Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 06-08-2015, 06:05 PM   #41
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
So far, I've bought two of those clamps, and neither of them work for any longer than it takes to turn the first corner, then, either the side force, or the vertical force, moves the tow bar and loosens the whole thing again.
I've had enough of this, Wednesday, I'm taking it to a machinist friend who will build up the tow bar, on one side, and the top, then machine it down to give a precision fit. We're shooting for about .010 clearance, on the top and sides. At the same time, he's going to build up the hitch pin holes, and redrill them to the proper size to accept the 5/8" htch pin.
This should take care of the sloppy fit....
For whatever it's worth.
Larry
Larry C is offline   Reply With Quote
Old 06-09-2015, 06:40 AM   #42
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Larry;
Just use a couple of shims like I did. I measured .064" between shank and receiver, and made two .060" shims, one drilled 5/8"for the pin. One end is bent over 90 deg. to prevent it being 'swallowed' and for easy removal.
I still have .004"clearance, which gives a modicum of play, and I grease the shank when I install it. No rattle, no play, and it comes out easily.
MelGoddard is offline   Reply With Quote
Old 06-17-2015, 06:21 PM   #43
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
After getting further into this sloppy factory hitch, I found that I had (when measured at the top of the ball), 1 3/4" of slop on the vertical (pitch axis), on the side to side (yaw) axis, there was 1". I found that there was evough slop in this lashup that the tow bar was actually pivoting in the 5/8" hitch pin.....not good, in my opinion.
So instead of trying to weld, shim, etc., I bought a new Curt, Class 5 reciever, and installed it today. I did have to change the height of the ball mount to mate up with the 19" or so tongue height, but not a big problem..
The important thing to me at least was, I down have 3/4" vertical movement, and 5/8" side to side.....
I think I'm happy......we'll know next week, when we leave for a 3 month trip to Indiana, the to Las Vegas. Here's a coulple pics of the new hitch.
LarryClick image for larger version
Originally Posted by MelGoddard View Post
Larry;
Old 06-17-2015, 06:39 PM   #44
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I can't tell from the pics but was your factory hitch a 2.5" and your replacement a 2"?
Old 06-17-2015, 07:26 PM   #45
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Stop the slop and she tows a lot nicer with a lot less noise. No more elongated pin hole.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-17-2015, 08:06 PM   #46
No. 13's Avatar
2012 25' FB Flying Cloud
Boise , Idaho
A few months ago m.hony recommended the clamps that he posted with a few pictures. These things work awesome. If you get the same clamps you will not have a problem they work great. You have to turn them upside down so you're tightening from the top.
No. 13 is offline   Reply With Quote
Old 06-17-2015, 08:47 PM   #47
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The receiver square hole was "wallowed out"!!!! That allowed the hitch bar to move.... A lot!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-18-2015, 06:53 AM   #48
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I tried two different clamps, I clamped them from the side, and I clamped them from the top. Both of them were just fine, until, I either applied the brakes, or made a turn.....I may not be a rocket scientist, but I am fairly congnicent of how things work...
For what every it's worth.
Larry
Old 06-18-2015, 06:58 AM   #49
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
You are exactly right! Actually, the elongated hole was caused by a hitch reciever that was "out of specs". It allowed the tow bar to "pivot", on the hitch pin, and over 107,000 miles enlarged both ends of the reciever. Due to the nature of the pivot point, the hole continually got more and more elongated....
I think the problem is solved, finally.
Larry
Old 06-18-2015, 07:02 AM   #50
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Both hitch recievers are 2". The new Curt hitch is a class 5, the Dodge factory hitch is considered a class 3/4. There really isn't much comparison as to the quality and construction between the two..
If and when I order a new truck, I'll order it without the hitch, and install the class 5 myself.
Larry
Old 06-18-2015, 08:30 AM   #51
m.hony's Avatar
2013 30' Classic
I had to re-tighten the anti- rattle device several times. It kinda sorta bent and settled to conform to the shape of the hitch receiver, shank, and Rocks Tamers mounting brackets gradually. After a while, it stayed tight.
TAC #MS-10
Airforums #70955
Old 06-18-2015, 09:05 AM   #52
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Originally Posted by KJRitchie View Post
I have a 2010 Tundra and the receiver tends to be slightly larger than the Equalizer head shank. Is it possible to have some spot welds put on the hitch shank as shims to remove the play? I have a grinder at home that I could use to grind away the spot welds to customize the fit.
I know there is a bolt on device to remove the play but you have to unbolt it every time you want to remove the head. That doesn't sound too convenient.
Kelvin
Yes, worked well on the 2" shank for the 1/2 ton and additionally spotted the adapter for the 3/4 T. I finished the fitting with a file rather than a grinder ... too easy to remove too much material and then it needs to be re-spotted.
Old 06-19-2015, 03:17 PM   #53
2022 Atlas
Homosassa , Florida
I joined the take out the slop group sort of. I mad to shims for my 3/4 ton. One for the reduction insert and one for the Hensley stinger.
Tater is offline   Reply With Quote
Old 06-20-2015, 01:01 PM   #54
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
One last hitch update, hopefully, the problem is resolved.
After installing the Curt Class 5 receiver, I took the AirSafe towbar to my welder/machinist buddy. He welded the elongated holes shut in the towbar in the tow bar. Then drilled a new hole in the tow bar (21/32, I think), then we reinstalled the AirSafe.
What a difference! I now have about 1/4" play side to side, and vertically! I have to tap the hitch pin to get it through the new holes. I think this will loosen a bit after a few hundred miles of towing...I don't need a clamp, and I really feel good about this change.
Larry
Old 06-20-2015, 04:14 PM   #55
m.hony's Avatar
2013 30' Classic
That 1/4" will be 3/8"...
TAC #MS-10
Airforums #70955
Old 06-21-2015, 05:34 AM   #56
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I would be surprised if it wasn't. But that's a lot better than 1" horizontal and 1 3/4 vertical
Larry
That 1/4" will be
3/8"...
Old 06-21-2015, 10:54 AM   #57
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
I have been using the stowaway clamp and it does the job -- no slop and no noise. It does require carrying a ratchet as it has to be loosened to remove the hitch bar from the receiver -- takes about 60 seconds to do.
Amazon.com: StowAway Hitch Tightener: Automotive
remphoto is offline   Reply With Quote
Old 06-29-2015, 10:07 AM   #58
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Do you have to torque these down to a specified amount or do you just crank on it with a 3/8" ratchet?
Kelvin
Old 06-29-2015, 11:32 AM   #59
"Cloudsplitter"
Kelvin,
I use a Box wench...I do very snug. Only used on the boat stinger so it comes on and off a lot. Most important is to alternate and tighten equally.
POI...notice it's up-side-down, with a heavy tongue weight, as in AS, I think it would be better to use it as designed. That way the U-bolt would not be supporting the TW and under much less stress.
Old 06-29-2015, 01:09 PM   #60
m.hony's Avatar
2013 30' Classic
Mine is upside down because of how the Rock Tamers are mounted. I could move the Rock Tamers mount, but I haven't so far.
TAC #MS-10
Airforums #70955
Broken welds on a '79 screen door blickcd Doors & Locks 4 09-08-2011 06:43 PM
Deep drop WD hitch shank ground clearance? mountainboy Hitches, Couplers & Balls 5 07-20-2009 04:56 AM
How do I Install an Adjustable Shank on my Hitch?? SmokelessJoe Hitches, Couplers & Balls 23 05-19-2008 09:18 PM
Shank too long for Reese Hitch? Bakes5 Hitches, Couplers & Balls 8 04-19-2007 06:57 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
