Old 07-30-2012, 01:11 PM   #1
Bettye's Avatar
2010 25' FB International
Mobile , Alabama
Images: 18
Stabilizer/Sway Bar for New Camper
We are considering the purchase of a 2010 25' International Signature. Our TV is a 3/4 ton Dodge Ram. Do we need stabilizers and sway bar to tow this camper.
Bettye & Harry
WBCCI #10360
Member Southeastern Camping Unit
Bettye is offline   Reply With Quote
Old 07-30-2012, 01:19 PM   #2
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Weight distribution hitch and sway control for sure. What are you using for the 31'?
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 07-30-2012, 01:22 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The answer is yes, if you intend to do any traveling. I do not think you need to overdo it with a $3,000 hitch but a simple weight distribution hitch, with or without a dampening device would cost less that $1,000. You might be able to locate one on Craigslist even cheaper. If you have the crew cab and the full length truck bed the requirements would be less because of the long wheelbase on the truck.
Old 07-30-2012, 01:31 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
You can pick up an Andersen WD for under $500 new. Easy on and off and light weight. Sway control and WD in one unit. Myself and others are using them and loving them.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-30-2012, 02:18 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto, on the Andersen, I am very satisified with the performance of mine. I have never read a complaint from anyone that actualy has and uses one. For the money I personaly think that it is best value on the market.
MICHAEL
Old 07-30-2012, 02:29 PM   #6
tinman1's Avatar
2002 30' Classic
East Central , Alabama
Definitely, I previously owned a 1993 25' Excella, and now have a 2002 30' Classic. Have used Reese dual cam anti-sway on both with no problem.
As was previously asked, what do you presently use on the 31' Excella?
There are several good units available, as you can tell by various posts in the forums.
Congratulations and best of luck in selecting the unit of your choice.
Curt, Joan and "BonJovi"
tinman1 is offline   Reply With Quote
Old 07-30-2012, 02:34 PM   #7
Bettye's Avatar
Mobile , Alabama
Images: 18
Not sure what we use on the 31'. If we get the new one, we're going to let the towing equipment go with the camper. Sounds like the Anderson is the way to go. Any other opinions?
Bettye & Harry
WBCCI #10360
