image for larger version
ID:	241762   Click image for larger version
amaier7771 is offline   Reply With Quote
Old 06-28-2015, 02:19 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
I like that.
Lets have a bit more explanation of that last picture. Is it a ladder folded down or just the bike rack?
If I were to start over I would follow you idea.
2004 Excursion 4x4
Old 06-28-2015, 04:04 PM   #9
amaier7771's Avatar
HowieE,
Here are some additional photos. The rubber clamps for the bike are "Original Quick FistŪ Clamp for mounting tools & equipment 1" - 2-1/4" diameter (Pack of 2)" from AMAZON. The BIKE rack Assembly that slips over my RACK is made of surplus aluminum extrusions i found by SODEM-FRANCE, but you could also use 8020INC extrusions you can buy on EBAY, or aluminum extrusions that you can buy at LOWES, ACE, and hobby stores.
The thing that I feel helped me the most, was talking to a sales guy at ZIP DEE who sold me the 4 aluminum ZIP Dee mounting brackets and lengths of ZIP Dee aluminum solid bar extrusion to make the removable RACK. I drilled/threaded the SIP Dee solid bar and assembled it with SS cap bolts. It is very rigid, I can even use it as a ladder to clean and wax the top of the AS.
Once I made RACK, it is not that hard to make attachments such as the Bike RACK, a bracket to hold the grill, a bracket to carry two GERRY cans, etc, etc.
Hope this makes sense.
Name:	Screen Shot 2015-06-28 at 3.34.58 PM.png
ID:	241788   Click image for larger version
ID:	241790   Click image for larger version
Aft and center bathrooms - why Jammer Our Community 5 01-29-2010 11:06 PM
insulating the aft under bed storage wmarsha Exterior Storage Compartments & Access Doors 3 08-02-2009 04:07 PM
Power Twin Stabilizers and fore/aft trailer movement on campsite with slight grade TX_Streamer Jacks, Stabilizers, Lifting and Leveling 7 10-24-2007 10:00 AM
aft frame repair daveinbama Repairing/Replacing Floor &/or Frame 2 07-19-2004 06:16 PM
