Old 03-19-2006, 11:30 AM   #1
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
squeek in the hitch.
When we have the airstream hitch up, and we use the bars with the chain links (5 links) It seems to make alot of creaking and popping is this normal. Our hitch ball seems to be greased enough and the trailer pulls great and true. It's when we come to a stop or turn. Also should we take the bars off when backing up into a spot or our driveway.
Becky
rebel beck is offline   Reply With Quote
Old 03-19-2006, 12:10 PM   #2
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
It is probably normal noise and nothing to worry about. There are some significant stresses on the system and most noises are to be accepted and not worried about. A little oil or grease at contact points is helpful.
I always take the bars off when I'm parking at home because I have a rear clearance problem. Otherwise, at campsites, etc. I seldom remove the bars unless I'm ready to unhook.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 03-19-2006, 12:44 PM   #3
mandolindave's Avatar
I take my bars off on wet ground
It puts weight back on the rear wheels so I can get better traction.
The trick is to do it before you get dug in the soil.
mandolindave is offline   Reply With Quote
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Hensley Arrow Hitch Les Hitches, Couplers & Balls 116 12-14-2015 07:41 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
