Old 06-03-2015, 08:10 PM   #29
dalemonroe's Avatar
2008 16' Safari
Portland , Oregon
I welded a piece of thin steel to the side of mine and filed it to fit.
dalemonroe is offline   Reply With Quote
Old 06-03-2015, 09:49 PM   #30
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I use Airstream Ball Lube on everything. No problems here.
NavyCorpsman is offline   Reply With Quote
Old 06-04-2015, 06:36 AM   #31
1981 31' Excella II
New Market , Alabama
I would be worried about so much slop that is bends the pin. That is not a normal amount of slop and I think that warrants a new receiver being installed. Welding these receivers makes me a little worried about changing the properties of the metal. I have gone so far as to weld a nut to a receiver extension and then using a bolt to take up the slack. This was used on an extension piece that held some steps for a slide in camper. The modified piece was not used to pull a trailer.
Perry
Originally Posted by dbj216 View Post
This thread is applicable to my sloppy shank to receiver fit I had a couple of years ago. I discovered a bent hitch pin while towing. Not good. I found my shank fit so poorly in the receiver that the hitch pin is what resisted torsional forces.
The situation was made worse in my case as my Super Duty came with a 2 1/2 receiver as well as a reducer sleeve to get to 2" square. There was clearance slop between both members. Again, the hitch pin was getting pinched, and the holes in the receiver were getting elongated.
I found a Curt Mfg. reducer sleeve that fit rather tightly in the Super Duty, better than the Ford supplied one. Then I welded the Curt reducer sleeve to the Pro Pride shank eliminating any slop between those two members. The heat of the weld distorted the Curt reducer enough that I had some serious power sanding to finally get a loose enough fit that I could assemble the shank to the receiver. These steps eliminated most of the slop.
I can now twist my shank using my Rock Tamer bars and the hitch pin stays free, or unbound. And my hitch pin is free and unbound when the trailer is connected and weight bars tightened. I do not believe the hitch pin was designed for any torsional forces, only sheer with the acceleration and braking forces.
So if the slop is great enough that it binds the hitch pin, I recommend figuring out a way to eliminate it. Weld build up on the shank, and then ground to a good fit would work in my view. I would use a bead weld, not a spot weld. You need some good bearing area so you don't wear the receiver. I also purchased a better hitch pin for added security. I even keep a grade 8 bolt in the tool box just in case I see anything unusual with the hitch pin.
By the way, I could not detect any difference in towing or noise before and after I eliminated the sloppy fit.
David
Old 06-04-2015, 06:55 AM   #32
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"It always seems to be some jerk in a giant pick up truck that does it."
I resemble that remark.
Right now it is out. But when we leave for the summer it will probably be in until we get back in October. Stay well clear of the back of "giant pick up trucks".
Bill M. is online now   Reply With Quote
Old 06-04-2015, 07:59 AM   #33
1976 31' Sovereign
Oswego , Illinois
Smile spot welds
Originally Posted by dan hartman View Post
have my hitch on all the time. saved my rear bumper twice ! people texting while driving in bumper to bumper traffic have run into the back of my truck and damaged there front ends! got what they deserved! hitch is on full time now.
Insurance cos. will have field day if leaving hitch on and doing damage plus so will cops, or causing personal injury.
Old 06-04-2015, 08:38 AM   #34
CRH
1995 25' Excella
xxxxx , xxxxxx
Originally Posted by cwf View Post
Budweiser can... Eeerrrr... Uh....shim stock.... Also handy for muffler patches and gaskets on Harley's.
Yep, I have been using beer can shims to seal the pipes on Ironhead heads for years.
CRH is offline   Reply With Quote
Old 06-04-2015, 08:45 AM   #35
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I drink my IPA out of bottles
I think we have so 7 up cans, I'll try cutting a some strips to see how it works.
Kelvin
Old 06-04-2015, 10:57 AM   #36
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by philipsinewe View Post
If you are using weight distribution, the play should be a nonissue. You are lifting close to 1000 pounds and the bar is in, pretty much a total bind. Isn't it?
What about side to side stinger movement?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-04-2015, 10:59 AM   #37
GCinSC2's Avatar
Kelvin
IPA, yup good stuff. Aluminum shims, me thinks too soft to hold up.
S/OS #001
Old 06-04-2015, 11:46 AM   #38
1974 Argosy 20
Kooskia , Idaho
My aluminum shims were too soft and got beat thin in about one trip. I went to Home Depot and got some Simpson Strong Ties metal mending plates for under a buck. They are steel and seem to hold up much better. One thickness shim on the bottom and one on the side seems to take all the slop out of my hitch system. My hitch receiver is on a Jeep Grand Cherokee, 2012.
I have an Andersen hitch system. When I was at the Andersen plant in Idaho Falls, ID they told me that they buy the shank shaft material pre made and have no actual control over it's dimensions. They indicated it is a standard stock industrial metal product. They said that many of the receivers built seem to be oversized and of course they also have no control whatsoever about the receiver socket size which comes on the rigs as delivered to the customer.
I don't recall this being a problem in the "old days" but seems to be common now.
Old 06-04-2015, 12:03 PM   #39
KJRitchie's Avatar
2008 25' Classic
I found some flat washers in my parts bins but they were too thick. How thick are the Simpson Strong Ties?
Kelvin
Old 06-04-2015, 12:32 PM   #40
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Name:	ImageUploadedByAirstream Forums1433442675.671697.jpg
Name:	ImageUploadedByAirstream Forums1433442750.922782.jpg
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-08-2015, 06:05 PM   #41
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
So far, I've bought two of those clamps, and neither of them work for any longer than it takes to turn the first corner, then, either the side force, or the vertical force, moves the tow bar and loosens the whole thing again.
I've had enough of this, Wednesday, I'm taking it to a machinist friend who will build up the tow bar, on one side, and the top, then machine it down to give a precision fit. We're shooting for about .010 clearance, on the top and sides. At the same time, he's going to build up the hitch pin holes, and redrill them to the proper size to accept the 5/8" htch pin.
This should take care of the sloppy fit....
For whatever it's worth.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 06-09-2015, 06:40 AM   #42
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Larry;
Just use a couple of shims like I did. I measured .064" between shank and receiver, and made two .060" shims, one drilled 5/8"for the pin. One end is bent over 90 deg. to prevent it being 'swallowed' and for easy removal.
I still have .004"clearance, which gives a modicum of play, and I grease the shank when I install it. No rattle, no play, and it comes out easily.
MelGoddard is offline   Reply With Quote
Broken welds on a '79 screen door blickcd Doors & Locks 4 09-08-2011 06:43 PM
Deep drop WD hitch shank ground clearance? mountainboy Hitches, Couplers & Balls 5 07-20-2009 04:56 AM
How do I Install an Adjustable Shank on my Hitch?? SmokelessJoe Hitches, Couplers & Balls 23 05-19-2008 09:18 PM
Shank too long for Reese Hitch? Bakes5 Hitches, Couplers & Balls 8 04-19-2007 06:57 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
