Old 03-31-2006, 12:09 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Specified ball height
The 1979 Airstream that I just bought has a specified ball height of 19 1/2" I am getting setup to tow it home Sunday. I have a tow bar which will allow me to adjust the ball height. Should I add an inch or 2 to allow for rear in sag on my TV or should I shoot for as close to 19 1/2" before I get there and let the WD do the rest of the work?
wacnstac is offline   Reply With Quote
Old 03-31-2006, 12:16 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
leave one inch for spring sag on your tow vehicle.
you may find your new trailer is not at the specified height due to a number of reasons. the trailer axles may be a little tired and have sagged some.
level the trailer on a flat surface, measure it and add one inch. then set your tow vehicle to that number.
john
you call them ferrets, i call them weasels.
Old 03-31-2006, 12:17 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
also, recheck the tightness of your hitch hardware after a couple of miles. (as well as your trailer's lug nuts)
here is a tip, to tighten your ball turn the hitch 90 degrees in the reciever so you can stand on the wrench!
john
Old 03-31-2006, 04:11 PM   #4
Images: 43
Would that 19 1/2" be to the top of the ball or the base of the ball?
Old 03-31-2006, 04:44 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
top
john
Old 03-31-2006, 04:52 PM   #6
Images: 43
Yikes, the lowest I can get the bottom of my ball with the HD adjustable bar I have is 20". Hopefully she'll sag enough to get me in the ballpark.
Old 03-31-2006, 05:27 PM   #7
2006 30' Classic
Farmington , New Mexico
Images: 14
Before you spend lots of $$$$ for a new shank concider this. I had the same problem. When the ball mount was at the correct height I could only aline one bolt. The second had no bolt holes in the shank to align with. I assembled mine this way with only one bolt, adjusted the ball angle as needed, then took it off and to a welded who welded the thing up leaving the one bolt in place. Obviously it's no longer adjustable afterwards but a new shank was over $150.00!!!! Welded properly you'll not sacrifice safty .
Pieman
Mike Lewis is offline   Reply With Quote
Old 03-31-2006, 05:32 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
you will most likely be fine for your trip home.
you can fine tune it from there.
john
Old 03-31-2006, 06:16 PM   #9
Images: 43
Thanks guys.
Old 03-31-2006, 07:41 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Spring sag
If you want a more precise measurement, we need your tongue weight and type of TV. I have a chart for projecting this. Sag is a factor of both tongue weight and rear spring sag. Obviously, half ton trucks and SUV's will sag more than a 1 ton dually.
Or simply measure from the ground to the bottom of the hitch ball unloaded, then with the T/T attached, then compute the difference and adjust accordingly.
Old 03-31-2006, 08:38 PM   #11
Images: 43
TV is a 2003 expedition so I do expect some sag. Tongue weight on the trailer is supposed to be around 600lbs.
Old 04-02-2006, 05:45 PM   #12
Images: 43
Well I made it home today without incident. I tell you what, those WD hitches really make a difference. It felt smoother than when I tow my 6x10 trailer home full of wood.
Old 04-02-2006, 05:48 PM   #13
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
so, how close to level did you get it?
john
Old 04-02-2006, 06:26 PM   #14
WayWard Wind's Avatar
2004 25' Safari
Just curious
Lew-- we just purchased a new TV---2500 HD GMC--- & since you said you have a chart for calculating sag, I'm wondering what it says for our set-up. We have a 25' Safari w/ a tongue weight of 610# give or take alittle.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Airstream Height Earl Winterizing, Storage, Carports & Covers 25 03-22-2008 08:34 PM
Airstream height Earl 1981 - 1983 Excella 1 09-01-2003 09:35 PM
tow ball size iguana Hitches, Couplers & Balls 2 10-03-2002 11:39 AM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
