Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 06-30-2004, 08:57 PM   #1
Navigator
Profile:
Spring Bars Strong Enough?
My Reese spring bars are 800# rated. My hitch weight is 730#.
Do I need higher rated spring bars? Am down to 2 chain links to the yoke.
Dick
Navigator is offline   Reply With Quote
Old 06-30-2004, 09:05 PM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Sounds OK
I would go with what you have. That is about the same ratio of tongue weight to bar capacity that I had on my International. That trailer towed perfectly. I would rather have bars a bit light than way too heavy.
Unless the bars have a pronounced curve when tensioned, you should be OK.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 10-05-2004, 08:48 PM   #3
Loren
Loren's Avatar
Profile:
Dick
Dick,
Do you mean that you have only two chain links from the hooks on the trailer A-frame to the spring equilizer bar? If so, then that is not enough to allow for forward and aft travel while turning. You should have at least six links there.
This adjustment is made by changing the angle of the hitch head. Yours would need to be pitched further downward to change the angle of the equalizer bars.
Loren
1997 - 34' Classic Limited Front Kitchen.
2000 Dodge 2500 diesel with Pulliam Pull-Rite hitch.
Loren is offline   Reply With Quote
Sway Bars tincanholiday Hitches 5 05-28-2004 06:42 AM
Wanted, Wt. Dist. Spring Bars Navigator Parts Archive 0 03-11-2004 07:04 PM
Spring has Arrived Here, Can't Be Long for the Rest of You Guys Big Dee Our Community 6 03-09-2004 09:23 AM
weight distributing bars/trunnion bars teutonik Hitches 2 12-04-2003 06:58 AM
Do I need to grease WD bars? Stefrobrts Hitches 7 10-26-2003 06:54 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
